Going to big bend ranch state park and National Park, recommendations?
Discussion in 'Texas' started by USDashCamera, Jan 9, 2019.
  1. Mar 18, 2019 at 7:33 AM
    #41
    gradyk33
    gradyk33 Well-Known Member
    Grady
    2019 Tacoma TRD Pro
    pending
    The window was a good hike! I would recommending going early so the sun is hitting you too bad. there is no shade. If you want some good food head to Starlight Theatre in Terlingua right out side of the park!
    Beretta4x4 likes this.
  2. Mar 18, 2019 at 11:47 AM
    #42
    USDashCamera
    USDashCamera [OP] Put it in H
    2017 Quicksand TRD OR
    Hopefully others respond since I didn't really do any of the high clearance roads other than the one short one (forget the name) that goes from the west entrance to elena canyon. from what I have seen it seems like any designed trail you'd likely be fine with 2WD. I watched a few videos and it seemed like even the worst part of black gap was just a smallish step up some rocks. but again, I didn't do the trails, spent the whole time hiking so hopefully others will comment. when i searched youtube for black gap and old ore road there were a couple videos showing them.
    the videos made it look very easy compared to some of the trails ive done in the black hills in south dakota.
    or you can always ask the rangers at panther junction.
    ChadsPride[QUOTED] likes this.
  3. Mar 18, 2019 at 11:48 AM
    #43
    ChadsPride
    Sponsored by TacomaWorld.com
    Thanks for the reply! Going to do some planning this evening.
  4. Mar 20, 2019 at 1:53 PM
    #44
    Beretta4x4
    Beretta4x4 What makes the green grass grow? TTC#0114
    Josh
    Temple, TX
    6-speed death mobile
    I did Black Gap, and the 4x4 high clearance requirements are not really necessary, unless there's been recent storms. You couldn't take a car and street tires wouldn't cut it, but a stock 4x4 with all-terrains could do it no problem, I was stock with 265/75r16 KO Begs and had no issues.
  5. Dec 21, 2019 at 9:21 AM
    #45
    Naveronski
    Naveronski Well-Known Member
    Fort Worth
    2014 MGM DCSB TRD:OR
    How was getting a permit for Christmas Mountain?
  6. Dec 25, 2019 at 6:00 AM
    #46
    LostHusker
    LostHusker Just one day at a time
    Mark
    South, TX
    2021 F150, 2015 T4R
    When we went late last year didn't need one, just need to call ahead of time to reserve your time. They allow two runs a day, no more then 4 vehicles, so they say but there have been pics of more then that. One first thing in the morning and one at noon, basically have a 4 hour window, can make the climb in about 45 min if you don't stop for pics.
    Naveronski[QUOTED] likes this.
  7. Dec 27, 2019 at 3:04 PM
    #47
    Naveronski
    Fort Worth
    Thanks! This was still accurate for us.
  8. Dec 27, 2019 at 3:09 PM
    #48
    LostHusker
    Mark
    South, TX
    2021 F150, 2015 T4R
    Looks like you had decent weather, glad it worked out
  9. Jan 28, 2020 at 2:51 PM
    #49
    ashris
    ashris Well-Known Member
    Ashley
    Hey! Love the thread, I'm interested in doing Black Gap, do you guys think I'd need a 4x4 or is 2WD/RWD fine? This would be with a 04' TRD! I've always wanted to go to Big Bend- my dad went out there once and said it was beautiful!
    LostHusker likes this.
  10. Jan 28, 2020 at 4:17 PM
    #50
    Naveronski
    Fort Worth
    Short answer: it depends.
    If the weather cooperates and everything is dry, you’ll probably be fine.
    If it’s wet or has been rutted out recently, there are a couple of spots 4wd would be needed.
    You could do many of the other roads with just 2wd, though. BiBe is still beautiful in 2wd.
    TheIsh and Beretta4x4 like this.
  11. Jan 28, 2020 at 4:20 PM
    #51
    ashris
    Ashley
    Thanks! I appreciate it!
  12. Jan 28, 2020 at 5:53 PM
    #52
    TheIsh
    TheIsh Well-Known Member
    ismael
    midland tx
    baja edition
    You should be able I did it on 2wd but I had 4wd as back up just make sure to take a jack as back up or some plastic treads
  13. Feb 1, 2020 at 12:04 PM
    #53
    rubiconjp
    rubiconjp Well-Known Member
    Austin TX
    I did Black Gap in Thanksgiving 2019. At the Gap, there's no bypass and you would need 4x4, unless you go with a 4x4 which can rope you up. All other places had easy bypasses.
  14. Jul 17, 2020 at 12:41 PM
    #54
    grumpytaco
    grumpytaco Well-Known Member
    Cypress, TX
    2018 TRD OffRoad
    Dissent Offroad Roof and Bed Racks, SoftTopper
    My last trip to Big Bend was Fall 2019. My 24 yr old son and I headed up for a week of camping and hiking. Had a blast. Day 4 we hiked the south rim trail, all 14 miles. We were pretty worn out at the end of the day as we had hiked several of the shorter trails the previous 3 days. Day 5 we were pretty much worthless and just drove around the park and dinked around. If you get there in the hotter parts of the year I would recommend planning on camping up in the Chisos basin. We were seeing as much as a 20 degree temp change from down low to up top in the basin. Sleeping at night when the temps are in the 50's-60's is so much better than sleeping down in the lower elevations where it is so hot and muggy at night.
    USDashCamera[OP] and Beretta4x4 like this.
