Going in for TSB. What to know about?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by airsoft_warrior, Oct 21, 2008.
  1. Oct 21, 2008 at 8:47 PM
    airsoft_warrior
    airsoft_warrior [OP] Batman
    Zack
    Edgewater, Maryland
    2015 Tacoma DCLB Limited
    TRD Performance Exhaust
    So i am taking my taco in on friday to be looked at for the suspension TSB. Prior to going in is there anything i should know about before going in? Like anything else that i need to have checked out for the TSB?
  2. Oct 21, 2008 at 8:59 PM
    Killer Red Taco
    Killer Red Taco NorCal Rock Whore
    Whatsurname
    BFE–Norcal
    007 Tacoma A/C TRD O/R Impulse Red 4x4
    Bilstein 5100 on front at 1.75 setting • 5100 on back• K&N Air Filter• TRD Seat Covers• Day Time Running Lights• Foglights Anytime• Hella 500 lights in grille• Rear TSB Springs• Alternative Locker Mod• CB and 4 ft firestick II• Billet Grille• Kid puke in the back!• 265/75R16 Goodyear MT/R• 16" Devino wheels• Hose Clamp Mod• Revenge Fab Sliders• No Sway Bar• A Hottie as Copilot
    I got my appointment tomorrow and I am playing stupid, till they say there is now problem with the springs. Then I pull out the TSB.
    I drove the truck around tonight with weight to rub on the bump stops.
  3. Oct 21, 2008 at 10:20 PM
    Gerry Pope
    Gerry Pope Well-Known Member
    San Diego
    07 4X4 PreRunner
    Nothing to do prior to going in. If you have read through the TSB you know what is expected. Make sure they do everything listed. I took mine in and they forgot to do the alignment.. A quick phone call dealt with that issue. Make sure you double check their work. Some folks have had the wrong leafs put back on.
  4. Oct 22, 2008 at 6:46 AM
    smokey28723
    smokey28723 Member
    Cullowhee
    08 TRD Offroad
    ARE Camper
    Took mine in this week for an "evaluation". (08 trd dc 6spd) They said it wasn't a problem to do the TSB and would order the parts. When I got home, I noticed the part numbers on the list they ordered were the same as the old part numbers. I called them back and they assured me they ordered the new parts with the 4 leaves. We will see, and I will definately have them check before I drive 1 1/2 hours to the dealership.
  5. Oct 22, 2008 at 6:48 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    take a copy of the tsb with you, and point out the right part numbers so they dont order the wrong ones!!
  6. Oct 22, 2008 at 6:58 AM
    hoosiertaco
    hoosiertaco Well-Known Member
    x2, I also went one step further Will and made them check for the four leaf when the parts arrived. They were insulted but oh well.
    I also want to say as I do in all of these threads........everyone needs to remember that the TSB was created because of customer complaint of a 'Harsh Ride'. If your truck is a qualifying truck on the TSB, neither you nor your truck have to prove anything.
    Tell them you have had a 'Harsh Ride' and you want this customer generated TSB done for the suspension. They may try to intimidate or scare you. But after that, look at them and smile and ask when will the parts be in.:D
  7. Oct 22, 2008 at 7:01 AM
    lsocoee
    lsocoee My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    get the alignment report. I didn't and they told me that they did an alignment, but 6 months later, the inside edges of my front tires were bald. They replaced them, but scratched my rim in the process.
  8. Oct 22, 2008 at 7:12 AM
    Brunes
    Brunes abides.
    Rotorhead
    Don't waste the time playing dumb..It's insulting to the service folks to try and set them up like that.
    Walk in- Say that you had issues with bottoming out and a rough ride. You found this info from the TSB. Work with them from there. You need to make sure they get the right parts- and the more you screw around with them the more frustrated and tired of dealing with the problem everyone will get.
  9. Oct 22, 2008 at 7:16 AM
    hoosiertaco
    :thumbsup::amen::thumbsup:
  10. Oct 22, 2008 at 7:31 AM
    mws4ua
    mws4ua I'll try being nicer if you try being smarter.
    Birmingham
    2018 GMC Sierra SLT Z71 4x4... Yeah yeah, I know.
    Definitely take a copy of the TSB with you. Also, since you have a TRD, highlight the parts section that shows that the TRD DOES NOT NEED NEW SHOCKS!
