Going to be driving on the beach...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dennisi01, Jul 1, 2010.
  1. Jul 1, 2010 at 5:40 AM
    Dennisi01
    Dennisi01 [OP] Well-Known Member
    Dennis
    Lopatcong, NJ
    '10 SR5 4x4
    None
    Hey all,
    I'm going to be going on vacation to the outer banks, NC, in about 3 weeks, and we plan on taking my 2010 DC LB 4x4. We are going to be staying in Carova, and will have to drive about 7 miles on the beach to get to/from the house. Do you guys have any suggestions on how to avoid getting stuck? Would I turn traction control off or anything like that? I don't have a TRD, it is an SR5, if it matters.
    thanks,
    Dennis
  2. Jul 1, 2010 at 5:51 AM
    kb1jop
    kb1jop Well-Known Member
    Rick
    Springfield, MA
    2010 Barcelona Red 4WD DCSB 6-Speed SR5
    Factory Towing Package Factory Roof Rack OEM Bed Mat Trifecta Tri-Fold Tonneau SeatSaver Custom-Fit Seatcovers WeatherTech Custom-Fit Floor Mats Block Heater: http://www.metrotpn.com/ProductDetails.aspx?CollectionID=13&ProductID=191&SortIndex=9
    If you don't know already, you will need to lower your tire pressure to around 18-20 PSI. Does NC have equipment regulations? I would think they do. Here's Rhode Island's list:
    1. Shovel (heavy-duty or military entrenching tool).
    2. Tow rope of chain (15 feet, load strength of 1,800 lbs., chain size-5/16" ).
    3. Jack and support stand (minimum 18" x 18" x 5/8", plywood).
    4. Street legal tires.
    5. Spare tire
    6. Low-pressure tire gauge (0-20 lbs.).
    7. First aid kit (approved by Coast Guard).
    8. Fire extinguisher (approved by the Coast Guard or Interstate Commerce Commission).
    9. Road flares and…..
    10. Flashlight
  3. Jul 1, 2010 at 7:06 AM
    kb1jop
    Rick
    Springfield, MA
  4. Jul 1, 2010 at 7:26 AM
    David K
    David K Well-Known Member
    San Marcos, Alta California
    2010 4WD Off Road DC
    Wow... the mis-information about traction control is pretty scary! TRAC is ON in 4WD HIGH (which is the mode for beach driving). The automatic limited slip system is a BIG advantage in off pavement driving as it directs torque (power) to the tire(s) with traction and will brake the spinning (non-traction) tire.
    In sand (or other low traction surfaces) the trend of open differentials is one tire in front and one in the rear will spin and you stop moving forward. Reducing the tire air pressure to under 20 psi will improve traction, and BEFORE the 2009 addition of Traction Control, was how we drove in sand... usually 10-15 psi.
    Sand is different in different places... out here on the West Coast, the Pacific beaches are mostly flat, with fine grain sand that compacts easily... and is easy to drive on. The Sea of Cortez beaches (Gulf of California) of Baja California are steep, with coarse sand/ crushed shell blend that remains loose and very hard to drive on without deflating tires.
    My third Tacoma (a 2010) with TRAC drove effortlessly over the deep sand without deflating (for the first time). Now, since my truck is an Off Road TRD it has the hydraulic brake booster for the A-TRAC in L4. That also makes the TRAC (in H4) stronger than the non-Off Road TRDs... so your experience may be different.
    Not having driven on the Atlantic beaches, I cannot be sure... But, I would suggest you first try using H4, with TRAC ON (normal mode, no pushing buttons)... Should your tires begin to spin and your truck stops moving forward... STOP, and deflate your tires to 15 psi... Then continue on... Re-inflate when you leave the beach. Do NOT turn off the TRAC (VSC OFF Mode)... it is a great benefit to off road driving and can prevent you from getting stuck.
    See my posts on beach driving in Baja... with photos. I am going back south this weekend to see if my new truck does as well in the summer as it did last winter on the sand!
