GoFastCamper GFC Mods, Tips, and Tricks thread.
Discussion in 'Technical Chat' started by YOTA 4X4, Jan 1, 2019.
  1. Mar 12, 2021 at 11:22 AM
    #1481
    skier
    skier Well-Known Member
    Keith
    SW Colorado
    2016 red Tacoma DBSB TRD Sport manual
    1085
    fatfurious2[QUOTED] likes this.
  2. Mar 12, 2021 at 12:34 PM
    #1482
    Fetch-is-life
    Fetch-is-life Member
    Vandy – I'm in MT and have done quite a bit of testing on temps, detailed in my thread on the GFC forum.
    What panel color did you choose? The white goes a long way towards keeping things cool. I also installed a small solar overhead fan, which is helpful, but when everything is closed it struggles due to lack of intake. I'm considering adding intake vents on my panels for this summer.
  3. Mar 13, 2021 at 9:17 PM
    #1483
    JDR07
    JDR07 Well-Known Member
    Colorado
    2016 DCSB TRDOR
    Duct Tape
    Is that a 7ft garage you’re parked in?
  4. Mar 14, 2021 at 7:20 AM
    #1484
    skier
    Keith
    SW Colorado
    Slightly sho
    Not quite. It's an under-sized garage, called a 1.5 car size in a 1985 built condo. I've adjusted the door to max clearance and the beef rack has about an inch to spare.
    80.5" up to the top of the Beef Rack. Door opening is 81.75". Close
  5. Mar 14, 2021 at 11:32 AM
    #1485
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    Going on a 3ish month road trip this summer out of the GFC, so needed a little more comfort. I think this Exped Megamat 10 MW will do the trick. :thumbsup:
    Taccoma007, econwatch and PcBuilder14 like this.
  6. Mar 14, 2021 at 1:14 PM
    #1486
    hoarder23
    hoarder23 Truck fell over
    Shay
    NJ
    15 Pyrite Mica DCSB Sport
    Scratches
    It’s the tits, I probably would have froze on a single digit night with the stock mattress
  7. Mar 15, 2021 at 11:09 AM
    #1487
    ivanza
    ivanza Well-Known Member
    Bay area, CA
    2017 MGM TRD OR MT
    Mobtown skids Fox 2.5 DSC OME heavy leaf
    Hi all, I’m picking up a v2 soon and deciding between black or white for my MGM trd off road. Is there a noticeable difference in interior temperature between the two? I and surf daily and store surfboard during the day at work and it gets obviously toasty. I pop a side window open on my ARE Zseries at the moment.
    also, any suggestions for how to sell the cap? These things are quite heavy and awkward to transfer from what I’ve heard
  8. Mar 15, 2021 at 11:15 AM
    #1488
    d.shaw
    d.shaw Well-Known Member
    2012 Silver TRD-OR
    Vagabond Drifter, King 2.5 coilovers, King 2.5 rear, Pelfreybilt front / rear bumpers and skids, rock sliders, Safari snorkel, Smitybilt winch, Baja designs 20in, wide cornering spots, S2 rear. Deaver expedition series stage 3 rear leaf.
    as far as selling the cap, facebook marketplace or craigslist, or use the bay area for sale page on here (probably somewhere here :)
    https://www.tacomaworld.com/forums/northern-california.42/
    they are easy to transfer, takes a few people to lift them, 3-4 would work. its pretty simple.
    black, as it will look the best just my 2 cents thou. they all get hot, although someone did do some temp readings across different colors somewhere
  9. Mar 15, 2021 at 11:49 AM
    #1489
    Fetch-is-life
    Definitely a noticeable interior temp difference between black / white. I have white and still take precautions (parking into the sun, popping panels 1-2", roof exhaust fan) to keep temps down for my dog. The black panels I've seen got hot to the touch, which is something I've never experienced with the white panels. That heat transfers pretty directly to the air in camper. I have a friend who insulated their black panels but I think it's still a losing battle.
    From my GFC forum thread:
    Did some fan testing on a 70F day in full sun:
    • Fan on exhaust mode, everything sealed – 10+ degrees hotter than outside air, rising slowly
    • Fan on exhaust mode, panels closed but resting on closed latches to create small air gap (not driving, obv) – still slightly hotter than outside air, but stabilizes. Delta decreases significantly when truck is facing into the sun
    • Fan on exhaust mode, panels open, truck facing into sun – cooler than outside air
    d.shaw likes this.
