Going to ask a dumb question.
Discussion in 'Lighting' started by rhowell, Feb 15, 2014.
  1. Feb 15, 2014 at 5:07 PM
    rhowell
    rhowell [OP] Well-Known Member
    Robert
    Canada
    08 Indigo TRD Sport 4x4 DCSB
    -Leather with Heated seats -AFE cold Air Intake -DE-jr Rims -Upper and Lower grills from Black Diamond Fabrication -Light bar behind grill -Hella Black Magic Rallye 1000 lights. -OME lift cw Dakar leafs -LR Upper control arms -Rosen duel DVD headrests -Nfab steps -leer canopy
    I asked this before but got no response. I am dumb when it comes to lighting and electrical so even if this is a waste of kb please answer.
    I have a palfrey built bumper coming and have rigid d2 and a sr20 waiting to install (rigid industries). I also have Hellas behind my grill wired to a switch in the cab.
    Question. Can I run all the lights to turn on with one switch?
    Thanks.
  2. Feb 15, 2014 at 5:18 PM
    deadhed61
    deadhed61 :notsure:
    Santa Barbara, Ca
    The Black Pearl
    A little lift and a little armor
    *Pelfreybilt* :)
    You're most likely going to want each of them on at different times so why put them on the same switch? But in the end, if the switch is rated above the total current draw there shouldn't be a problem. I just wouldn't do it.
  3. Feb 15, 2014 at 5:20 PM
    Juggernaut
    Juggernaut Captain
    Sacramento
    25 TRD OffRoad DCSB
    Hook it up to a relay and then you don't have to worry about the wattage going through the switch. So yes you can.
  4. Feb 15, 2014 at 5:20 PM
    95SLE
    95SLE Starting to get cold outside
    Tom
    Maryland
    09 RWD Access Cab
    Custom XM Install, Window Tint, Intermittant Wiper Install, AVS Bug Deflector, Bed Mat, TRS FX-R retrofits, CIBIE fog and spot lamps, PIAA 510 lamps, Acess LE cover, Weathertech Digital floorr mats, LED interior lighting, Pioneer AVH-2300BT HU, Boston Acoustics speakers, JL Audio Amp, shorty antenna, leather wrap steering wheel cover, Viper security system.
    You would be better off installing a relay and have the switch operate the relay.
  5. Feb 15, 2014 at 5:22 PM
    rhowell
    Robert
    Canada
    Thanks. I meant to say pelfreybilt. Can't type on this freakin thing. I think they are either all on or all off since none of them are legal to drive unless I am on the back roads. Need all the light I can. Too many close calls with deer and moose going night skiing.
  6. Feb 15, 2014 at 5:23 PM
    rhowell
    Robert
    Canada
    They all have individual relays so can I just run them all from each relay and join all the wires together at the cabin switch.
  7. Feb 15, 2014 at 5:36 PM
    95SLE
    Tom
    Maryland
    09 RWD Access Cab
    Or you can use some diodes and have each on its own switch and a dedicated switch that operates all the relays.
  8. Feb 15, 2014 at 5:42 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    Yes. Have the low amp side of the relay on the rigids, be energized by the high side(or low side if you want) of the hellas. Then when you turn on the Hellas, the rigids turn on too.
  9. Feb 16, 2014 at 4:11 PM
    ZEROPILOT
    ZEROPILOT Can't re-MEMBER
    ED
    SUNRISE,FLORIDA
    09 2.7 XTRA CAB 5 SPEED
    LARGER WHEELS. DIFFERENT STEREO. PUSH BAR. TAILGATE EXTENDER. WIPER MOD. TPMS LIGHT DELETE MOD.
    I've got some powered by a relay from my high beams. No switch but on when needed.
  10. Feb 17, 2014 at 8:31 PM
    rhowell
    Robert
    Canada
    Don't suppose you can draw a schematic. I have no clue what you are referring to.:confused:
  11. Feb 17, 2014 at 8:32 PM
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    The only dumb question is the question that's not asked.
