Going from towing with a 6spd to Automatic..anything i should know?
Discussion in 'Towing' started by Lunercrab, Jan 6, 2010.
  1. Jan 6, 2010 at 9:17 PM
    Lunercrab
    Lunercrab [OP] AKA "06tacosport"
    Beth
    Lehigh Valley area, PA
    2010 timberland mica dcab sport
    Ok so i currently have a 06 sport 6spd that i use to tow my small popup (bout 1400lbs) anyways i'm most likely buying a 2010 sport with auto this time and i was curious if there is anything i need to do differently. Now correct me if i'm wrong but if it comes with the factory tow package then it has a tranny and oil cooling system right? and i know not to tow in overdrive, so there is a button to disable this right?(sorry it's be awhile since i towed with an auto) i'm guessing there is not going to be much difference between towing with the 6psd vs auto...but i just was curious :p
  2. Jan 6, 2010 at 9:18 PM
    4low2go
    4low2go Well-Known Member
    Coatesville, PA
    10 RC 4x4 5sp MGM
    Curt hitch, OBX Shift
    The auto is easier to tow with.
  3. Jan 7, 2010 at 5:29 AM
    Demoncleaner
    Demoncleaner Well-Known Member
    Upstate NY
    05 Dcab 6spd 4x4 TRD Sport w/Tow
    TRD exhaust Homemade bed mat & bed extender, front Drings, Short clutch throw, Summer: Stock 17's Winter: Blizzaks on 16' black steelies
    Traitor.
    Your gonna miss 6th pulling that 1400 lb trailer.
    No button, if you look at the auto's shift column, 4th is where you naturally go, straight up. Over to right is OD.
  4. Jan 14, 2010 at 7:16 PM
    Isthatahemi
    Isthatahemi Well-Known Member
    TRD OFF ROAD
    BFG AT's, Weathertechs, Hoppy's brake controller.
    No reason not to tow in overdrive. This is not a chevy. Especially with a light camper and a towing package.
