Going from 265 Cs to 285 Ps
Discussion in '4 Cylinder' started by maxpower29, Oct 2, 2012.
  1. Oct 2, 2012 at 5:32 PM
    maxpower29
    maxpower29 [OP] Well-Known Member
    Jordan
    Nova Scotia, Canada
    2011 Tacoma 4x4 2.7 5 speed SWB
    All season mats, 2nd filter delete, DT header, Jardine cat-back, URD shifter, Bilstein 5100's all around at .85 front with Eibachs + .25 passenger/.5 drivers spacers and 1.5 AAL, 0w20 synthetic, Scanguage II, extra D rings, OEM backup camera+Mirror, bed mat, Extang Solid Fold, Popnlock 5300, Pro Comp 7089's 4.5bs 285/70/17 Revo 2s, De-badged
    I know a lot of people ask these questions so I will chime in with my tire swap today.
    Today I went from 265/70/17 BFgoodrich ATs C rated to 285/70/17 Bridgestone Dueler Revo 2s P rated.
    Right off the bat the noise is WAY lower, the drive is 10 times smoother, and the truck keeps momentum a lot easier then the BFs, so Im guessing I will see an easy 1 or more better MPG when this tank is finished.
    The power seems the exact same, nothing I didnt expect because the BFs weighted 45.75lbs and the Revos 46lbs. So the same there.
    All around driving though the truck is so much smoother going back to the P rated tires it started with. Some people will say they are not tough enough, but yet they have a max weight of 2864lbs (or close to it) per tire and the BFs only have a 2650 or so. So really I should be able to carry more with these.
    I did NOT have to regear, and nor will I because I dont feel the need. I have plenty power and can do whatever I did before.
    I have very happy I went with the Revo and cant wait to drive it more and see how it works in other conditions. I will update when I use it more
  2. Oct 2, 2012 at 5:34 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Maybe it has to do with your alignment
  3. Oct 2, 2012 at 5:40 PM
    maxpower29
    Jordan
    Nova Scotia, Canada
    I dont think, its less rough and not hard hitting bumps now
  4. Oct 3, 2012 at 6:41 AM
    shemp
    shemp Well-Known Member
    What pressure did you have in the old tires? What are the new ones inflated to?
  5. Oct 3, 2012 at 6:46 AM
    maxpower29
    Jordan
    Nova Scotia, Canada
    not sure of the old ones, but I assume to the normal specs. I will check mine later
  6. Oct 3, 2012 at 12:50 PM
    shemp
    It can be dangerous to make assumptions. Without knowing these details, it is hard to properly attribute the difference in the ride. If you happened to be running way over-inflated with the old tires and are now at a more reasonable pressure, that could have a major impact. In fact, it could be vastly more than the difference between the tires themselves.
    An unfortunate problem with having "someone else" manage tire inflation (which is what your response suggests), is that there is a very high chance that they inflate to what is written on the sidewall instead of the proper spec. In the case of a "C" tire, that would probably be 50 to 55 psi. Proper inflation is about 30.
    A dedicated tire shop will be more likely to follow the proper spec for the vehicle than, for example, a gas station, so I would imagine that they are now somewhere around 30.
    In any event though, the main point is that you are happy with them as they are now, and their limits are well above the limits of your truck, so there is no problem with capacity.
  7. Oct 3, 2012 at 1:16 PM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    Or the Toyota dealer did that to me once on my 285/75/16 Bfg load E they filled them up to 50 psi I was like what the fuck
  8. Oct 3, 2012 at 1:43 PM
    maxpower29
    Jordan
    Nova Scotia, Canada
    Ya I will double check. But I'm sure these are at the right psi. They just make the truck feel back to stock. I like that feeling
  9. Oct 21, 2012 at 6:43 AM
    DPR921
    DPR921 Well-Known Member
    Dylan
    Cheshire, MA
    08 SR5 4x4 2.7
    any update on what your getting for mpg?
  10. Oct 21, 2012 at 11:02 AM
    maxpower29
    Jordan
    Nova Scotia, Canada
    Still getting good numbers. 23.5-24 the last 2 tanks. I usually am anywhere from 22-25
