Going to install additional OEM d-rings. Any tips?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacomaPrime, Dec 29, 2011.
  1. Jan 1, 2012 at 2:13 PM
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
  2. Jan 1, 2012 at 3:37 PM
    TacomaPrime
    TacomaPrime [OP] Cybertronian Tacoma
    Gregory
    Illinois
    14 TRD sport 4x4 Barcelona Red
    Weathertech front floor liners, window vent visors. Custom bedside decals. OEM bed mat, tonneau covrew. Added D rings to bed.
  3. Aug 9, 2012 at 5:58 AM
    pikey
    pikey Member
    Moncton, NB
    08 Tacoma SR5
    Just reading throught the threads on the D ring install as I am going to do it. Seems like the army surplus ones won't swivel unless you do a mod, as I read somewhere on here, but what about the ones from trdparts4u and the OEM ones? Would they swivel, or is modification also required for these, also? The rings are super cheap from army surplus!
  4. Aug 9, 2012 at 6:03 AM
    TacoCat
    TacoCat These pretzels are making me thirsty
    Johnny-5
    Chantilly, VA
    25 Crosstrek Premium CVT (first ever automatic!)
    The ones from trdparts4u are the OEM ones. And they do swivel a bit, actually mine swivel easier than the factory ones near the tailgate. Only regret I have is not buying another pair for the middle bed bolts.
  5. Aug 9, 2012 at 6:17 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    TRDparts4u - $21.25
    Dodge 05104500AA - $3.50
    The dodge ones do swivel.
  6. Aug 9, 2012 at 8:48 AM
    pikey
    pikey Member
    Moncton, NB
    08 Tacoma SR5
    ordered from dodge - thanks!:)
  7. Aug 9, 2012 at 9:18 AM
    Sandman614
    Tim
    '06 SR5 Off Road
    I glad you can use the internet... someone else in another thread asked me where I found them for that price :mad:
  8. Aug 9, 2012 at 9:31 AM
    TerryS
    TerryS Well-Known Member
    Terry
    Cape Cod, Mass.
    '24 Celestial Silver DCLB SR5
    OEM cast aluminum running boards & tonneau cover.
    Thanks for that Dodge part number. I ordered 4 of them. :)
  9. Aug 20, 2012 at 9:30 AM
    tacopoker
    tacopoker Member
    Texas
    Taco 4 banger
    D-Rings that swivel like factory!! See below.
    As I was thinking about adding more d-rings to my 2012 TAco to tie shit down with my engineering mind came up with this,
    1. Remove the front bed bolts.
    2. Measure the bolts O.D.
    3. Buy steel pipe that will freely slip over the bolts.
    4. Drill out the d-rings slightly bigger than the pipe O.D.
    5. Cut pieces of the pipe that are 1/32" thicker than the d-rings.
    6. Place a piece of pipe in the d-ring, slip the bolt thru the piece and
    install.
    7. Enjoy, Done deal.
    Since I'm an engineer and a machinist, I made my own pipe pieces on an engine lathe. I just turned the O.D. on a piece of bar stock smaller than the I.D. drilled in the d-ring, drilled and bored the I.D. bigger than the bolts O.D. and cut them of with a cutoff blade.
    Tools Needed;
    Dial Calipers or Verneers to measure O.D. and I.D.
    Breakover handle w/ wrench to fit bolts.
  10. Aug 22, 2012 at 5:55 AM
    kingston73
    kingston73 Well-Known Member
    North eastern Ohio
    09 SR5 4.0L 4x4
    I just want the double check a couple things before I order. The dodge rings are called "ring,ring retainer", right? And these swivel and don't need any modification to fit using the bed bolts? And are these loud or louder than the factory d rings?
  11. Aug 22, 2012 at 7:02 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    You guys need to get some air tools..... and impact gun... and those bolts come out easily.
    We did this mod about a month ago. Added 4 extra d-rings. Bought the drings from http://www.armysurpluswarehouse.com/
    Impulse Red posted a link - but for some reason, that link isn't working today. I tired searching and it keeps bumping me back to their host server page. They were cheap and very good quality.
    Chencho tacoma likes this.
  12. Aug 23, 2012 at 6:26 AM
    pikey
    pikey Member
    Moncton, NB
    08 Tacoma SR5
    I ordered the dodge ones and they don't swivel. Perhaps a different part number? So, if I feel energetic I'll make up sleeves so I can swivel them...otherwise they are getting bolted in tight! Seem like a good quality part anyway. Not sure what the load rating is.
  13. Aug 23, 2012 at 3:01 PM
    kingston73
    North eastern Ohio
    09 SR5 4.0L 4x4
    So the dodge part doesn't swivel?
  14. Aug 24, 2012 at 12:58 AM
    JKD
    JKD Well-Known Member
  15. Aug 24, 2012 at 6:35 AM
    #35
    Janster
    Jandy
    Lancaster, PA
  16. Aug 25, 2012 at 12:14 PM
    #36
    TerryS
    Terry
    Cape Cod, Mass.
    I just received mine in the mail and no, the Dodge 05104500AA d-rings DO NOT swivel. :mad:
  17. Aug 25, 2012 at 12:36 PM
    #37
    t4daddy
    t4daddy Well-Known Member
    North Alabama
    2008 PreRunner Double Cab
  18. Aug 25, 2012 at 12:50 PM
    #38
    Sandman614
    Tim
    '06 SR5 Off Road
    Because I want swivel.
  19. Aug 25, 2012 at 12:56 PM
    #39
    wolftree
    wolftree Well-Known Member
    Rick
    Ohio
    2011 Tacoma 4x4 Regular cab automatic trans,
    Rear Leaf TSB, Bilstein 5100s, extra leaf added
    If you enter "Dodge 05104500AA" into your search window you can find sites that will take you directly to the Dodge D-rings. Dodge uses a bushing like "tacopoker" made above, allowing the D-ring to swivel.
    Dodge Bushing PN "05104544AA" Cost $2.31 each
  20. Aug 25, 2012 at 1:03 PM
    #40
    t4daddy
    North Alabama
    With even more rattle. Is there a situation where a non-swiveling D-ring would prevent you from securing a load?
