Going from coilovers to spindles?
Discussion in 'Suspension' started by cluck024, Nov 4, 2011.
  1. Nov 4, 2011 at 8:04 AM
    cluck024
    cluck024 [OP] -cluck
    Robert
    Greenwood, Arkansas
    09 Prerunner TRD-OR DC Barcelona Red
    Blacked out badges, Anytime Fog Light Mod, Sockmonkey Decals and Third Brake Light Cover, Yellow fog lights, custom homelink install, Radflo 2.0 coilovers, LR UCA's, AAL, Moto Metal 957 matte black with Nitto Terra Grappler 285/70/17 shoes, more to come...
    Currently I have radflo coilovers set at 3" of lift with rear 2" add a leaf. I want to get spindles and set the coilovers to 0". I want the lift to be level or have a slightly higher rear end. What would be the best option for the rear? And is there anything else needed that I may not be aware of?
    EDIT: I also should mention I currently have bilstein 5100 shocks in rear. Would I need longer shocks? If so, what shocks would be the best choice?
    Thanks for the help
    -cluck024
  2. Nov 4, 2011 at 9:36 AM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    Look at the allpro expedition pack, think its around 4". Def need longer shocks, long 5100s from DSM or wheelers!
  3. Nov 4, 2011 at 9:51 AM
    cluck024
    Robert
    Greenwood, Arkansas
    Good info, would love to hear from some others!:)
  4. Nov 4, 2011 at 1:54 PM
    cluck024
    Robert
    Greenwood, Arkansas
    Come on guys, need some more advice. Anybody?
  5. Nov 4, 2011 at 2:01 PM
    mjp2
    Milton Juevos Portimous II
    NJ
    '06 TRD Access Cab, v6, 6-speed
    Scaffolding and a painted grill
    Sublime pretty much covered it. You'll need longer brake lines too.
  6. Nov 4, 2011 at 2:23 PM
    dira1987
    dira1987 Well-Known Member
    David
    Chandler AZ
    2003 LT Prerunner
    Metal.
    What size of spindles are you looking to add (just wondering). I have the camburg spindles and icon coilovers set to 0 as well. In the rear i just did the ome dakars and nitrocharger shocks. It worked out great. I do have a small prerunner rake with the nose up a hair in the front but its not that noticeable.
  7. Nov 4, 2011 at 5:23 PM
    cluck024
    Robert
    Greenwood, Arkansas
    Yes, but I would like to hear other options as well!!
    I was looking at 4" camburg spindles with radflos at 0". Dont want any "bro lean" !! Would the allpro expo pack take care of that? If so what shocks would I need to take full advantage of the expos?
    Thanks again guys!
  8. Nov 4, 2011 at 6:00 PM
    cluck024
    Robert
    Greenwood, Arkansas
    Actually, now that I think about it. My whole reason for wanting spindles was to improve the ride and get better alignment. That being said, What spindles would you all suggest?
  9. Nov 4, 2011 at 6:59 PM
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    Check allpro's website. Their rear package is everything you want with springs, shocks, u-bolt flip kit, bump stops and extended brake line for $1000!
    That's the only quality lift other than OME which was stated will give you the bro lean!
  10. Nov 5, 2011 at 7:09 AM
    cluck024
    Robert
    Greenwood, Arkansas
    what about the walker Evans set up they have for 699? has anyone used those shocks? I don't do much off roading, just the deer woods.
  11. Nov 5, 2011 at 7:55 AM
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    Ya, you should be good!
  12. Nov 5, 2011 at 8:01 AM
    kinkrider101
    kinkrider101 Well-Known Member
    santa barbara
    2007 cummins/2007 tacoma
    wheels and tires
    Get in on the maxtracspindles 420$ and only give a hair over 3.5"
  13. Nov 5, 2011 at 8:03 AM
    hudhawk
    hudhawk #texasforever
    Hudson
    California
    TRD Off Road
    Rust, lots of rust
    Keep in mind that the All-pro expo leafs are much stiffer than the All-pro standard pack which is already stiff. If you are going to be hauling lots of weight in the bed all the time, then I would say get they expos, if not get the standard pack.
  14. Nov 5, 2011 at 8:03 AM
    cluck024
    Robert
    Greenwood, Arkansas
    Thanks for the help sublime! One more question, has anyone tried out the maxtrac spindles?
  15. Nov 5, 2011 at 8:05 AM
    cluck024
    Robert
    Greenwood, Arkansas
    I do think I will end up getting these, but dont have the cash right now. Even at 500 for the set its a steal!
    Thanks hawk, wasnt sure on this either!
  16. Nov 5, 2011 at 8:05 AM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    ALCAN can do custom springs for ya... but you'll need longer shocks... look at the 5125/5150s
