God awful DAC noise?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by fpf, May 31, 2016.
  1. May 31, 2016 at 9:15 PM
    fpf
    fpf [OP] Well-Known Member
    TRD PRO
    Tried to use it a little while back on my 2015 but the noise it made while engaged was so horrendous I thought the transmission was going to explode or something. Wtf. Also it had quite the lag going down hill before it kicked in. Is this normal? My wife's DAC on her Xterra is silent and works flawlessly.
  2. May 31, 2016 at 9:22 PM
    pruchai
    pruchai KAMA3
    Igor
    San Diego, CA
    '14 TRD TX Baja
    Not enough...
    Yeah, the manual says that you "may" get noise. I always get clicking or grinding noise when I used it.
    http://www.ttguide.net/downhill_assist_control_system-72.html
    When the system is in operation, the slip indicator will flash, and the stop lights/high mounted stop light will come on. A sound may also occur during the operation. This does not indicate a malfunction.
  3. May 31, 2016 at 9:27 PM
    Pigpen
    Dan
    Northwest Montana
    Is the transmission oil topped off?
  4. May 31, 2016 at 11:02 PM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    It has nothing to do with the transmission. The sound you are hearing is the brake module applying pressure as needed to maintain control while going downhill.
    fpf[OP] and Sharpish like this.
  5. Jun 1, 2016 at 4:17 AM
    jmaack
    jmaack Well-Known Member
    Justin
    Helena Alabama
    Skewped hood silver 4runner
    Ome, Sqeak free dakars, arms, skids, sliders.
    I tried it out once when I got my truck. It is loud. Never used it again.
    fpf[OP] likes this.
  6. Jun 1, 2016 at 4:27 AM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    ^^ THIS ^^
    All those noises are perfectly normal. I use it quite often exploring potential hunting & fishing sites on mountain forest roads (we call them logging roads) here in Maine.
  7. Jun 1, 2016 at 6:29 AM
    fpf
    TRD PRO
    How can Toyota have such a loud system when other companies have clearly found a way to make theirs silent??? I'll never use my DAC again
  8. Jun 1, 2016 at 7:04 AM
    Sig45
    Mark
    Maine
    The noise is of less concern to me than than the actual functionality of the system, which works very well.
  9. Jun 1, 2016 at 12:32 PM
    2015WhiteOR
    Gainesville TX
    Sorry but that doesn't matter. You already paid for it so Toyota got their money. LOL
    But really - Why on earth does it matter if it makes a bunch of noise? If you're crawling along and need DAC, you should care more that it gets you down safely.
  10. Jun 1, 2016 at 12:39 PM
    Large
    Large Red
    Forgot I even had this in my taco .. don't think I've ever used it.
  11. Jun 1, 2016 at 12:54 PM
    fpf
    TRD PRO
    It's not that it makes noise, it's that it makes that grinding noise that makes you think you are trashing your vehicle. Now if they could make it so that the noise coming from it was my favorite rock bands song i wouldn't mind lol.
    Imagine if every time you shifted gears a loud clinking sound happened. Would it annoy you more than your other ride that is silent when shifting?
    You are right, I shouldn't let it bother me. But it does damn it. Lol
  12. Jun 1, 2016 at 1:12 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    yup its normal, i highly doubt your xtera did as good of a job. be glad you have the electric boosted master cylinder on your TRD OR 4x4.... the rest of the poor saps dont have it and have much shitty break pedal feel.
