going diesel
Discussion in 'General Automotive' started by feldman28, Oct 22, 2012.
  1. Oct 22, 2012 at 7:37 AM
    feldman28
    feldman28 [OP] Well-Known Member
    chris
    batavia
    09 sr5 stick
    So going to a diesel but I want the allison 1000 transit in the cummins. So what do you have or had experience with. I want 05to 07 CUMMINS cause I like that style and cause of straight axle. But love the drive train of Chevy. Going to trade taco in cause it won't pull new car hauler. Just stuck between the two.
  2. Nov 12, 2012 at 6:15 PM
    06TRDsport
    06TRDsport Well-Known Member
    Bend, OR
    2007 F250 Diesel and 1999 4Runner
    Do you plan to leave it stock or put a lift/bigger tires and tuner on it. Both the Dodge and Allison transmissions are weak links in trucks making noticeably more power than stock and running larger tires. Allisons have a decent reputation, but mostly on stock trucks.
  3. Nov 12, 2012 at 6:22 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Allison is good when beefed up a bit.
    The stock 1000 is maxed out with the stock Duramax LBZ. Transgo kit firms up the C3 actuation and bumps it another 50hp or so. More than that and it needs more work.
  4. Nov 12, 2012 at 6:24 PM
    Walker
    Walker Well-Known Member
    Walker
    Weippe, Idaho
    10 Trd OffRoad
    3" procomp, Light Racing UCA's
    04.5 to 05 dodge cummins were standard high output and had no emmisions equipment....with the 6 speed they are a great truck, i just traded my 05 with 60hp injectors, intake, exhaust and programmer and you put it in 4th and stomp on it and burn out, amazing power. If the injectors havent been replaced and your looking at one with over 100k it will be needing them soon. I would not buy one moddified, or with and edge juice, my truck was on its 3rd set of injectors at 96k
