God I love my Taco. The Burnt C6 Taco Build
Discussion in '2nd Gen. Builds (2005-2015)' started by Burnt C6, Feb 5, 2014.
  1. Feb 5, 2014 at 6:23 PM
    Burnt C6
    Burnt C6 [OP] Well-Known Member
    David
    Houston Texas
    Silver & Black 06 PreRunner
    Bilstein 5100 up front new Powder coated Coil Springs and Calipers, With 5160 in back, New 3” Dakar Rear Spring pack, Slotted and Cross Drilled Rotors, SS brake lines,Icon UCA’S . PIAA Driving Lights, Wheels Pro Comp 7031 17”x9 with 295/70 R70 XTreme tires. Katzkin Premium Leather Seats, Doug Thorley long tube headers and Y pipe, Under hood LED light kit,
    5100 Bilstein
    5160 Bilstein in back,
    SS brake lines,
    Borla Cat back exhaust
    Icon UCA’S .
    NFab light bar
    PIAA Driving Lights
    URD CAI w/ control module
    BP Fabricating black powder coated skid plate
    600Watt Pioneer Stereo with blue tooth.
    Spyder Projector HID headlights
    Warm White hood light kit (thanks tacodane)
    Doug Thorley Long Tube Ceramic coated headers.
    Doug Thorley Cat Delete Y Pipe bomb .
    before any mods
    I bought new Coil Springs and coated them along with my new Calipers. never do this when it is 30 deg outside. :eek:
    Front being installed. Bilstens up front and all new SS brake lines front and back
    Also bought new slotted and drilled Rotors and SS brake lines. Ended up having to buy new UCA’s ouch that was not cheap. But they are top of the line Icon Vehicle Dynamics.
    Bilstein 5160 out back with new springs.
    As she sits now. 3” suspension lift and 3” of tire lift. 6” total Bushwacker Pocket Flares.
    The wheel are Pro Comp 7031 17x9 with Pro Comp Extreme MT 295x17 33”.
    New Grill and PIAA Driving lights
    Headlights installed
    The Seats are done
    Added the PIAA lights
    installed the Borla Exhaust
    installed the URD CAI
    installed the BP Fab skid plate
  2. Jul 4, 2014 at 2:27 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Truck looks really mean man. :thumbsup:
  3. Jul 11, 2014 at 4:28 PM
    monstajp
    monstajp Well-Known Member
    joshua
    las vegas
    2011 trd sport debadged
    Debadged, Blacked Out Taillights and 3rd Brakelight , Blacked Out Grille, Blacked Out Lower Valence, Hot Wheels Badges, Yellow Fog Lights, Rims and Tires. Undercover Swing Case, Pop-A-Lock on my Tailgate, N-FAB Step Bars, Extang Trifecta Bed cover, Aero Cat- Back Exhaust, PIAA Extreme white 4000k Bulbs, Readylift 2.25 Leveling Kit.
    Nice build
  4. Jul 11, 2014 at 5:04 PM
    Hot2na
    Hot2na Well-Known Member
    what kind of grill ???
  5. Jul 12, 2014 at 5:16 AM
    Stockmonester
    Stockmonester Well-Known Member
    Nick
    Rome, Ny
    2019 v6 sr 4x4
    in channel vent visors
    I like that grill.
  6. Jul 26, 2014 at 11:09 AM
    Burnt C6
    David
    Houston Texas
  7. Aug 17, 2014 at 5:16 PM
    Burnt C6
    David
    Houston Texas
    installed sound insulation and the hood light kit. Need to work on the insulation a little. Thanks Tacodane for the light kit.
    installed the seal plates from G Tec Fab
    Painted the TRD Silver
  8. Aug 17, 2014 at 5:19 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    looking good
  9. Sep 26, 2014 at 9:42 AM
    Burnt C6
    David
    Houston Texas
    did the hood blackout install looks good.
    then decided to add a little flare to it.
    also put the same graphics on the bed side. installed them in at the cab. I think it looks betters since they are not factory.
  10. Sep 26, 2014 at 9:47 AM
    Burnt C6
    David
    Houston Texas
    Doug Thorley headers and Y pipe bomb installed. It sure is loud with the Borla exhaust. :devil:
  11. Sep 26, 2014 at 9:52 AM
    xgalvanxgx
    xgalvanxgx seymour butts
    Gerardo
    OC (Lake Forest) California
    TRD Off-Road BlackSandPearl 07 PreRunner
    DTF Race Kit with 2.5 x 10 Kings, DMZ SUA rear with 16" triple bypass Kings, King bumpstops front and rear, 17" KMC RG1 powdered in Matte Bronze with black ring with 37" BFG KO2s, front and rear DTF bumpers, front Fiberwerx glass and Mcneil trophy bedsides, K&N 77 Series Intake, Magnaflow, Pioneer touchscreen, Rockford Fosgate 10" sub with box and amp. Dyanamat walls, Andres' devil horn emblem, 50" D4 curved LED bar, rear chase light rack (brake, ambers, white lights) Engine brace, deleted inner wheel wells for max up travel. Cab roll rage built into bedcage.
  12. Nov 18, 2016 at 8:19 PM
    urban
    urban Well-Known Member
    Illinois/Michigan
    12 DCLB sport OME lift
    305/65r17's on 17x9.5 Rotiforms Cab mount chop 4.10 gears Detroit true track OME 885's Dakars Camburg UCA's Undercover SE Weathertech liners and visors Black headlight mod Debadged Rock Blokz mudflapps (oversized)
    Which bilstein 5160 did you use exactly? I noticed you have the stem to eye converter.