    Photo taken this past New Years, 25 miles south of San Felipe, tires at 32 psi in 4WD HIGH with TRAC ON... and no getting stuck. In fact, I turned the TRAC/ VSC OFF and the truck soon bogged down and stuck! The A-TRAC drove me right out, and I went back into H4 with TRAC on and continued... My 2005 or 2001 Tacoma would have required deflating the tires.
  5. Jul 1, 2010 at 7:42 AM
    kb1jop
    Rick
    Springfield, MA
    We are not talking about the TRD Off Road 4WD versions like you are. The man said "I don't have a TRD, it is an SR5, if it matters." which it does. I have the same thing. No traction control in either 4WD state, period. No VSC, no A-TRAC, no rear-locker, period.
  6. Jul 1, 2010 at 7:50 AM
    Metallikatz3
    Metallikatz3 Well-Known Member
    SLC, UT
    2017 DCLB OR
    Always in process
    the beaches on the OBX aren't hard to drive.. just air down to around 15-18 psi and make sure you have the equipment required. There are a lot of ruts to follow, just make sure none of them are too deep where you get high-centered.
  7. Jul 1, 2010 at 7:53 AM
    David K
    Take another LOOK:
    "Would I turn traction control off or anything like that?"
    is what HE asks... He does have TRACTION CONTROL because it is a 2010... they all do (TRAC and VSC).
    He doesn't have A-TRAC or a Rear Locker because it isn't an Off Road, correct. The button with the wavey lines under the car is the VSC OFF control... to turn Auto LSD on (quick push) or to turn VSC off (hold down for 3+ seconds, while stopped).
    You said: "Traction control is off when in 4WD." and that is not true in H4... only in L4.
    If there are 2009 and newer Tacomas without the VSC and TRAC, it is news to me, and I retract my statement about misinformation... sorry!
  8. Jul 1, 2010 at 8:11 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    Just drive in 4hi and air down your tires and you should be fine. I will be heading up to corolla this weekend and staying all next week. I will let you know how I do, since this will be my first time driving the taco on the beach there. I too have an SR5 w/ the open diff.
  9. Jul 1, 2010 at 8:53 AM
    MarineTacoDriver
    MarineTacoDriver Well-Known Member
    Brian
    Cherry Point
    09 SR5 4x4
    ARB front bumper, Warn M8000, ATO front/transmission/transfer case skids, Icon ext travel coilovers, Total Chaos UCA's, OME Dakar leaf springs, Bilstein/RCD 5100 3-4" lift shock, extended stainless brake lines, DrewFab shackle flip, rear ARB Airlocker, ARB air compressor
    I went there a few weeks ago, I was able to drive on the beach in 4HI without deflating my stock Dunflops, with a mix of using TRAC and disabling it as well. (SR5)
  10. Jul 1, 2010 at 8:58 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    the same, run my truck with out deflating tires never had a problem. I have nitrogen in tires so did not want to bother with refilling tires later.
    I would suggest doing the breather mod on rear axle. To get to some houses you need to cross pools of water. Depending on your luck some maybe deep enough to go over the axle.
    The hardest spots are exits to house that's where sand is very loose and it can quickly bog down the car.
  11. Jul 1, 2010 at 9:49 AM
    Dennisi01
    Dennis
    Lopatcong, NJ
    '10 SR5 4x4
    None
    Thank you all for the advice.. didn't mean to incite any TRAC wars :) Seems like if i am careful and use some common sense i should be fine (i hope, lol!)
    Thanks again!! :)
  12. Jul 1, 2010 at 9:56 AM
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    17 XLT Sport
    3rd gen forum caused me to get a Ford
    run 4H and keep momentum....then when/if u get stuck, drop the air pressure and 4L. drop the air pressure to start w/ to lessen the chances of stuckage. i drove from corolla to the VA border on the beach road last year. aired down the nitto TGs i had at the time and 4H it all the way w/o issue
  13. Jul 1, 2010 at 4:58 PM
    David K
    I would sure like to know if you have the VSC OFF button (on the dash, left side of steering wheel, car with wavey/ skid lines under it).