    You have nothing to prove. Just say it has a harsh ride and that it has bottomed out before.
    Have you called them? My dealer didn't have the parts to do mine the first day I took the truck. I had to come back a week later to give them time to order the parts.
  11. Oct 22, 2008 at 8:24 AM
    hockeypoor
    hockeypoor Well-Known Member
    Central Coast of California
    Speedway Blue All stock Prerunner
    Had mine done in San Luis Obispo, Ca. Just picked it up yesterday and it was done right the first time. Joe in the service dept was great. I will say that it looks like the rear of my truck is about 1/2- 1in higher then before but I am sure that the springs will settle some. Anyway rides like a truck now. Not to stiff not to soft just right.
    They also fixed some other things on my truck without any hassle at all.
  12. Oct 22, 2008 at 8:30 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    and the reason i say take a copy and show them the correct part numbers......the first time i took mine in....the ordered the wrong parts and installed them. i had to take the tsb in and show the parts guys and the service manager the correct part numbers. it wasnt fun.
  13. Oct 22, 2008 at 2:40 PM
    airsoft_warrior
    Zack
    Edgewater, Maryland
    Well they said that no matter what they would have to order the parts, after they look at the truck to see if it qualifies, then they would order the parts. How do i know if the leafs are the correct leafs or not?
  14. Oct 22, 2008 at 2:41 PM
    lsocoee
    Hotdog
    Wet Okole Underwear
    if you have 4 leaves, you have the updated ones. If you have 3, they screwed up. You could also have them read you the part numbers
  15. Oct 22, 2008 at 2:41 PM
    mws4ua
    Birmingham
    The new ones? Mine still had the label on them when they were installed. Also... before the TSB there were 3 of them, afterwards there were 4. Tht was enough for me.
  16. Oct 22, 2008 at 2:42 PM
    airsoft_warrior
    Zack
    Edgewater, Maryland
    My dealership scratched my rugged edition rims and i was pissed. I raised hell with them and they said that there was nothing they could do for it and it will happen everytime.
  17. Oct 22, 2008 at 2:44 PM
    lsocoee
    Hotdog
    Wet Okole Underwear
    yeah, I called the 800 number a bunch of times and they just ignored me there too. I'm done getting all my free TSB work at that dealership.
  18. Oct 22, 2008 at 2:51 PM
    Killer Red Taco
    Whatsurname
    BFE–Norcal
    I feel It is not a insult, if they are on the ball than I shouldn't need to tell them about the TSB, thats there job. I told them the problems he said there is no recall for my truck in which I replied what about a TSB to which I received no answer. Will see what happens I forgot the TSB paper at home so I'll bring it in if I have a problem.
  19. Oct 22, 2008 at 4:59 PM
    keeper15
    keeper15 Member
    SF Bay Area
    05 PreRunner
    CoverKing Seat Covers Running Boards
    :( Called dealer and he said this is covered only if within 36 month or 36000 miles. Since I have Jun 2005 sold date and 12000 miles it isnt covered! Darn:help:...I only have 12000 miles...it does feel porpoisey:crazy: on freeway and does have the 3 spring setup....any help out there....
  20. Oct 22, 2008 at 5:16 PM
    Gerry Pope
    San Diego
    07 4X4 PreRunner
    Ya know... We live in a different world now.. Think back to how it was before the information age. We were at the mercy of the so called experts. With the tools of the internet we can arm ourselves with information. Sometimes we seem to be more informed then the folks at Toyota. Take the Harsh ride TSB.. If it had not been for this forum I might have remained in the dark about this process. I admit I went to the dealer ready for a fight. After hearing about the troubles many of us have had with trying to get the tsb done. After talking with my service rep for 5 minutes I felt as if I had hit paydirt. They said they would do the work. I did not have to prove my truck was bottoming out. They treated me like an adult! Sadly this seems to be the exception rather than the rule. They called to say it was finished but no mention of an alignment. Armed with the info from this forum and the TSB I had to remind them that they need to do an alignment. A couple hours later and my truck was back where she belongs.. I realize that the reps at Toyota are doing more with less... who isn't. No excuse though. If you have a truck with this issue and it is under warranty and Toyota values you as a customer they should not question your motives for seeking this fix. If you cannot get the help you need from your rep... find another!
