Going Alone - Single Vehicle Wheeling & Safety
Discussion in 'Off-Roading & Trails' started by Mxpatriot, Oct 3, 2016.
  1. Jul 27, 2019 at 7:05 AM
    #161
    MtnFisher
    MtnFisher Well-Known Member
    ZeroDrift
    2019 Tacoma TRD ACLB V6 MT
    Currently running Goodyear DuraTracs with "ghetto" wheels
    Thanks for the clarification, your PLB is a great choice.
    The ACR Resqlink is a proven device as well which requires very little effort from the user. The ACR rescue stories bear this out. Set the Resqlink with a clear view of the sky, flip the antenna and push a button. For an injured or disabled person it might make a difference?
    Either PLB is going to be better than nothing, that is the point I was making.
  2. Jul 27, 2019 at 9:23 PM
    #162
    Mxpatriot
    Mxpatriot [OP] Well-Known Member
    '06 4x4 AP LT and Locked
    Most certainly.
    I spend a lot of time in the Alaska backcountry - it amazes me how many people you find without a satellite messenger or PLB. They'll be in a $40,000 boat or a $20,000 side by side, but won't buy a $300 device that are absolute life savers in emergencies.
  3. Aug 13, 2019 at 9:41 AM
    #163
    nvnv
    nvnv Stop geotagging
    Connor
    2016 Tacoma TRD OFF ROAD
    Couple things-
    Inreach and PLB SOS signals don’t go to the same place. Inreach uses a private rescue coordination center (GEOS) whereas the PLB goes to the US Air Force Rescue Coordination Center, the same as EPIRBs on boats/ships and ELTs on airplanes. I don’t know if one is better than the other.
    In the case where the PLB coordinates were off by a mile, they were most likely using an old PLB that did not have GPS capability. Those beacons are located using Doppler (triangulation) and are not super accurate. New PLBs encode GPS coordinates into the SOS signal and offer the same accuracy as satellite trackers while also still being able to be tracked by Doppler and also transmitting on the old 121.5mhz freq that planes still monitor.
    Another thing to consider with PLBs is that they are going to be more reliable getting a signal out, there’s no denying that. They transmit on 406mhz which is going to be much better at getting through trees and rough terrain than satellite trackers that use the much higher 1.6ghz frequent. They also transmit at 5 watts vs satellite trackers that are going to transmit at only 1 watt.
    In a true life or death situation I would take the PLB.
  4. Aug 13, 2019 at 12:30 PM
    #164
    MtnFisher
    ZeroDrift
    Carry both if you can afford it and have the room.
  5. Aug 13, 2019 at 12:38 PM
    #165
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    Yeah, those old 121.5 ones are a PITA to track down sometimes. Actually harder in urban areas than in the bush. Less stuff to bounce off of.
  6. Aug 17, 2019 at 7:34 AM
    #166
    HB Taco
    HB Taco Well-Known Member
    Curt
    Huntington Beach, CA
    2019 F150 FX4 S Crew 3.5 TT
    :thumbsup:
  7. Sep 16, 2019 at 11:24 AM
    #167
    Cplfly
    Cplfly Member
    Kent,Wa
    2017 Tacoma access cab SR5,silver,4x4
    I learned the hard way, know the capability of your truck. 82 Toyo p/u, at the time and..."THINK" before you try to make it. I learned a atv trail is not made for trucks in the snow in winter. It looked wide at top but narrowed quickly[Alaska], no turn around, defiantly wasn't going forward,steeper hill, could not back up the snowy hill. fault...mine!! [ I got stuck in deep snow twice up there, digging out when it is 5-10degs out isn't fun] ......Carry the stuff talked about here,have fun... but THINK!! Can I really make it?, will I damage the truck/get stuck. How far out am I,do I want to hike out that far? There is no shame in backing out or turning around. The truck was very capable... going up power line roads [dry] 4L,gas mashed.. 4th,3rd,2nd,1st,gas mashed...bump...front wheels off ground..steering wheel spins full lock left [I learned NOT to have your thumbs inside the steering wheel,it hurts!!]..foot mashed........Made it!!.....It's fun but then you get the bill to fix things no so much......The 82 truck hit 2 trees left front,3 right front, a concrete pole, headlong into ditch,backed into 2 trees and 2 rollovers [1st in snow other dry conditions] the 2nd one was terminal. fault...mine.......Get out and have fun but THINK!..... I miss those days of really testing the truck,going where I want........... Got my new truck and my family said " your not going to do what you did to your other truck are you?....No..