    Toyota even puts VSC and TRAC on Corollas now (Star Safety System)... so it would really surprise me if the more expensive (bur not a TRD)Tacoma doesn't have TRAC! I wish all new truck owners would at least thumb through their owners manuel so they get the basics... then come here for the details!
  14. Jul 1, 2010 at 5:32 PM
    Raylo
    Raylo Well-Known Member
    MD, USA
    2009 4x4 Access Cab, TRD Sport
    I was there last August and drove that beach and farther south at Oregon Inlet. I didn't air down the tires and had no issues at all with traction or getting stuck. Not even close. I did have a problem with the steering shaft banging at higher speeds whan I went across others' tire tracks.
  15. Jul 1, 2010 at 9:09 PM
    surfrat
    surfrat Well-Known Member
    LI, NY
    icon coilover, total chaos UCA, allpr expo, icon 2.0 rear,wet okole
    i drive the beaches daily...AIR DOWN..your tranny will thank you..with the DC LB i find about 15psi to work best.. IF you cant idle across the sand your not down enough..Plus you Make ruts and bumps and just piss people off when not airing down...DO it.... ON my 2010 my VSC does kick in occasionally in 4wd on the sand...STUPID feature for 4wd, well maybe not in snow..but on the beach i dont need it
  16. Jul 1, 2010 at 9:35 PM
    mgrande
    mgrande iKill
    Raleigh
    2011 TRD off road
    Kings, AP 3" leaf pack, timbrens front and rear, TC UCA's, pro comp 7189's, baja ATZ's, CBI sliders and rear, relentless front, dynomax catback
  17. Jul 1, 2010 at 9:57 PM
    mach1man001
    mach1man001 eh whatever
    Rob
    Blackstone, MA
    '09 Sport DCLB Met Grey
    Toyota bed mat (1st mod), Toyota all season floor mats, Rear spring TSB, Map light mod, Fog light mod, Putco yellow fog bulbs, Weather Tech window vents, Extra d-rings, Mounted mag light, TRD CAI with AFE pro dry filter, '05 front mud flaps (winter only), 2 set's of wheels/tires, 285/75/16 Hankook MT's, Black Painted 1st Gen TRD wheels (wheeling set) Black powder coated FJ Cruiser with 265/70/17 BFGoodrich KO2's (everyday), painted center of grill & bumper black, Devil horns, OME with 885's + spacers front, OME shocks w/OMD designed rear springs, Front diff drop, Rear trailer plug relocate, ATO IFS skid, Relentless Trans & Transfer skids, BAMF bolt on rock sliders, Relentless tailgate reinforcement, Uniden 75 CB radio, BAMF antenna bracket, TRD exhaust, high lift jack w/ATO mounts. And of course ProEFX Towing Mirrors!
    Can you tell me where in RI you can wheel on the beach? I have looked around before and can't seem to find any info. Thanks
  18. Jul 2, 2010 at 4:00 AM
    StandingCow
    StandingCow Well-Known Member
    NJ
    09 SR5 4x4 V6 access cab
  19. Jul 2, 2010 at 4:10 AM
    Dennisi01
    Dennis
    Lopatcong, NJ
    '10 SR5 4x4
    None
    David,
    Yeah, I do have the VSC off button.
    thanks,
    Dennis
  20. Jul 2, 2010 at 4:13 AM
    Dennisi01
    Dennis
    Lopatcong, NJ
    '10 SR5 4x4
    None
    That was probably a kid who's parents bought him a brand new FJ cruiser for his bday, so he has no idea what it takes to work and pay for something like that.. or he can be someone who just doesnt give a crap about seriously decreasing the life expectancy of hisvehicle :)
