Going to install additional OEM d-rings. Any tips?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacomaPrime, Dec 29, 2011.
  1. Dec 29, 2011 at 7:57 PM
    TacomaPrime
    TacomaPrime [OP] Cybertronian Tacoma
    Gregory
    Illinois
    14 TRD sport 4x4 Barcelona Red
    Weathertech front floor liners, window vent visors. Custom bedside decals. OEM bed mat, tonneau covrew. Added D rings to bed.
    I got my T-55 Torx and my dremel ready. also have my electric impact gun (don't have an air compressor).
    Should I hit the bolts with PB blaster? If so, should I spray them from the top, or will that hurt the bed material? If I should spray them from underneath, anyone got some pics of what the bolts look like from underneath, or where they are located? The connect to the frame, right?
    Thanks.
  2. Dec 29, 2011 at 8:12 PM
    DOUBLLD
    DOUBLLD Well-Known Member
    Daniel
    Bluemont, VA
    05 Tacoma LS Swap Twin Turbo
    Alot
    take them from the top because the nut is welded to a plate that fits into a slot that makes it not move when tightening or loosening. break it loose by hand first. torx bits suck. Im a toyota tech so i know
  3. Dec 29, 2011 at 8:14 PM
    TacomaPrime
    Gregory
    Illinois
    I know that they have to be removed from the top, but was curious if the pb blaster should be applied from the top or bottom. I don't want to spray the stuff onto the bed material if it's gonna f it up. I don't even know if I need to use the PB blaster. i assume the impact gun should get the job done.
  4. Dec 29, 2011 at 8:17 PM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
    They are a bizalin TPI, strange looking bolt. I added them under the two front and two mid bed bolts, love em.
  5. Dec 29, 2011 at 10:31 PM
    ROGU3 PR3DATOR
    ROGU3 PR3DATOR Space Shuttle Door Gunner
    Jake
    Eagle River, Alaska
    MGM 2011 TRD Off-Road
    Lifted, Supercharged, Armored, and lots more
    Given that the bolts have been there for like 7 years I dont think it would hurt to hit it with pb blaster, and I would do it from the top. I dont think it will hurt the bed liner and even it it does that is what the bet mat is there for. If you dont have one I would recommend it. And I dont think that there is even a way to get to the bolts from the bottom. I think they go directly into the frame and dont come out. Let me know if you find out otherwise. But If you are using a battery powered impact gun you might want to try a breaker par to loosen them first. I love my DeWalt impact driver but sometimes it just doesnt have the power I wish it did.
  6. Dec 29, 2011 at 11:21 PM
    jackrules
    jackrules Well-Known Member
    Jack
    San Diego
    10 PreRunner Double Cab SR5 TRD Sport LB
    Break it by hand
    Just to make sure you don't strip it.
    The bolts do come out from below the frame
  7. Dec 30, 2011 at 6:59 AM
    cverneau
    cverneau Well-Known Member
    Craig
    Cheshire, CT.
    11 Access Cab 4cyl 4x4 Auto
    AVS In-Channel Window Deflectors, AVS Rear Window Sun/Rain Deflector, EGR Front Hood Deflector, Weathertech Digital Fit Floor Liners With TRD Off Road Decals, TonnoPro Tri-Fold Cover, Coverking Black Neoprene Front Seat Covers & Front & Rear Center Console Covers, Black With Red Stitched TRD Head Rest Covers, Rear Grey Neoprene Wet Okole Seat Covers, Black Front Door Handle Pull Covers, Husky Custom Molded Mud Flaps, Devil Horns Of Fire On Satoshi, 7" Off Road Lights Mounted Behind Grill, Pop N Lock 5300, Seatbelt Chime Off, Interior & Exterior Led's, Cubby & Drink Holder Amber LED's, Infinity Reference #9633 6X9 Front Speakers, Solar-Gard HP Smoke 35% Tint, De-badged & Pinstripe Removal, Sun Visor Stickers Removed, Illuminated 4x4 Switch, ImMrYo Rear-View Mirror Lift Bracket, Ultragauge, TRD Aluminum Skid Plate, Bed Storage Cubby Locks Mod, Additional D-Rings In Bed, Rubber Bed Mat, Intermittent Wiper Stalk, Black Vinyl Arm Rest Mod, Secondary Air Filter Removal Mod, Spare Tire Rod Alignment Tube Mod, 14" Antenna Mod, Tailgate Theft Mod, DTRL Wire Jumper Mod, Parking Lights As Turn Signals Mod, Under Hood LED Strip Lighting Mod, 30 Watt Reverse Bulbs, PIAA 510's With LED's In Fog Locations, Cree LED Flood lights In Rear Bumper, Burner Bedlights In Bed Cubby's, Avid Light Bar, Horn Relocation Mod, Rear TSB Springs, Bilstein 5100's on all four corners - front set at 0.85", Cooper Discoverer ATP - 265-75R/16, Pioneer AVH-X3700BHS Head Unit With Microbypass, Added USB Charging Ports Under Dash.
