Going from a 1st gen Tundra to a Tacoma?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by The tundy, Oct 18, 2018.
  1. Oct 18, 2018 at 1:25 PM
    The tundy
    The tundy [OP] Member
    Gavin
    Hey I’m new to this forum and now I currently own a 2001 Toyota Tundra limited with a 4.7 liter v8. Love the truck. The other day the rear differential failed on me at 225k miles I haven’t gotten to look into it yet so I don’t know what the damage really is yet. Basically I’m going back and fourth on what to do I love the truck like I said and I’d love to keep it but a new Tacoma is temping. Basically what I’m looking for is if anyone has any experience coming from a first gen tundra to a third gen tacoma and what your experiences were. Thank you
  2. Oct 18, 2018 at 1:34 PM
    LivinOnEdge
    LivinOnEdge ¯\_(ツ)_/¯
    Land of The Lost
    Four wheels and a refrigerator
    Biggest selling point is how much power you need. Although the Tacoma is a beast, it still has no where near the same towing capacity as a V8 full size. What are your needs?
    Rogues Gambit, MCCM and RIDER34 like this.
  3. Oct 18, 2018 at 1:43 PM
    11Bravo4x4
    11Bravo4x4 Well-Known Member
    Mitchell
    2018 Tacoma off road 4x4 quicksand
    Agreed with above. I would also factor in space. In the tundras you have space for days. In the taco it can be limited. Depends if you have a big family and haul them often. I would get tundra. In my case I got a taco because it’s just me and my wife for now. Otherwise I did want a tundra. Will get one in the future though
    Rogues Gambit likes this.
  4. Oct 18, 2018 at 1:45 PM
    RIDER34
    RIDER34 Well-Known Member
    16 Inferno SR5, 18 magnectic gray SR5 4x4
    2 different trucks, as LivinOnEdge stated above, all will depends on your needs.
    Few things that might help, you get much more truck for the money in the Tacoma, a 40k Tundra its naked compared to a 40k tacoma.
    Tundra is to big of a truck for trails, overlanding, offroading, fuel efficiency etc etc.
    If you are in to towing campers, heavy loads the Tundra will fit your needs.
    Again everything will be on your personal needs.
    Good Luck.
  5. Oct 18, 2018 at 1:46 PM
    SportsmanJake
    SportsmanJake Well-Known Member
    VA
    2006 Tundra
    Reading comprehension on TW is low.
    1st gen Tundra and 3rd gen Taco have comparable tow ratings.
    Op's 1st gen tundra will be very similar in size to a 3rd gen.
    Op is asking about his 1st gen tundra. You are confusing it with a 2nd gen.
    Snaeper, R490, Lawfarin and 3 others like this.
  6. Oct 18, 2018 at 1:46 PM
    jerryb1984
    jerryb1984 Well-Known Member
    Jerry
    2018 DCLB TRD OFF ROAD
    16x8 FUEL BEAST 265 75 16 FALKEN WILDPEAK AT3 Tyger step sides 20% tint front to match factory tint bilstein 5100s on third notch PRO grill
    The 2001 tundra will actually be similar size to the new Tacoma’s. The new tundras are way roomier but coming from an 01 it will be similar. As stated above, if you don’t need the v8 in the tundra the Tacoma may work better. The tundra gets about 14 mpg and the Tacoma 18-20. Depends what you need to do with the truck
    SportsmanJake likes this.
  7. Oct 18, 2018 at 1:53 PM
    SportsmanJake
    VA
    2006 Tundra
    Not my chart, but still helpful when comparing dimensions.
    3rd gens with the Tow Package is closer to 6800 or something.
    OP, I saw fix your Tundra and keep driving it. The 3rd gens are very nice though. The interiors alone are so much nicer.
  8. Oct 18, 2018 at 1:53 PM
    LivinOnEdge
    Land of The Lost
    But hes not going to buy another 2001 Tundra (or maybe he is IDK). I'm taking into consideration hes going to be buying a newer vehicle.
    SportsmanJake[QUOTED] likes this.
  9. Oct 18, 2018 at 1:54 PM
    phsycle
    phsycle Well-Known Member
    CA
    Unless you need the V8 pulling power, Tacoma is a nice upgrade. Take your truck to the dealer and drive them back to back.
  10. Oct 18, 2018 at 1:54 PM
    black coffee
    black coffee A is A.
    Glenn
    509
    2010 AC 4x4 SR5 V6
    Can’t you repair the rear axle?
    The 4.7 V8 has quite a bit more torque than the 3.5 V6.
    shakerhood likes this.
