Going to install additional OEM d-rings. Any tips?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacomaPrime, Dec 29, 2011.
  1. Aug 25, 2012 at 1:05 PM
    #41
    tostidos
    tostidos Well-Known Member
    Apple Valley, CA
    07 LT 6spd
  2. Aug 25, 2012 at 2:23 PM
    #42
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Yes, the I want swivel situation. I'll buy the bushings as well.
    Thanks for the bushing number. :) still cheaper than Toyota rings.
  3. Aug 25, 2012 at 2:33 PM
    #43
    TerryS
    TerryS Well-Known Member
    Terry
    Cape Cod, Mass.
    '24 Celestial Silver DCLB SR5
    OEM cast aluminum running boards & tonneau cover.
    Me too, but I wonder if the bed bolt will fit through the bushing.
  4. Aug 25, 2012 at 4:56 PM
    #44
    wolftree
    wolftree Well-Known Member
    Rick
    Ohio
    2011 Tacoma 4x4 Regular cab automatic trans,
    Rear Leaf TSB, Bilstein 5100s, extra leaf added
    TerryS, A drill will make it fit.
  5. Sep 4, 2012 at 11:54 AM
    #45
    pikey
    pikey Member
    Moncton, NB
    08 Tacoma SR5
    yeesh - I picked up the bushings today and it looks like things may be tight to drill these out. Not much room to drill without making the bushing wall too thin. They look to be close to 1" in height too, so I am not sure if this will cause any issues. Might need to take some height off them too.
    I'll size it all up tonight and post my findings.:notsure:
  6. Sep 4, 2012 at 1:54 PM
    #46
    Bobbb
    Bobbb "Rumors of Bob, but never Bob. It is Bob, right?"
    Bob
    Bob
    Bob
    Tundra TRD/OR
    Even easier is just whack the SOB with a BFH. 1-1/16" socket on top w/ scrap lumber block below and 2lb sledge. Washer ends up slightly cupped from doing it this way so I flipped it before re-install. If the cupping bothers you, just use said BFH and whack it flat again.
    I don't have nor care about swivelling, but I would think that a simple nylon washer from yer neighborhood homeless depot both above and below D-ring strap should allow for swivel. Since these aren't torqued to crazy specs it should allow for tightness (no rattle) yet still be movable.
    Sidney Vicious likes this.
