Going Alone - Single Vehicle Wheeling & Safety
Discussion in 'Off-Roading & Trails' started by Mxpatriot, Oct 3, 2016.
  1. Nov 14, 2016 at 12:36 PM
    #61
    tacot0wn
    tacot0wn Mia San Mia
    CO
    07 DCSB on 35s. Slowly becoming #EAF
    you been living under a rock? :laugh:
    661, la0d0g and DustStorm4x4 like this.
  2. Nov 14, 2016 at 12:42 PM
    #62
    Lux
    Lux @jamesgrouss
    James
    NJ
    2001 tacoma sr5 4x4
    OME 3" lift 881 coils, Dakar's 33" General Grabber AT2's TG low profile front bumper
    lol never really thought much of it honestly
    tacot0wn[QUOTED] likes this.
  3. Nov 23, 2016 at 3:42 PM
    #63
    jeeper
    jeeper Well-Known Member
    Some great info in here. Nice work!
  4. Dec 6, 2016 at 8:45 PM
    #64
    Mach375
    Mach375 Habitual Violator of Wheeling Rule #2
    Sathington "Alowicious Devadander Abercrombie" Willoughby (but you can call me Mud)
    '11 DCLB 4x4 TRD Sport
    Too much to list, but enough to get me in trouble. Repeatedly.
    Ah, there's the article I've been meaning to write, but never have the time to do so. Nicely done.
    As someone who has actually had to deploy a couple of levels of the Oh Shit Kit, I gotta say there's not a single bit of bad or superfluous advice here. (My situation? https://www.tacomaworld.com/threads/rescue-needed-anybody-near-ridgecrest-395.303269/ Old thread, so the pics may have expired, but I managed to get myself back on the ground, with no one around).
    Big key points are: 1) Calm down, evaluate the situation, and think it through before acting. 2) KNOW YOUR GEAR, and KNOW WHERE IT IS. The last thing you want to do when you're in a situation is have to remove the packaging and start reading the instructions. And YouTube videos don't count, either -- ya gotta get out and practice using the gear before you need it. 3) Stay calm. 4) Maintain your gear, rotating expired items as needed.
    If you have a mish-mash of stuff as you're putting together your gear, start an inventory sheet. Date every consumable item with a Sharpie.
    I'm kinda surprised you didn't mention an Israeli Bandage. Having very recently nearly torn my thumb off (roll-up garage door springs are no joke, especially when they explode while you're holding them), it was the Israeli Bandage and its quick application that made it so that I'm still 100% OEM with no missing parts.
    Landpirate, jubei and ecgreen like this.
  5. Dec 6, 2016 at 8:51 PM
    #65
    Mxpatriot
    Mxpatriot [OP] Well-Known Member
    '06 4x4 AP LT and Locked
    I did not go in depth on first aid, as that's an article on its own merit.
    Pressure bandages (Israeli dressings) and tourniquets are two great tools for controlling hemorrhage.
    GilbertOz and pra4sno like this.
  6. Dec 6, 2016 at 8:59 PM
    #66
    Mach375
    Anyone looking to put together a comprehensive gear assortment will rapidly run into storage issues. Be creative, and realize that our trucks have little nooks and crannies everywhere. Take it out of the packaging if needed. And don't ignore all that unused space in the engine bay -- I keep my air hose, spare belt, oil, trans fluid, brake fluid, stop leak, bailing wire, foil tape, zip ties, hose clamps, spare fuses, spare tire tools, and gobs more under the hood. Also, if you can figure a way to securely mount it, there's a fuckton of room under the truck.
    I highly recommend installing a roof rack and some Plano rifle boxes to carry extra stuff. The boxes are super-low profile, but have enough space to carry nearly all my emergency stuff. I have three boxes: 1: All my vehicle recovery gear, 2: Spare clothes and backpacking food, 3: Truck consumables (wire, tire plugs, rags, air line, parts [U-joints, tie rod ends {inner and outer!}] etc.). Don't forget to carry some means of cooking (and don't forget redundancy of fuel!).
