Going from a spacer lift to a coilover lift.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Traps, Sep 29, 2023.
  1. Sep 29, 2023 at 3:37 AM
    Traps
    Traps [OP] Member
    Terry
    2019 Tacoma SR5
    6 inch BDS lift
    Need some help here. So I bought my 2019 Tacoma. And it had a BDS 4inch Spacer lift. I didn't install. I can't find a 4 inch coilover lift to replace the spacers. And 4 inch lift leaf springs to replace the 4 inch lift blocks. Can I drop to a 3.5 inch lift ? Say from Rough Country? I also have the differential drop. And extended steering knuckles that came with the BDS lift kit. Am I cursed? Any info would be appreciated.
  2. Sep 29, 2023 at 3:54 AM
    BillyE
    BillyE Well-Known Member
    You could go to a 3.5” lift and it should be fine. Another option might be to stack a block on top of the coil over you want, to achieve the 4” you currently have.
    Traps[OP] likes this.
  3. Sep 29, 2023 at 3:59 AM
    Traps
    Traps [OP] Member
    Terry
    2019 Tacoma SR5
    6 inch BDS lift
    Any info I've researched on after market coilovers. Everything says "Do not use with spacers" One reason would be.. it decreases your up travel within the shocks.And you could damage them. But..its only half an inch.
    I am thinking the same as you on the 3.5 inch conversion. I don't think the axle angle change. Would even be noticeable..
  4. Sep 29, 2023 at 4:40 AM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    Is it a diff drop, or is cross member cut and new (aftermarket) installed? Guessing later.
  5. Sep 29, 2023 at 4:42 AM
    Traps
    Traps [OP] Member
    Terry
    2019 Tacoma SR5
    6 inch BDS lift
    Crossmember is cut and BDS one installed. Also has extended steering knuckles.
  6. Sep 29, 2023 at 5:09 AM
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
  7. Sep 29, 2023 at 5:14 AM
    BillyE
    Agree, but the stock suspension would also have the same "do not use with spacers" warning. Your goal is to have the most travel you can get and keep the lift about where it is? There's all kinds of things you can do, but different options will require different stops, drops, extensions, drops, etc...
    Traps[QUOTED][OP] likes this.
  8. Sep 29, 2023 at 5:22 AM
    Traps
    Traps [OP] Member
    Terry
    2019 Tacoma SR5
    6 inch BDS lift
    I didn't think of that.. be no different than doing a 1/2 inch spacer lift on stock suspension. Right now.. my geometry is all within factory specs..as far as the axle angles..drive shaft angles. Drives haft has spacer installed as well. So yea.. I think a 1/2 inch spacer on top of the 2.5 inch lift coilovers..should work. And replacing the stock rear leafsprings and the 4 inch lift blocks...to a 3.5 inch lift RC leaf pack. Possibly just leave it at that.. might level out nicer.
    I think we've talked me into it.