    Stuck Sucks likes this.
  8. Sep 16, 2019 at 12:35 PM
    #168
    MtnFisher
    ZeroDrift
  9. Sep 16, 2019 at 5:02 PM
    #169
    steelhd
    steelhd Well-Known Member
    Eastern WA
    2011 DCSB TRD OR
    Never been a fan of those except in a "walk home bag". Even then I prefer a small folding saw or light camp axe/hatchet. In the truck and Jeep I carry bow saws because they can do a lot more work with a lot less effort. They take up more space but are flat so aren't hard to stow away somewhere.
    Hobbs and MtnFisher[QUOTED] like this.
  10. Sep 16, 2019 at 8:06 PM
    #170
    MtnFisher
    ZeroDrift
    I have a 21" bow saw too. I also have a compact Wyoming saw.
    The pocket chain saw is quick and easy for taking out brush that might be in the way next to the road if you get stuck. Wrap it around the base of the brush, pull back and forth. Less chance of breaking a blade.
    Never carried or mounted a dedicated axe in my 1st Gen, just a small hatchet. I'm going to dedicate an axe for my 3rd Gen since much more room. This forum has been helpful.
  11. Sep 17, 2019 at 6:40 AM
    #171
    TheJungleJesse
    TheJungleJesse Well-Known Member
    Denver
    2019 TRDOR 4x4, Previously 02 SC'd PreRunner TRDOR
    33's on SEMA wheels, Bilstien 5100s, CaliRaised Sliders, Clazzio Seat covers, Dionos
    Sounds like an episode of Top Gear. Would like to see a picture.
  12. Sep 17, 2019 at 2:43 PM
    #172
    Cplfly
    Cplfly Member
    Kent,Wa
    picture.jpg That's a total of what the truck went thru over the years,forgot to mention the broken leaf springs and bent steering stabilizer. I do have a pic's after the last rollover,I'll try to dig them up...............Back in my partying ,drink en day's. It was a good truck in Alaska for getting around ,9+ years.............. The first days I had it and the last day.....picture_002.jpg picture_006.jpg picture_005.jpg picture_003.jpg picture.jpg There was a canopy on it,three guy's in cab.....My buddy's think we went end for end,I think we did a peroet thing on the nose....... Logging road,power shift from 3rd to 4th...without lifting off gas, rear-end breaking lose, hearing the right front tire getting slammed into wheel well [a big rock and stump had a mark on it]..dust, twigs...gravel....ended up on the other side of road facing the other direction, luckily stayed on the road. [clear cut area]...............BART!!!...............Think!!..........It still ran,the fan was banging on something but it started right up.........................Found the pic of the first one [snow]. Beaver Creek, Yukon. Alaska Hwy
  13. Sep 17, 2019 at 3:51 PM
    #173
    steelhd
    Eastern WA
    2011 DCSB TRD OR
  14. Sep 17, 2019 at 4:19 PM
    #174
    Cplfly
    Cplfly Member
    Kent,Wa
  15. Sep 17, 2019 at 5:47 PM
    #175
    2Gtacosr5
    2Gtacosr5 Well-Known Member
    2013 double cab 4x4 sr5
    Front level kit, diff drop kit
    Yep, awesome thread OP.
  16. Sep 29, 2019 at 12:15 PM
    #176
    Richie Rich
    Richie Rich Toyota Hoarder
    760 (San Diego)
    2010 X-Runner 2011 TRD Sport DC 4x4
    More than I can afford
    Since I own them for work, have a grip of batteries and a charger that works with the inverter in our trucks, I carry a Milwaukee 18V sawzall, cordless impact, flashlight, 3-4 batteries, charger and an assortment of bits, blades and misc hardware. A pruning blade will go through a 10-12" branch with no drama.
    Have used them to clear fallen branches, gather/cut firewood and even built target stands when someone forgot to bring some.
    I also do carry an axe (Forrest Tool Company Max Axe) , hand chainsaw and a machete.
    Something I for sure need to bulk up on is first aid (both kit and knowledge). I have very limited first aid skills.
    MtnFisher[QUOTED] likes this.
