going from 245 to 265
Discussion in 'Wheels & Tires' started by emacpgh, Aug 27, 2009.
  1. Aug 27, 2009 at 8:38 AM
    emacpgh
    emacpgh [OP] Well-Known Member
    eric
    pittsburgh
    silver streak mica sr5 sport
    Aries stainless steel bull bar , afe pro dry s filter , secondary air filter removal, scangauge II
    how much power and mpg can i expect to lose going from 245 /75/16 to 265/75/16 tires? i have the 2.7 4x4 if that makes a difference . thanks
  2. Aug 27, 2009 at 8:40 AM
    98tacoma27
    Ben
    Not Beech Creek
    Some where between none and too little to even notice.
  3. Aug 27, 2009 at 8:54 AM
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    1-2 mpg
  4. Aug 27, 2009 at 8:58 AM
    emacpgh
    eric
    pittsburgh
    cool , thanks. just wanted to fill up the wheel well a little bit more w/ out lifting. can you suggest a reasonably priced at tire. i dont do much off roading, but weather here in pittsburgh can get shitty. prob 80% blacktop driving 20% gravel/dirt.
  5. Aug 27, 2009 at 12:58 PM
    Taco-NB
    Taco-NB MMMMM Taco's
    New Brunswick
    '09 4X4 SR5 Access Cab V6 - Black Sand Pearl
    Is that the largest size tire you can go to without doing a lift?
    Will you need to cut any of the wheel well?
    Cheers.
  6. Aug 27, 2009 at 1:01 PM
    DanGer
    DanGer Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
  7. Aug 27, 2009 at 1:07 PM
    98tacoma27
    Ben
    Not Beech Creek
    No.
  8. Aug 27, 2009 at 1:10 PM
    007Tacoma
    007Tacoma I dub thee malicious!
    Mark
    San Antonio, TX
    2015 4Runner Trail Edition Premium
    Cloaking Device
    I lost 3 MPG going from 245 to 265 in my 2007 PreRunner 2.7L (sold that truck).
  9. Aug 27, 2009 at 6:17 PM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    24 Tundra Trd Sport former 13 TRD OR
    Stock for now
    265s are wider than 245s (first number is width). The second number is how tall a tire is.
    265/75/16s would fill your wheel well more.
  10. Aug 28, 2009 at 10:02 AM
    emacpgh
    eric
    pittsburgh
    really !! three mpg 007 ? think i will stick with the 245s. i love the look of the bigger tire but, if your losing 3 mpgg your prob losing some hp/torque also. cant afford to lose any power in the 4banger. love the efficiency of the 4 and the mt allows for a little get up when you really need it, but it is a thin line. thanks.
  11. Aug 28, 2009 at 10:10 AM
    CometKat
    CometKat Well-Known Member
    Carson City NV
    08 Tacoma 4X4 Regular Cab SR5
    Go with a 265/70R16. The tire is the same height but wider. Going taller would be a big mistake since the gearing is already too tall on these trucks. I’m thinking of going with a 255/65R16 next time to shorten up the gearing and make 5th more useful.
  12. Aug 28, 2009 at 10:13 AM
    emacpgh
    eric
    pittsburgh
    do you think the mpg loss is attributed more to the widening of the tire or the heightening of it? or do they contribute equally. can i get a higher tire without the width. cant recall ever seeing something like 245/85/16. prob wouldn't be stable enough. my priorities are 1. safety 2. efficiency 3. performance 4. aesthetics
  13. Aug 28, 2009 at 10:17 AM
    emacpgh
    eric
    pittsburgh
    you answered my question while iwas typing . thanks kat . you must have espn . lol
  14. Aug 28, 2009 at 10:21 AM
    98tacoma27
    Ben
    Not Beech Creek
    It's attributed to width (= more traction = more friction) and the height (= more weight). It really isn't that much of a loss.
  15. Aug 28, 2009 at 10:47 AM
    CometKat
    Carson City NV
    Here is a useful website where you can play around with different tires sizes for comparison to your stock tire. It gives the speedometer error also when straying from stock. Personally I like a wider tire vs. a taller tire from the aesthetic point of view. If you go wider just make sure the rim can handle it.
    http://www.discounttire.com/dtcs/infoTireMath.dos
  16. Aug 28, 2009 at 10:59 AM
    4cyltacoma
    4cyltacoma Well-Known Member
    Reagan
    Fresno, Ca
    06 Tacoma SR5 4Cyl 4x4
    AFE CAI, Black Housed Headlights, In Channel Window Visor, Bug Deflector, Black Side Step Tubes, Blacked out emblems
    i when from 245/65/16 to 265/75/16 and didnt really nocticed any milegae drop or no power loss. it still feels the same for me except that its a litttle wider tire which is aewsome
  17. Aug 28, 2009 at 11:12 AM
    98tacoma27
    Ben
    Not Beech Creek
    There is one on this site also. It's in the mod's/tutorial drop down menu.
    http://www.tacomaworld.com/forum/tirecalc.php
  18. Aug 28, 2009 at 11:51 AM
    CometKat
    Carson City NV
    The stock tire size is 245/75R16 (the Dunflaps) or 265/70R16 (the Rugged Fails). I think the I4 has acceptable power but I wouldn’t want to do anything that would compromise what power there is. So there’s no way I’d go with a taller tire. But a slightly wider tire would not make a difference. A shorter tire like a 255/65R16 would actually make the truck a little quicker.
  19. Aug 28, 2009 at 4:26 PM
    4cyltacoma
    Reagan
    Fresno, Ca
    well i dont really need the speed cause my truck is a 4cyl 4x4 so its got alot of weight and a little slow. im not to picky and my ride is a little higher do to the 265/75/16, but if i do go for some speed ill might consider the 255/65/16. thanks..:):)
  20. Aug 28, 2009 at 4:35 PM
    ttylerr
    ttylerr Well-Known Member
    Tyler
    Fort McMurray, Alberta
    09 MGM 4Banger 4x4
    5% tint all around, Alpine IVA-W505, 16x8 Mojave Teflon Rims w/Hercules Terra Trac 265/75, Grillcraft Grill, Slimcubby HIDs, Front 5100's @ 0 w/Eibach 1.6" springs, URD Short Shifter, Extang Trifecta Tonneau Cover, Uniden Pro510XL and K30Mag Mount, Relentless Fab Bumper soon to come
    i'm running 265/75's in my 4cyl, cant notice much of a performance difference but according to the scangauge i've lost almost 3mpg average... kinda shitty, but they do look a lot better.
    i'm running hercules terra trac a/t's they were $155CDN a piece.