  10. Mar 15, 2021 at 11:57 AM
    #1490
    Donkeythekidd
    Donkeythekidd Well-Known Member
    Beaumont, CA
    2017 MGM Tacoma TRD Off Road Double Cab
    Does anyone have just the Platform RTT installed? I haven't been able to find any pictures of one installed on a Tacoma. I'm thinking of ordering one to go on my short bed. I have a Snugtop rebel with the sportsman package so its reinforced along with the Prinsu top rack and cab rack. From what I can gather the mounting brackets will add 1" between the tent and the top rack. So that would raise it 1" off the cab rack and leave enough space for flex.
  11. Mar 15, 2021 at 12:43 PM
    #1491
    Kerbouchard!
    Kerbouchard! Well-Known Member
    Englewood, CO
    fishin' tank
    +1, def an easy process. In preparation for my GFC install I sold my shell on FB marketplace for about 200 less than I listed it for. The guy showed up with a friend. Me, my gf, and those two were able to lift and shift no problem.
    One thing to keep in mind--your buyer may not realize they need access to their bed rails. The guy that bought my shell still had his tonneau cover installed when he showed up. Removal is easy enough, but the very last bolt to the tonneau frame was stripped. His buddy ended up having to go to home depot to buy an easy out, chisels, etc., and then break the head off the bolt.
    Long story short...tell your buyer to come with an empty bed. It'll save you a few awkward hours of troubleshooting :thumbsup:
    d.shaw[QUOTED] likes this.
  12. Mar 15, 2021 at 6:12 PM
    #1492
    ivanza
    Bay area, CA
    2017 MGM TRD OR MT
    Thanks for all the responses guys.
    I’m going to go with the white camper. I kinda prefer the look as well on an mgm truck.
    All great points on selling the camper. I’ll keep all these in mind and sell it on Craigslist.
    Kerbouchard! likes this.
  13. Mar 15, 2021 at 6:14 PM
    #1493
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    I think that should look good with MGM.
    On my white truck, I am going to do a black camper. My aftermarket bumpers are white, so I think if the camper is white too, it will be too much white
  14. Mar 15, 2021 at 6:20 PM
    #1494
    Squeaky Penguin
    Brett
    Bummer they don't have a grey standard anymore. If it were me I would be tempted by the new grey, but understand not wanted to pay any more than you already have.
    The old grey on my MGM trucks looks pretty good IMO.
    fatfurious2 likes this.
  15. Mar 15, 2021 at 6:51 PM
    #1495
    Sunsetsearider
    Sunsetsearider Well-Known Member
    San Francisco
    2017 DCLB OR/1998 5 Lug
    Good to hear, I'm in the Bay Area with black on MGM. I would hate to get in your truck by accident someday. :D I've never noticed a heat issue. Even in Nevada, it seemed cooler than any fiberglass shell ever was.
  16. Mar 15, 2021 at 6:56 PM
    #1496
    fatfurious2
    David
    Ashburn, VA
    jim_bob's truck - white camper, black bumpers:
    My truck - white bumpers, future black camper with tangerine fabric. ( I dont have my Prinsu anymore either)
    Ive had a contractor cap on my truck a few years ago, and it just looks like a work truck. Something that I don't want to look like
    d.shaw and AY_ARONTRD like this.
  17. Mar 15, 2021 at 7:01 PM
    #1497
    AY_ARONTRD
    AY_ARONTRD Well-Known Member
    Aaron
    Murrieta ,CA
    2019 DCLB Cement OR 4x4
    Damn, that GFC sure does look nice on that truck.
  18. Mar 15, 2021 at 7:04 PM
    #1498
    fatfurious2
    David
    Ashburn, VA
    dont think its there anymore. I think he has a custom AT habitat now
    AY_ARONTRD[QUOTED] likes this.
  19. Mar 15, 2021 at 7:36 PM
    #1499
    desertjunkie760
    desertjunkie760 @DesertJunkie760 (IG)
    Shane
    2011 MGM DCSB TRD Sport 4x4
    Check My Sig.
    he’s got the new GFC camper with the Superlite on top to save weight.
  20. Mar 17, 2021 at 2:57 PM
    #1500
    hoarder23
    Shay
    NJ
    Scratches
    I should buy some Instagram followers so I can get new unreleased stuff too
    d.shaw and fatfurious2 like this.
