Going to be Tuning up both our tacomas. Need suggestions..
Discussion in '2nd Gen. Tacomas (2005-2015)' started by nitrus5, Sep 11, 2009.
  1. Sep 11, 2009 at 7:43 PM
    nitrus5
    nitrus5 [OP] Well-Known Member
    My wife and i both own 05' Tacomas. the only difference is i have a bilsteins all around with a manual trans. And she has a double cab that is bone stock.
    They are both just over the 50K mile range, and i am wanting to change air filters, spark plugs and check the all the gear cases and trans fluids.
    Is there anything else that needs checked or replaced on this pickups after 50k ??? and where can i find a good air filter that is better than stock. Also are Denso's the way to go for plugs??
    thanks
  2. Sep 11, 2009 at 7:47 PM
    98tacoma27
    Ben
    Not Beech Creek
    Just wait till the 60k maintenance schedule that is in the manual and follow it's recommendations.
  3. Sep 11, 2009 at 7:50 PM
    REVHARD25
    REVHARD25 Well-Known Member
    so cal
    RUGGED TRAIL PACKAGE
    Tint on front windows. Dnx7120 kenwood. Rear tsb springs. Wet okoles seat covers UWS truck box Weathertech floor mats TSB floor mat hook grommets Satoshi grill AFE drop in filter Fumoto drain valve Bed mat
    cabin air filter replace or clean...rotate tires check brake pads..re torque drive axle and teach your wife how to do it also ..so she can help next time:D
  4. Sep 11, 2009 at 8:23 PM
    nitrus5
    thanks!
    she already changes her own oil and rotates tires everytime she changes oil! She likes to get dirty plus she's into all my car hobbies!! i hit the jackpot!
  5. Sep 11, 2009 at 10:25 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    Shouldn't have to do the plugs until at or after 100k, whatever the manual states. 50k on 05's... light driving :D
  6. Sep 11, 2009 at 10:30 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Every 30K for a plug change.