    If you're going to run a ham radio, I suggest one that has APRS, which dedicates one side of the radio to GPS beaconing (can be used to send basic text info via email, SMS, or ham radio text; also allows tracking of your position for SAR recovery). The Kenwood TW-D710 is my pick......it's attached to a stand-alone GPS unit I can slip in my pocket and use on the trail.
    As OP hinted at, the shovel should be your first tool in which you invest. It's what you'll use most, and is usually the first line of recovery. And bonus: They're cheap!
  7. Dec 29, 2016 at 4:27 AM
    #67
    QMEDJoe
    QMEDJoe Proverbs 3:5-6
    Joe
    Columbus Grove, Ohio
    2003 Tacoma, V6, 5 speed, 4x4.
    Fox 2.0 Coilovers in the front and Fox 2.0’s in the rear, Total Chaos UCA’s, Al-lpro expo leafs, K&N cold air intake, TRD headers,Magnaflow catback exhaust,URD short throw shifter, switched out my 60/40 bench seat for some Tacoma Limited seats, Replaced the vinyl shift boot for a leather one, completely soundproofed the cab w/ Frost King. Replaced stock radio with a Pioneer AVH series head unit. Focal component system w/a 10" sub powered by 2 Alpine amps. Weathertech floor mats. Line-X'd the bed. SCS Ray 10’s, Installed an A.R.E. MX series camper shell. All-Pro Apex front bumper w/ All-Pro skid plates all the way back to the Trans. Low Range fuel skid plate.
    I will definitely be using this as a guide.Thank you sir! This thread may very well save my life some day. :thumbsup:
    BC Hunter and ecgreen like this.
  8. Jan 3, 2017 at 4:44 PM
    #68
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    And, IMO, you really shouldn't go into much detail online with this type of advice. You mention tourniquets, but people shouldn't use them to just stop the bleeding (a common misconception). Use one, and you're very likely going to loose that limb.
    I would suggest that everyone take a cpr, wilderness first-aid, or better yet, a wilderness first responder class. The knowledge you get is invaluable for anyone who recreates outdoors. Everything from simple lacerations to diagnosing (or clearing) spinal injuries are covered, and will save lives.
    WFA is a 16 hour course and is usually over a weekend. WFR is a 9-10 day course. NOLS offers many classes all over the place, but there are local places too. Check with an REI or similar place, they'll know where to look locally.
    Most of these courses even go into self first-aid as well, especially if you ask.
    idahodesert, BC Hunter and jubei like this.
  9. Jan 3, 2017 at 6:10 PM
    #69
    2000man
    2000man The Church Of @ODNAREM San Diego Chapter 1904
    G
    SDMF CA
    Shadow 4x4
    Awesome write up OP!!! Thank you! :bowdown:
  10. Jan 3, 2017 at 10:30 PM
    #70
    Mxpatriot
    You are working on 15+ year old information, which has been resoundingly proven false in OIF, OEF, and in domestic law enforcement / EMS.
    When direct pressure fails or is obviously inadequate to address severe hemorrhaging of a limb, a tourniquet is the correct answer.
    There is not a TCCC / CLS / LE / MIL first responder trauma class out there that does not teach tourniquet application, for a reason. I have applied tourniquets. I work with folks who have applied dozens of tourniquets. No limbs were lost, and lives were saved.
    This and this are good places to start reading on this subject.
  11. Jan 3, 2017 at 10:50 PM
    #71
    jbrandt
    Justin
    I'll grant you that my tourniquet info is probably old, it's been a few years since I was certified, which is why I stated YOU SHOULD TAKE A CLASS.
    I also never said you should never apply one. Applying one without proper training IS dangerous, regardless. I was simply cautioning people from going off and applying one when direct pressure would be more effective for a number of reasons, which could (and has) happened because some idiot read on the internet that tourniquets stop bleeding.
    Read my post again, I wasn't using rei as a source for medical info, but perhaps a place that might know where you can take an actual class. I even mentioned NOLS.
