Going extreme?
Discussion in 'Suspension' started by FLAtacoma05, Nov 7, 2009.
  1. Nov 7, 2009 at 4:21 AM
    FLAtacoma05
    FLAtacoma05 [OP] Well-Known Member
    Wes
    Crestview, FL
    2005 BSP Prerunner DBL Cab
    toytec spacers body lift 315/75/16
    i have a 2005 PreRunner DBL cab
    i want to have a total of 9" lift (preferrably suspension)
    quite possibly go up to 12"
    AND its strictly for show... no off roading
    ive heard so many otpions as far as TC spindles and coilovers and a body lift
    6" kit and body lift
    6" kit and coil overs
    WHATS THE BEST WAY:confused:
  2. Nov 7, 2009 at 5:16 AM
    paintdiddy
    paintdiddy Machine gun shits
    shithead
    nj and not from "the jersey shore"
    silver bullet
    x2
  3. Nov 7, 2009 at 5:38 AM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    the title says it all.:eek:
  4. Nov 7, 2009 at 5:40 AM
    paintdiddy
    shithead
    silver bullet
    i would do that big of a lift on a prerunner.
  5. Nov 7, 2009 at 9:00 AM
    anti
    anti Well-Known Member
    Johnson
    08 DCLB 4WD
    totally do this!
  6. Nov 7, 2009 at 9:02 AM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    x3
  7. Nov 7, 2009 at 9:03 AM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    i think getting into the 12" lift range youre talking custom work
    more than likely needing to convert to solid front axle and buy ridiculously arched lift springs or coils
  8. Nov 7, 2009 at 9:05 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    4" camburg spindles + 3" from coilovers = 7"!!
    body lifts...ehh look like crap
  9. Nov 7, 2009 at 9:22 AM
    THXEY
    THXEY Panda Jerk
    Jacob
    San Diego
    2013 Subaru WRX
    STi Short Shifter.OEM floor illumination kit. Rally Armor Mud Flaps. BC BR Coilovers. Invidia N1 Exhaust
    why for show?
  10. Nov 7, 2009 at 11:13 AM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    cuz any practical usage that high will likely end up with the truck upside down and the occupants in a helicopter on the way to a trauma center....
  11. Nov 7, 2009 at 11:17 AM
    mikesdoublecab
    Mohawk Mike
    Glendale, CA
    but yah, if you want to go that high, have the truck all show and a head turner, at least make it legit and go all the way to a solid axle suspension system and gain the extreme height by linking the truck front and rear with dual rate coilovers all the way around...
    figure between the suspension height and some 49" tires, you will be high enough off the ground to flip the truck over and accumulate a gang of citations from the local cops, but hey, at least the girls will be falling in line to give you a hand job, right?
    KIDDING...
    but yah, i vote you go solid axle and link it... that would be pretty pimp...
  12. Nov 7, 2009 at 6:31 PM
    FLAtacoma05
    Wes
    Crestview, FL
    I already have something to go runnnin in. This 05 is just a project and once im done ill be fgetting rid of it.
    i think im gonna do camburg spindles. 3.5" coilovers and 3" BL
    thatll give me 10 right with not too much travel left in the shocks...?
  13. Nov 7, 2009 at 6:45 PM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    How about you just give me the money your gonna waste... because this is A BAD IDEA!
  14. Nov 7, 2009 at 6:51 PM
    DanGer
    DanGer Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    When I read the title I thought of the "extreme" guys from harold and kumar. After reading the post, I realize you would fit in with them nicely!
  15. Nov 7, 2009 at 6:53 PM
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    SAve some money, go to Lowes or home Depot, buy a pressure treated 4x4 and cut 2, 10 inch sections satnd them up between the rear axle and leaf springs. Then for the front, get a nice 5 gallon bucket and use it as a spacer between the front struts and upper mounts. 9" of lift for under 20 bucks.
  16. Nov 7, 2009 at 6:55 PM
    FearNothing321
    FearNothing321 You gonna eat that taco?
    Tony
    Knoxville, TN
    2019 Audi S3
    :facepalm:
    why would you want that much lift?????? don't forget about drive-line angles, re-gearing, getting your speedo corrected...
    but in all honesty ditch the body lift and stick with the spindles and coilovers
  17. Nov 7, 2009 at 6:55 PM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    3 inch body is ok, but 6inch body makes severe axel bounce witch is deadly
    but imo 6 inch (total) is the highest you should go no matter what 9"-12" just screams i have a small penis and am trying to over compensate, plus it just looks like ass on a midsize truck
  18. Nov 7, 2009 at 6:58 PM
    THXEY
    THXEY Panda Jerk
    Jacob
    San Diego
    2013 Subaru WRX
    hahahah i know that... i meant like... why hahah i think its a waste of money :p
  19. Nov 7, 2009 at 7:07 PM
    mikesdoublecab
    Mohawk Mike
    Glendale, CA
    well, it's only a waste of money if you build it and let it sit in the garage...
  20. Nov 7, 2009 at 7:07 PM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