  17. Sep 29, 2019 at 2:33 PM
    #177
    MtnFisher
    ZeroDrift
    Posted earlier, I picked one of these Stanley cooksets off Amazon just for the rig , this set is real compact and great for pairing up with one of the backpacking canister fuel stoves. I've carried a Snowpeak Ti cup with fuel and BP stove for many years but recently picked up another Titanium mug/pot for my son. Throw in some freeze dried BP meals and one can stay an unexpected overnighter if needed. Great for coffee too.
    Hobbs likes this.
  18. Nov 4, 2019 at 7:10 PM
    #178
    Sierra Trail Pro
    Sierra Trail Pro The more I play with it, the Bigger it gets!
    Kelly
    Cameron Park, CA
    2020 TRD Pro, Magnetic Grey Metallic
    Upgraded REM Polished 5.29 Revolution Gears Dobinsons 2.5 MRA/MMR adjustable remote reservoir front coilovers w/732lb springs, 35x12.5 BFG KM3 MTA tires on Moto Metal 16" wheels, incl. full size spare Bushmaster bolt on wheel well flares CaliLED full cab length DOM Steel Rock Sliders w/kickouts, Total Chaos welded spindle gussets, & LCA Cam Tab Gussets, Welded "Runnin 4 Tacos" Cab Mount Relocation Bracket, C4 Fabrication front steel hybrid bumper incl. heavy duty steel bumper support add-on's, C4 Fab Rear overland high rise steel bumper w/steel rear qtr panel wrap armor and side tube upgrades, 12k Smittybilt XRC Pro Comp Winch w/Factor 55 Flatlink Expert shackle mount assembly, Dobinsons heavy duty rear leaf spring pack, Timbren Off Road Racing bump stops (F&R), Fox 2.5 TRD Pro OEM rear monotube shocks, OEM Factory TRD Pro front aluminum skid RCI Steel skid plates (tucked in to factory engine skid)@ transmission, transfer case, lower A arms, and rear diff; CBI steel gas tank skid, ARB Twin Compressor in an M.O.R.E. engine bay mount, ARB Front Air Locker w/ Stainless Steel Air Lines Diode Dynamics 30" LED light bar @front bumper, RIGID front fog lights tied into factory wiring harness, Odyssey Group 31 AGM battery in a CBI Steel battery tray, Decked Slide-Out lockable Bed Drawer System, Yaesu FTM-400XDR HAM Radio (c/s:K6TOY), FreeSpirit Recreation "Evolution" Aluminum Hard Shell RTT w/Accessory Rails X2, FreeSpirit Recreation 270 Degree Swing-Out Self Supporting Awning w/Tent Mount Brackets, Cab Rack Mounted shower/changing tent, CBI corner to corner Steel Full Bed Rack, Prinsu Cab Rack w/extra rails, UpTop Overland upTAKE Snorkel (Functional & self draining), iPOD Bantam X touch screen switch panel control module, Dometic CFX3 95DZ Dual Zone Electric Refrigerator/Freezer w/dedicated electrical circuit & outlet, Dometic Refrigerator Slider Bed Mount, (4) 4 Gal Roto Pax Gas Cans w/locking Bed Rack Mount, MaxTrax Extreme Recovery Boards w/locking bed rack mount, Valley Runner custom ECU tune, TRD Advanced Cold Air Intake, Escort Radar Detector, hard wired w/RVM mount ALL K&N cleanable filter media installed, Only use Mobile One Full Synthetic Oil, changed every 5K miles, All Major Mods Professionally Installed
    This is a very helpful post, thank you!
  19. Nov 8, 2019 at 11:14 AM
    #179
    Stranger45
    Stranger45 Active Member
    Sevierville, TN
    A third GPS device is always on my wrist. I don't leave the truck without marking its location.
    Great post, and thread.
    How did you mount the tablet?
  20. Nov 9, 2019 at 12:02 AM
    #180
    nvnv
    Connor
    I took the wilderness first responder course through NOLS last year and it was awesome. They go in depth into most issues you will come across in the backcountry and it is a lot of practical hands on training. They also do a shorter wilderness first aid class that I’ve heard is good too.
    I think it’s one of the things most people miss. You can have the most badass rig with a stocked first aid kit but if you don’t have the training it’s worthless.
