Going from 17" stock rims to 16" on a Tacoma Sport. Is it possible?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PFD FIRE, Aug 28, 2016.
  1. Aug 28, 2016 at 10:26 AM
    PFD FIRE
    PFD FIRE [OP] Well-Known Member
    David
    San Diego
    2011 Toyota Tacoma TRD Sport
    265/75/16 Goodyear Duratrac Tires, Total Chaos UCA, Bilstein 6112 Coilovers (front) Bilstein 5100 (rear), TRD CAI, TRD Cat Back Exhaust, Rough Country/Lamphus LED lights, rear ARB locker, Baja Rack
    I drive a 2011 Tacoma Sport 4.0L 4WD dbl cab long bed. The truck came with 17" rims and I was thinking about upgrading to 16" rims. My question, are 16" rims compatible on my truck? I want to upgrade my rims to the pro comp la Paz 29 series rim 16x8. The online dealer (Autoanything.com) tells me that there not compatible because the calipers on my Tacoma sport will rub. Any advice out there?
  2. Aug 28, 2016 at 11:41 AM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    It depends on the wheel and how much space there is between the wheel and the caliper.. Some 16s will fit, and some not. I have pro comp 7089 in 16s.
  3. Aug 28, 2016 at 2:16 PM
    Fitz235
    Fitz235 Well-Known Member
    Rob
    New Hampshire
    Black '22 DCSB TRD Offroad 4WD
    - TRD T4R Pro Wheels - TRD Lift Kit - TRD Skid Plate - 265/70/17 Toyo Open Country 3's - OEM Bed Lights - OEM Bed mat - Alpharex Tail Lights - TacomaBeast LED Interior Lights - Green Lane Offroad Aluminum Sliders - Place Holder for More Bad Financial Decisions...
    Enter before, and after specs here: This will take away the mystery.
  4. Aug 28, 2016 at 2:56 PM
    HolyHandGrenade
    HolyHandGrenade NOOB
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    It's possible. I running 16x8's
  5. Aug 28, 2016 at 3:03 PM
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    A few major variables :
    1. Backspacing, a lot of guys with 16's have to run spacers.
    2. If you are ever going to gusset your spindles 16's will not fit without spacers unless you have a crazy deep negative offset.
    3. Big brake kits - if you are going to add 2000lbs of shit to your truck like most of and may want to get a big brake kit you must stick with 17's.
    4. Tires available - really deep dive into what tire sizes are available for what size rims. You don't want to be forced into a specific tire because it is the only one in the size you need.
