Going to a One piece Drive Shaft tomorrow
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tacomafinally, Jan 20, 2011.
  1. Mar 17, 2013 at 7:52 AM
    #61
    TXPROMAN
    TXPROMAN Well-Known Member
    Martin
    NY
    2012 TX PRO TACOMA
    vibrations and shuddering in 3 to 6 inch lift only? How about 2." lift?
    otherphone likes this.
  2. Mar 19, 2013 at 2:03 PM
    #62
    TRDBeast
    TRDBeast Boogie Man Kryptonite
    Wayne
    Coconut Creek, FL
    08 Tacoma Crew Cab TRD
    Brute Force front armor with 30" rigid and dual 4" quad rigid fogs OME suspension 3" lift with Dakar leaf pack and ToyTec body lift for total 4.25 LR UCA's 9000 sport Nitro Charger shocks 885X Coils AFE Pro Dry CAI 18" Rockstars Alpine DDIN systemw/Nav, Bluetooth and DVD 2 12's Infinity Kappa's in doors and Alpine 6.5 X 9 in front and back and 2 Alpine Zeus amps rear 2 Rockford Fosgate amps front NFab running boards Dyno tuned FXRs w/ 3" Projectors and Halos retrofit w/ Apollo shrouds and 5000k HID 55W Debadged Wet Okole skins HomerTaco Satoshi grill Elusive Elements light support with 2 Hella 500ff's behind grill Powder coated tool box TRD gear shift Andres Devil Horns TREX eyelids Body Armor rear bumper 15% Tint "ZOMBIE" light switches Custom gun concealer in dash One-piece aluminum drive shaft LED interior light swap
    Im sorry I did not measure it myself. I had the drive shaft installer do everything....
  3. Mar 19, 2013 at 2:04 PM
    #63
    TRDBeast
    Wayne
    Coconut Creek, FL
    all up to the truck. Ive heard people doing the same lift with no problems at all while others are in agony....
    na5m likes this.
  4. Mar 19, 2013 at 3:11 PM
    #64
    TXPROMAN
    Martin
    NY
    2012 TX PRO TACOMA
    I have a 2." lift with AAL for the rear. It's been snow up here no time to install at this time . Hope I dont get vibrations. I have 2012 4 door.
  5. Feb 23, 2014 at 1:17 AM
    #65
    puretone
    puretone New Member
    1998 Tacoma, chassis type RZN150
    Hey gjbonner:
    Here's a good pointer for you if you have that shudder when starting off from a complete stop. Prolly also a good idea for an Admin to add this info to a sticky thread or general "What's causing this weird *insert symptom* behavior?" FAQ.
    I had a bit of a light ticking noise coming from my driveshaft. It's a 1998 2WD Extended cab & 2RZ-FE and 195.000 miles on the clock. So it's excusable that the driveline would have some sort of issue finally. Ticking noise was the U-joints, no biggie & a relatively common thing. Right before I installed the replacement U-joints I started noticing a bit of a shudder when accelerating from a dead stop. It did so for the first 10 or 20mph, in 1st & second gear shifts. Transmission = automatic. To me the shudder sort of felt akin to a manual transmission clutch disk slipping. I did for a moment have a bit of a worry, thinking it was the auto trans and/or torque converter commiting suicide....
    The fix that eliminated this type of shudder was the replacement of the U-joints and carrier bearing. Took all of 1 hour to fix in my Temple Of All Things Combustion, aided by my Toolbox Diciples & Bible Of Service Shop Manual.
  6. Jan 29, 2017 at 3:58 PM
    #66
    MurdedTaco
    MurdedTaco New Member
    Andre
    2011 Tacoma Dbl V6 4x4
    Well my driveshaft just came off while getting on the freeway... 2nd time this has happening owning 2 different trucks smh
    .. im looking at tom woods now
  7. Jan 30, 2017 at 3:49 PM
    #67
    Tectonic
    Tectonic Well-Known Member
    James
    Tucson, AZ
    12 TRD Sport DCSB 4wd
    Bilstein 5100 all around OME 884 Wheelers 1.5" 3 leaf progressive aal 255/75r17 Hankook Dynapro ATM ARE camper shell Hella Sharptones (4)
    Holy shit dude. Stock or a custom one-piece?
  8. Jan 31, 2017 at 1:24 PM
    #68
    MurdedTaco
    Andre
    Stock... happened on the same freeway my last truck decided to shit out the driveshaft too...
