Going SAS, selling IFS parts
Discussion in '1st Gen Tacoma Parts Marketplace (1995-2004)' started by GC1990, Jul 11, 2021.
  1. Jul 11, 2021 at 5:57 PM
    GC1990
    GC1990 [OP] Well-Known Member
    Graham
    Tampa, FL
    2017 TRDOR ACLB
    Selling for a friend; He decided to go bigger. (New motor, Dana’s etc)
    Pictures include everything that is available, the following is being sold together at this time:
    Fox dsc coilovers
    Icon upper control arms
    Front axle with Detroit turetrac 4.88 gears
    Factory rear axle with factory locker, actuator guard from LROR, 4.88 gears
    5- 17” rotiform wheels, 0 offset with maxxis razr mt 285/70/r17
    The remaining items are included if you want them, (Mostly stock parts (transmission, gear case, steering etc)
    All parts have approx 20k miles and were purchased new except for the transmission and transfer case which have around 120k.
    $5000, located in Tampa FL
    alarka likes this.
  2. Jul 11, 2021 at 9:00 PM
    v5ensx
    v5ensx CARB legal is not CALI legal
    SAS parts? More like IFS...
    Xiongmoua90 likes this.
  3. Jul 12, 2021 at 10:10 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    What model year is the truck?
  4. Jul 12, 2021 at 10:13 AM
    GC1990
    Graham
    Tampa, FL
    2017 TRDOR ACLB
    It was off an 04
  5. Jul 12, 2021 at 10:15 AM
    Digiratus
    Roaming the PNW
    The RedHead
    Auto trans with a push button t-case?
  6. Jul 12, 2021 at 11:02 AM
    GC1990
    Graham
    Tampa, FL
    2017 TRDOR ACLB
    Direct shift (Stick) T-Case (you can see it pretty well in the first photo) And auto trans.
  7. Jul 12, 2021 at 6:39 PM
    Cooperm77
    Cooperm77 Member
    Cooper
    Toyota Tacoma 2002
    4x4 3.4L E-Locker
    Would he be willing to sell just the upper control arms and the fox coil overs?
  8. Jul 13, 2021 at 12:25 AM
    Digiratus
    Roaming the PNW
    The RedHead
    It's either a j-shift or a push button. Both use sticks to shift into 4WD. There isn't enough detail in your pic to differentiate between the two different t-cases.
  9. Jul 13, 2021 at 8:17 AM
    GC1990
    Graham
    Tampa, FL
    2017 TRDOR ACLB
    Looking to sell as a whole, give a few weeks and will possibly reconsider
    Apologies, I'm just the messenger. I confirmed it is J-shift
    Again, just the messenger, he's currently doing a SAS, so these are the parts he had on prior.
    Digiratus[QUOTED] likes this.
  10. Jul 13, 2021 at 8:21 AM
    desertjunkie760
    desertjunkie760 @DesertJunkie760 (IG)
    Shane
    2011 MGM DCSB TRD Sport 4x4
    Check My Sig.
    Free bump. The thread title is deceiving FYI.
    Also interested in the Fox 2.5" if you decide to separate.
  11. Jul 13, 2021 at 8:29 AM
    GC1990
    Graham
    Tampa, FL
    2017 TRDOR ACLB
    Changed thread title.
  12. Jul 13, 2021 at 8:40 AM
    17taco4x4
    17taco4x4 FZJ80
    Orlando
    Porter, TX
    1997 Land Cruiser
    I understand trying to sell as a whole but if willing to separate, I’m interested in both front and rear axles.
  13. Jul 20, 2021 at 7:31 AM
    GC1990
    Graham
    Tampa, FL
    2017 TRDOR ACLB
    Bump and willing to separate.
    Coilovers and UCA's Sold
    Front and Rear axles - $1500
    Wheels and Tires -$1500
  14. Jul 20, 2021 at 8:06 AM
    It all starts with a taco
    It all starts with a taco New Member
    Utah
    1998 Red Ext. Cab Tacoma
    OME rear leaf springs. Metal bumpers front and rear. Billistein 5100's up front.
    Will you sell just the coils?
  15. Jul 20, 2021 at 8:41 AM
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    How much for just the Icon UCA's?
  16. Jul 20, 2021 at 4:30 PM
    beez
    beez Well-Known Member
    Nate
    04 single cab PreRunner
    I need the transfer case shifter assembly.
  17. Jul 21, 2021 at 2:54 PM
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    @cbechtold too bad you don't need those UCA's anymore. Good deal on both UCA's and 2.5 DSC's
    cbechtold likes this.
  18. Jul 21, 2021 at 2:58 PM
    cbechtold
    cbechtold IG: @corybechtold
    Cory
    Pleasanton, CA
    2001 DCSB SR5 TRD 4x4
    @otis24 I know you need new suspension :stirthepot:
    otis24 and betterbuckleup like this.
  19. Jul 21, 2021 at 4:00 PM
    otis24
    otis24 Hard Shell Taco
    Mark
    California
    OtisBound Outdoors Bodonkadonk
    OtisBound Bodonkadonk
    Thanks for thinking of me!
    I’m going back to work next month so I’ll be able to get stuff again!
    cbechtold[QUOTED] likes this.
  20. Jul 22, 2021 at 3:51 PM
    jacky_bubbles
    jacky_bubbles Senior Lurker
    Victoria
    Supercharged 1997 Tacoma
    Any chance the factory LCAs are available?
