going from a 10" to an 8"
Discussion in 'Audio & Video' started by IDtrucks, Dec 5, 2011.
  1. Dec 5, 2011 at 11:16 PM
    IDtrucks
    IDtrucks [OP] Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    so i want to keep both back seats in my new truck, that means i would have to swap my kicker 10" with a 400w amp for an 8" (powered by the same amp) so i can fit it in the cubby hole under one of my seats. For the people who have had 10s and 8s will it be a depressing shift with a huge loss of bass, or if i get a decent 8" that can take the mono 400w sub will it not be too bad of a switch? thanks!!
  2. Dec 5, 2011 at 11:30 PM
    MY50cal
    MY50cal - IPFK -
    Mojo
    Chester County, PA
    09 PM RC / 05 SWB AC (RIP)
    Yep.
    paging ItalynStylion...
  3. Dec 6, 2011 at 5:27 AM
    XJBaylor
    XJBaylor Well-Known Member
    Keith
    Plano, TX
    06 DCLB TRD Sport 4x4
    King coilovers with remote reservoirs, Deaver 12 leaf pack with 5100's, TRD exhaust, Kenwood 6160, Anthracite Sport Wheels
    There are way too many variable to say without more information. In the end, a bigger speaker (all other things equal) will play louder and lower. But all things are never equal. One of the most important variable would be the enclosure. Was your old enclosure well designed for your sub? Was it ported or sealed? Can you you find a sub that plays well in the enclosure you will be installing?
    Other variables will include the sensitivity of the new sub, the quality of the installation and the impedance (was your old sub 4 ohm, can your amp power your new sub at 2 ohms?)
    You will likely lose a significant amount of volume, simply because (and I am just guessing) you are going to be going to a very small sealed enclosure to fit it into the cubbyhole. Just make sure you know the size of your new enclosure, and find a sub that models well in that airspace. You should still be able to create a system that you are happy with, and have some extra room in the cab.
  4. Dec 6, 2011 at 5:51 AM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    ^Good advice for sure.
    A ported 8 should do well with regard to keeping up with a sealed 10. So if you can port, absolutely do it. Try and find something with a higher sensitivity and good Xmax. I think the JBL GTO 8's are pretty good with both of those in mind.
    What kind of space do you have to work with? What are your plans for an enclosure?
  5. Dec 6, 2011 at 6:13 AM
    mattg43
    mattg43 Well-Known Member
    Texas
    08 Prerunner SR5 DC
    SwingCase, driver side. PVC Bike rack. Aftermarket stereo.
    If you are talking a 1st gen, and using the little cubby under the seat with an 8 vs a 10 on top of the seat, you will have to do some compromising.
  6. Dec 6, 2011 at 10:30 AM
    06SR5canada
    06SR5canada Well-Known Member
    Saskatchewan
    06 dblcab SR5
    2ndary air filter removed, flowmaster 40
    Just cuz a sub is smaller dosent mean it will have less output. They have single 8s hitting over 150dbs now
  7. Dec 6, 2011 at 1:39 PM
    XJBaylor
    Keith
    Plano, TX
    True. I guess. However, he also stated that he is installing the 8 in the cubbyhole below the rear seat. How many 8" subs do you know of that can hit over 150db in a (very) small sealed box with 400w behind them?
  8. Dec 6, 2011 at 1:51 PM
    ItalynStylion
    Steven
    DFW, Tx.
    I sat here and calculated that you'd need a sub with 120db efficiency to get 150db on 400watts. Then I remembered cabin gain....IDIOT...brain fart lol
  9. Dec 7, 2011 at 4:36 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    ya i know im going to lose some, just wondering how much.
    i dont think i need the highest end top of the line 150 db 8" i can get. So whats the populous's recommendation for an 8"? i dont know the dimensions of the cubby but anyone thats seen the 1st gen xcab knows what im talking about and might be able to give an idea. Also incase there was any confusion it would be the bigger of the two cubbys, just sayin.
  10. Dec 7, 2011 at 4:46 PM
    jtav2002
    jtav2002 Kenny Fuckin Powers
    Josh
    Reading, PA
    2013 Tundra DBL Cab TRD OR
  11. Dec 7, 2011 at 6:00 PM
    mattg43
    Texas
    08 Prerunner SR5 DC
    If I were looking, I would be between the JBL GTO804, or the Alpine Type R 8. Let your budget decide, but I have doubts you would be disappointed with either.
  12. Dec 7, 2011 at 6:58 PM
    XJBaylor
    Keith
    Plano, TX
    Agreed. The Alpine will run you around $100, the JBL can be had for around $70. If you look at the threads on other forums the Alpine is considered by many to be one of the best 8" subs available. The JBL is probably the single best bargain in subs, and I can't remember hearing a single complaint. I have never heard one personally, but I have heard great things. There may be something comparable from Parts Express, but outside of that I don't think anything compares.
    Nothing wrong with the JL 8", but I don't think it is the best bang for the buck either.
  13. Dec 7, 2011 at 11:38 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    the apline looks great, and even its above my power level. the amp in only a 400 with 200 rms,
  14. Dec 8, 2011 at 5:27 AM
    XJBaylor
    Keith
    Plano, TX
    From what I understand, the Alpine requires a lot of power (350+) to really sing.
    You didn't state what amp you have, but if it is stable at 2ohms you might consider going with a sub that has dual 4ohm voice coils. You could wire then wire it to 2ohms and likely get a little more out of your amp. The Polk MM840 and Alpine SWR-843D are both DVC subs with 4ohm voice coils. Alternatively, I think the JBL would still sound amazing with 200 watts behind it.
    What is the model number of the amp you are currently using?
    EDIT: I actually see you mentioned mono in your first post, though not explicitly stating you have a monoblock amp. If that is the case, it will almost certainly be stable at 2ohms, and less resistance could help you maximize your current amp.
  15. Dec 8, 2011 at 6:13 AM
    mattg43
    Texas
    08 Prerunner SR5 DC
    If you are at 200rms, go with the JBL. I would go to the Type R with 400w available.
    RMS, not peak or max watts.
    And FYI - Amazon has the JBL for $55 shipped, and they are authorized last I checked.
  16. Dec 8, 2011 at 8:46 AM
    ItalynStylion
    Steven
    DFW, Tx.
    Agreed, the JBL is actually quite efficient for an 8 (which is almost an oxymoron). If you can squeeze 400RMS at 2ohms out of that amp, like Keith said, get the type R in a dual 4ohm coils.
  17. Dec 8, 2011 at 10:04 AM
    Cinco
    Cinco Team no taco
    Jose
    Rio Rancho,NM
    2012 Civic Ex Coupe
    As stated above. I really loved the JBL GTO 8s I had a few years back. Very efficiant and great sounding. I do have a Type R I have been playing with and that thing is a monster. That sub is worth all the hype. For the money you cannot find a better 8in then the JBL. NOTHING at the price point will beat it.
  18. Dec 9, 2011 at 12:54 AM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    alright, jbl it is then! thanks for all the help!:D