    I'm gonna be doing mine this weekend as well. Two up front & two in the middle. Got the T-55 Torx, wrench and a pipe to use as a breaker bar. I've got the torque wrench (55-60 lbs) for re-installation.
    Here's a question - Should I use Loctite 262 (red permanent) when re-installing the bolts?? I really don't see ever removing these bolts again...
    Also, someone here mentioned stripping the bolts. Has this happened often on these bed bolts?? I realize on older trucks with rusted bolts that's a definite possibility. I've got a 2011, so these should come out pretty easy after breaking them.
  8. Dec 30, 2011 at 7:08 AM
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    No locktite
  9. Dec 30, 2011 at 7:11 AM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    24 Tundra Trd Sport former 13 TRD OR
    Stock for now
    I did this mod to the tundra too.
    It was a nice addition.
    All the tips are great!
  10. Dec 30, 2011 at 7:11 AM
    wolftree
    wolftree Well-Known Member
    Rick
    Ohio
    2011 Tacoma 4x4 Regular cab automatic trans,
    Rear Leaf TSB, Bilstein 5100s, extra leaf added
    I expect he was referring to stripping out the Torx head of the bolts, not the threaded shank.
  11. Dec 30, 2011 at 7:24 AM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    it will be easier than you ever imagined. just go for it.
  12. Dec 30, 2011 at 7:46 PM
    TacomaPrime
    Gregory
    Illinois
    showered the bolts in pb blaster today from top and bottom. I'll let ya all know how it goes tomorrow.
  13. Dec 31, 2011 at 6:42 AM
    Rokon
    Rokon Active Member
    Robert
    Arkansas
    2011 TRD OR DC - Stock
    Are the bolts long enough to install through the bed mat. This may deter bed mat theft.
  14. Dec 31, 2011 at 9:33 AM
    cmoschip
    cmoschip Well-Known Member
    Robert
    Houston, Texas
    2008 TRD Sport DC 4x4
    Hi - dumb question - these OEM D-rings/bolts replace the existing OEM bolts (say the two nearest the cab, for example)?
    Thanks!
  15. Dec 31, 2011 at 9:50 AM
    ImpulseRed008
    Susan
    SC
    No, you use the original bolts, you just put the d rings on them like you would a washer.
  16. Dec 31, 2011 at 4:59 PM
    cverneau
    Craig
    Cheshire, CT.
    Did them today. They were really easy and I didn't need the breaker bar - they came right out. I checked with the torque wrench befor taking them out and they only seemed to be in with about 25-30 lbs of torque.
    Put them in and didn't even bother with the torque wrench - just put them in tighter than what they originally were but not enough to over-do it.
    The four d-rings and the new intermittent wiper stalk I put in today took me a total of a little over an hour.
  17. Jan 1, 2012 at 6:55 AM
    cmoschip
    Robert
    Houston, Texas
    Thanks!
  18. Jan 1, 2012 at 11:45 AM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    Glad to hear. For any future readers...
    I'd suggest hitting from top and bottom with PB, maybe hit the bottoms with a wire brush best you can as well. Be careful with the heads, the Torx bolts like to strip if they're not properly seated, or at least I think so anyway. No loctite, but apply antiseize to make it easier for the next guy taking these out.
  19. Jan 1, 2012 at 1:21 PM
    JKD
    JKD Well-Known Member
    People doing this, when you install the D-rings (I used the military type), you probably want to put the ring right under the head of the bolt, then the washer. That way the washer is still in contact with the bed material.
    To do that, you have to remove the washer from the bolt. To do THAT, you need to grind down the ridges on the bolt shaft just a little. I used a dremel with a drum stone and just went around the bolt once, that's all it needed.
    So when installed, looking from the side, you would have:
    ..........[0000000000] <-- Bolt Head
    ......==============0000000 <--D ring
    ...~~~~~~~~~~~~~~~ <-- Original Washer
  20. Jan 1, 2012 at 1:43 PM
    07TaCo07
    07TaCo07 Well-Known Member
    oregon
    07 double cab 6" lift
    6" fab tech lift, 35" toyo m/t, 17" teflon wheels
    How much r the rings from the dealer