  11. Oct 18, 2018 at 1:59 PM
    The tundy
    Gavin
    Honestly I have never used my tundra to it’s full potential. There’s not a single thing I have done with my tundra that the Tacoma wouldn’t be up for. Basically I own a v8 because I like the low end power and piece of mind I can pull anything I’ll ever need to but with the amount I drive averaging 15 mpg just really doesn’t make much sense anymore.
  12. Oct 18, 2018 at 2:01 PM
    LivinOnEdge
    Land of The Lost
    The 3rd Gen taco will get you roughly 16 in the city and 22 on high ways. You'll love everything about it if your not too picky about seat cushion and the finicky transmission.
    The new Tacomas are also just under the same width as your old Tundra. Mid size vehicles have become near full size in the past 10 years.
    Thegenerik1 likes this.
  13. Oct 18, 2018 at 2:03 PM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    I went from an '04 Tacoma to an '06 Tundra (last year of 1st gen) to an '09 Tacoma (2nd gen, not a 3rd gen, but similar enough in size). My Tundra was a double cab and I found it huge, but I was not used to full size trucks. I had no need for a full size, really, it was just cheaper than the Tacoma at the time so I thought what the heck. Great truck, just way bigger than I needed. I have 2 kids, and they fit fine in the Tacoma. Adults not so much, so if you are hauling full-size passengers a lot, the Tundra would be more comfortable for them.
    As others have said, depends mainly on your needs, but also what you are used to. If you are used to driving full-size trucks, you may find the Tacoma a bit cramped. If you find the Tundra a bit big for your needs, you should be fine.
  14. Oct 18, 2018 at 2:06 PM
    Virginian
    Virginian Well-Known Member
    Raleigh, NC
    2017 Tacoma Double Cab TRD Off Road
    I came from a 2003 Tundra Limited Step Side that I had for 13 years. Loved that truck, but was having some issues, so I traded for a 2017 TRD Off Road Double Cab last year. The new Tundra was just too big and the new Taco felt just right. To each his own of course. I test drove the Sport first and didn't care for the ride. Took the Off Road on the exact same drive and felt it was right for me. And I'm really spoiled by all the new tech stuff, particularly the back up camera.IMG_0004.jpg
  15. Oct 18, 2018 at 2:19 PM
    The tundy
    Gavin
    I’m going to replace it but it’s almost an 18 year old truck with almost a quarter million miles. Even though it’s running and driving strong I don’t wanna have something else possibly go wrong soon and have to put more money into an old truck. Although that torque is nice i really don’t need all of it
  16. Oct 18, 2018 at 2:23 PM
    LivinOnEdge
    Land of The Lost
    You could also pay a reputable mechanic in your area to do a multi point inspection and try to scope out any other concerns that may effect you in the future. Old Toyota trucks just don't die. You might want to invest in the tranny fix. 225k miles, you just broke in your truck, it's nowhere near out the door.
  17. Oct 18, 2018 at 2:24 PM
    LeftCoastNerd
    LeftCoastNerd Old 'nuff to know betta
    Santa Cruz, California
    08 AC 4x4 OR 6sp
    that comparision table is pretty misleading. tow capacity for a 4x4 v6 tacoma is considerably higher than 3500 lbs. payload varies with standard/access/doublecab, and 4x4 vs 2x4 vs 'prerunner'..
    one thing to note, the 3.5L V6 in the 3rd Gens, you gotta really rev them up for the power, there's more low end torque with the 4.0 in the 2nd gen.
  18. Oct 18, 2018 at 2:38 PM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    The trucks are very comparable in size and probably tow about the same. Tacoma isn’t going to have the bottom end and the torque feel that the old tundra has. Everything else should be better with the Tacoma just because it’s alot newer. That said it comes down to finances. Would you rather dump a few grand into the tundra or 30-40k on a new Tacoma? Pick your poison
  19. Oct 18, 2018 at 4:20 PM
    black coffee
    Glenn
    509
    2010 AC 4x4 SR5 V6
    Some money into an old Tundra repairs as opposed to the price of a 3rd gen?
    225K wouldn’t worry me much if I knew the history. There are plenty of folks with more than 225K on their Toyotas. I was one of them at one point.
  20. Oct 18, 2018 at 4:56 PM
    Invid
    Invid Well-Known Member
    New Braunfels, Texas
    2016 Tacoma Limited
    I went from a 2002 Tundra AC V8 to a 2016 Limited and I am still loving the decision. The technology alone is worth it but overall I feel it's a much better truck. Despite the "power issues" which people complain about this is a superior vehicle.
