Going to change my starter any tips?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Junetaco03, Jan 5, 2017.
  1. Jan 5, 2017 at 6:51 PM
    Junetaco03
    Junetaco03 [OP] Well-Known Member
    Bay Area, California
    2019 TRD OFF ROAD 4x4 DCSB
    Hello I'll be changing my starter tomorrow morning. Anyone have any tips or suggestions on how to get it done easier? I sort of got it figures out. But anything to make my job easier Will help! Thanks for the help.
  2. Jan 5, 2017 at 7:02 PM
    wamego
    wamego Well-Known Member
    2002 Tacoma 2x4 TRD SR5
    You might find some ideas on youtube. 4Runners are really similar.
    DustStorm4x4 likes this.
  3. Jan 5, 2017 at 7:06 PM
    vrod671
    vrod671 The Okayest Member
    Brandon
    2022 TRD Sport 4x4
    Stock
    Get beer. :thumbsup:
  4. Jan 5, 2017 at 7:06 PM
    LuckyToy
    LuckyToy Well-Known Member
    4x4 Offroad
    Drink a couple beers first, starters are not that bad to replace.
  5. Jan 5, 2017 at 7:08 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Go thru the side. You can remove it easier by taking off the passenger wheel. You will have to carefully bend a brake line out of the way.
  6. Jan 6, 2017 at 10:00 AM
    Slickster
    Slickster greentaco
    2002 pre
    isn't it on the driver side?
  7. Jan 6, 2017 at 10:02 AM
    Jerry311SD
    Jerry311SD Well-Known Member
    Jerry
    Ramona Ca SAN DIEGO
    2019 tacoma TRD Quicksand
    KDMaxx tune K&N drop in AFE catback Oil catch can Bill's 6112/5160 Dynomat whole inside of cab TRD skid plate
    My 01 TRD v6 is on the passenger side .....
  8. Jan 6, 2017 at 10:16 AM
    Clearwater Bill
    Billy
    Largo Florida
    Pay someone else to do it. (hey, you asked for easy)
    If you DIY, disconnect the battery first. ;)
    If you are lifting the vehicle, do it on a good surface, chock the rear wheel(s) and use good jackstands. Saving labor $ can be quickly negated with a chassis lying on your chest.
    koditten likes this.
  9. Jan 6, 2017 at 10:20 AM
    Markcal
    Markcal Well-Known Member
    Excellent advice, because an ECM is expensive to replace.
  10. Jan 7, 2017 at 1:31 AM
    DrZ
    DrZ Well-Known Member
    Mesa, AZ
    96 2.4L 5-speed
    My tip is don't replace it, just replace the solenoid contacts, but it sounds like you're going to replace the whole thing at this point. Do us a favor and take the cover of the back of the old starter and let us know if worn contacts were the problem. 99 times out of 100 they were.
    keakar and bry838 like this.
  11. Jan 7, 2017 at 6:21 AM
    ROCKIN RICHIE
    ROCKIN RICHIE Well-Known Member
    BEAN TOWN
    02'TACO
  12. Jan 7, 2017 at 10:03 PM
    Junetaco03
    I just did it guys! I have trd headers so I I had removed them! Pain in the ass!! But it all went smoothly after that.
  13. Jan 8, 2017 at 6:56 AM
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
    Lol when i saw the title i instantly had this run through my head!
  14. Jan 8, 2017 at 8:26 AM
    ghs57
    ghs57 Well-Known Member
    Chops
    Catskill Mts. NY
    '17 Grey TRD OR xtracab 3.5L 4WD
    Pretty much stock right now
    Agreed. Most likely starter problem is worn solenoid contacts.
    I just recently rebuilt a Denso starter on my skid steer. The contacts become worn and grooved and no longer touch when the key is turned. New contacts are readily available online for just a few bucks. I didn't even use the new contacts I bought, but just filed down the old ones, cleaned and greased everything, reassembled and installed. Good as new.
    cruiserguy likes this.
  15. Jan 8, 2017 at 12:08 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    And you kept the original new quality Denso starter instead of some 'reman' Denso that was remanned in chumbawumba.
  16. Jan 8, 2017 at 3:40 PM
    bry838
    oregon
    Exactly!!! The denso is a superb component that people throw away and replace with a piece of shit that cost 100x's more than it would take to replace the wear items in the high quality original!...stupid...
  17. Jan 8, 2017 at 3:46 PM
    cruiserguy
    Elijah
    SEKS
    I think it's usually that owners just don't know what they have available to them. Most don't know that these starters are rebuildable. Even if it's not just the contacts, 99% of the time it's always them though :D, the bearings are replaceable, etc. This way you keep the superior starter. And even a lot of times I've pulled the cover to the contacts on starters and the contacts weren't seated all the way or properly. Many times you can just clean up the contacts and plunger and smooth out the pitting in them and have a 'new' starter better than any reman.
  18. Jan 8, 2017 at 3:49 PM
    bry838
    oregon
    Very true! Heck i didnt know you could replace wear items in that thing till i learned about it here several years back...