    Calm down buddy.
  12. Jan 3, 2017 at 11:04 PM
    #72
    Mxpatriot
    You are still putting out incorrect information, which is a great detriment to the general public who reads it and doesn't know any better.
    Tourniquets are not dangerous. Massive hemorrhaging is dangerous. If you find yourself in a situation where trauma occurred and you cannot control the bleeding with other means, a tourniquet is the answer - period. Training or no training - you are doing no harm by applying a tourniquet to a limb that you cannot otherwise control bleeding on.
    Nerve, tissue, and muscle damage are risks. They are minor in comparison to the risks associated with uncontrolled hemorrhaging and subsequent shock, particularly in first world nations where treatment in a medical facility generally falls well within the golden hour.
    Please read the links I posted above.
    BC Hunter, T2Flo, tacot0wn and 3 others like this.
  13. Jan 3, 2017 at 11:25 PM
    #73
    austinrauh
    austinrauh Well-Known Member
    Nevada
    05 AC OR
    We do a lot of this with wild land firefighting, we have to be self sustainable during full work weeks if we spike out, this process and preparation carried over into my truck for sure, aswell as being an emt, I carry some bls stuff in a quick to get box for myself, and others too if it comes down to it.
    But great write up!
    Sweet rig too!
    edit: in search of a box full of extra Sam splints for y'all, just have to remember where it is
  14. Jan 3, 2017 at 11:28 PM
    #74
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    So, lessons learned here, if I can't stop the blood use a tourniquet. :thumbsup: I thought everyone knew that?
  15. Jan 3, 2017 at 11:31 PM
    #75
    Mxpatriot
    Knowing is the easy part, making the judgement call in the field is a different story.
    The overwhelming lesson learned in the last fifteen years of war has been to err on the side of application. However, as visible in the last couple of posts, there are still many people out there that view tourniquets as a last resort that will likely result in loss of the limb - which just isn't true. This thinking results in hesitation to apply tourniquets, which causes preventable blood loss related injuries or death.
    BC Hunter, Pyrotech and NOLAMedic like this.
  16. Jan 3, 2017 at 11:37 PM
    #76
    VolcomTacoma
    Jeff
    NorCal
    No experience myself in it, but from my work Basic FA and CPR classes what I got from it was if direct pressure doesn't work, IE blood coming through the gauze within 2 minutes (iirc was the rough time they said) then a tourniquet may be needed. I'm not an expert in the matter in any way shape or form, but if I had to help someone, I feel I could do it. Might get sued in the end, but I'll damn sure try to save someones life if I'm the only one within shouting distance
    RedDemolisher and DustStorm4x4 like this.
  17. Jan 3, 2017 at 11:48 PM
    #77
    Mxpatriot
    I will preface this by saying the best preparation is quality training. That said, any level of preparation is better than no preparation.
    A CAT TQ (or two) in your vehicle and the knowledge you can get from this video series by North American Rescue on how to apply it will have you far more prepared than not having anything.
    Mike O, NOLAMedic, T2Flo and 3 others like this.
  18. Jan 3, 2017 at 11:50 PM
    #78
    VolcomTacoma
    Jeff
    NorCal
    Cheers! I've been slowly buying up FA and Trauma packs to have anything I could think of in case of emergency. Even if its something I don't quite know how to use (but I'm learning) hopefully there's someone there that does know how to use it and needs it. Adverse to this thread, I actually try not to go out alone all that often, for the very reason that I know I'm not fully prepared in the event of an emergency.
    DustStorm4x4 likes this.
  19. Jan 4, 2017 at 12:16 AM
    #79
    Kellan_s
    Kellan_s Well-Known Member
    Utah
    08 Access Cab
    Stuff.. and things
    :thumbsup: Awesome write up! Looking forward to using this as a reference for my own truck and adventures.
  20. Jan 4, 2017 at 5:46 AM
    #80
    gugman
    gugman analog
    bob
    Vermont
    wow very nicely done. great reference
