Going all LED lights
Discussion in '1st Gen. Tacomas (1995-2004)' started by ChrisCharles, Aug 17, 2022.
  1. Aug 17, 2022 at 12:08 PM
    ChrisCharles
    ChrisCharles [OP] Active Member
    North Carolina
    2003 Tacoma Prerunner
    Flowmaster 40, Deck plate mod,
    I know the turn signals will flash faster with LEDs.
    Is there any drawbacks from replacing all the lights with LEDs?
  2. Aug 17, 2022 at 12:13 PM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    Cheap LEDs don't last any longer than halogen bulbs, and anything other than halogen in the stock headlight is a down grade.
    Bivouac likes this.
  3. Aug 17, 2022 at 12:17 PM
    ChrisCharles
    North Carolina
    I didn't think running LEDs in the headlight was even legal if the assembly wasn't made for it.
    Looking at LED 1157 bulbs online. There must be a million different offerings. Are there any brands that are reliable? or are they all about the same?
  4. Aug 17, 2022 at 12:18 PM
    BudFriendguy
    BudFriendguy TRD BRGLR
    Zak
    Portland, Oregon >> Cleveland, Ohio
    2021 TRD Sport ACLB 4WD 6MT V6 Voodoo Blue
    As far as I know if you use a resistor, turn signals will not hyperflash.
  5. Aug 17, 2022 at 12:28 PM
    5efvz
    5efvz Well-Known Member
    I think you need to change out the flasher relay.
  6. Aug 17, 2022 at 12:30 PM
    ChrisCharles
    North Carolina
    I see the kits pretty cheap. I have LEDs in the rear now without a resistor and they flash a bit faster. When I add the front LEDs it will probably be fast enough to fail inspection.
  7. Aug 17, 2022 at 1:03 PM
    2004Taco
    2004Taco Financially Irresponsible
    Lou
    California
    04 Double Cab PreRunner SR5 TRD