  9. Feb 1, 2017 at 9:48 AM
    #69
    braik
    braik Well-Known Member
    Louisville, KY
    2006 4.0L 4x4 BASE
    2" Ironman 4x4 (B) Front Spacer Level LR UCAs Level 8: Tracker Wheels 255/75 Cooper ATPs Welded Rock Sliders Weathertech floormats Wet Okole seat covers JVC Head Unit Diff Breather Mod Zip Tie Mod Needle Bearing Mod HID Retrofit (Acura TL-R)
    My driveshaft dropped out of mine going down the highway as well about 2 months ago. Luckily I was on the exit ramp and not going full speed. Unfortunately it cost a few hundred dollars to source a replacement rear flange yolk that was damaged, and then 2 mos later I find out those vibrations I've been feeling at 65mph is my driveshaft out of round by 15/1000ths. I'm looking into a local shop or High Angle Drivelines to replace it with a one-piece. I just can't decide if aluminum would mean I don't have to worry about the "jump roping" at higher speeds some people complain about with the TW shaft.
  10. Feb 1, 2017 at 4:54 PM
    #70
    Regcab05
    Regcab05 Well-Known Member
    David
    Atlanta
    05 regular cab 4x4
    Yotamasters.com has yokes for $60
  11. Feb 1, 2017 at 4:54 PM
    #71
    Regcab05
    David
    Atlanta
    05 regular cab 4x4
  12. Feb 1, 2017 at 5:05 PM
    #72
    braik
    Louisville, KY
    2006 4.0L 4x4 BASE
    I exaggerated a little bit. They had to do the ujoints, and the yoke plus the labor ended up being a few hundred dollars.
  13. Feb 1, 2017 at 5:08 PM
    #73
    Regcab05
    David
    Atlanta
    05 regular cab 4x4
    It's all about the wording. I thought you paid $300 for a part that can be had for $60. I didn't want that to happen to anyone else.
    braik likes this.
  14. Feb 1, 2017 at 5:10 PM
    #74
    braik
    Louisville, KY
    2006 4.0L 4x4 BASE
    Nah. Someone else reading this thread later on will probably appreciate your post though.
  15. Jun 9, 2017 at 12:37 AM
    #75
    na5m
    na5m Member
    Sacramento
    V-6 4x4 6-speed manual
    Bone stock, except for my TaoTronics HD back-up camera & KW-NT810HDT audio HU...
    Old, but excellent drive shaft thread! I am DEFINITELY going to get a one piece shaft for my
    2011 Taco 4x4 6-speed manual V-6. I have installed a 2 inch body lift and a 6 inch suspension
    lift and the 2-piece shaft fully sucks! The center bearing (or drop bearing or pillow block) really
    sucks if you've done any suspension/geometry mods. The stock rubber bushing center bearing
    is so that the truck will drive all comfy-cushy for commuter drivers.
    Here are a couple of vids of the drive shaft issues I was facing after my lift:
    MEGA REAR AXLE WRAP!!!
    https://www.youtube.com/watch?v=ozF3KsHBFB4
    A BIT MORE TAME AXLE ACTIVITY WITH A TRACK/TORSION BAR INSTALLED....
    https://www.youtube.com/watch?v=70dfaYO6nec
    CENTER BEARING OBSCENITY!!!! AND LOOK AT THE LASAGNA STOCK LEAF SPRINGS!!
    https://www.youtube.com/watch?v=C1Yzni66qcs
    Long boring story short: I am going to break some hard earned bread and have a local shop
    custom fab a one piece drive line for my Taco. I live in Sacramento, CA and will give these
    guys a go. They have been here for quite a while and they have a good Yelp score and also
    a nice "History Of" page at
    https://www.drive-lines.com/dlssac.com/index.html
    For the sake of all of this thread's visitors, I will report back as soon as I can about my experience
    going to a 1 piece shaft.
  16. Jun 9, 2017 at 1:32 AM
    #76
    azzwethinkweiz
    azzwethinkweiz Well-Known Member
    Tucson, AZ
    2013 4x4 DCSB V6 6-Spd, TRD OR, Tow Package
  17. Jun 9, 2017 at 7:36 AM
    #77
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    any details on the traction bar?
  18. Jun 9, 2017 at 7:41 AM
    #78
    TACOVRD
    TACOVRD I Identify As A Prius
    TW Addict
    AZ/WA
    2019 T4R ORP - Formerly 2013 DCSB OR Spruce Mica
    Workin' on it....
  19. Jun 10, 2017 at 12:36 AM
    #79
    na5m
    na5m Member
    Sacramento
    It is a bolt-on kit from budbuilt.com
    You can see in the video that the bar
    worked pretty well against the torsion
    from the stock leaf springs. I haven't
    filmed it yet, but I have replaced the
    crummy stock springs with a stout
    set of OME leaf springs. TOTAL
    NIGHT/DAY! Axle twist is now ZERO.
    The very last issue with my final drive
    now is the friggin' vibrations due to the
    poorly designed 2-piece drive shaft and
    the sloppy center bearing.
  20. Jun 11, 2017 at 4:24 PM
    #80
    nd4spdbh
    SoCal
    my problem is the OME dakars are going to be too stiff for my tastes....
    That budbuilt kit, where does the front bolt to? Same cross member as the carrier bearing?
    na5m likes this.
