Going to look at an 03
Discussion in '1st Gen. Tacomas (1995-2004)' started by rrflyer, Jul 18, 2010.
  1. Jul 18, 2010 at 12:02 AM
    rrflyer
    rrflyer [OP] Member
    I'm going to look at an 03 TRD 4wd access cab this week.
    Has 80,000 miles on it and is at a local toyota dealership and they are asking 12,000 for it but it does have a color matched camper shell on the back which I would like.
    Can you guys suggest or point me in a direction that might list some things to pay specific attention to?
  2. Jul 18, 2010 at 12:07 AM
    rrflyer
    rrflyer [OP] Member
    I should add that its a 4cyl(which has me worried a little) auto.
  3. Jul 18, 2010 at 1:40 PM
    malander
    malander That's some tight butthole
    max
    Missouri
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    the 4cyl is a beast it'll last for a long time
  4. Jul 18, 2010 at 1:46 PM
    tacomakid96
    tacomakid96 Can you skin Grizz, pilgram?
    Phil
    Out n' about
    2008 Tundra
    4 bangers are frickin bullet proof my dads has 230,000 miles on it and he drives it like shit. Go to youtube and watch how to buy a used powerstroke, the guy has a lisp, but he goes over everthing to look for when buying a used vehicle. He shows it on a diesel but it goes for most everything definently worth watching!
  5. Jul 18, 2010 at 2:02 PM
    oldtacomaguy
    oldtacomaguy four forty four
    Dave
    SE Conn.
    08 SR-5 4WD Impulse Red Pearl
    Alpine deck and amp, Polk speakers front and rear, Kenwood subwoofer, windows tinted to 20%, Sockmonkey decals, TSB, Eibach springs and Bilstein 5100's
  6. Jul 18, 2010 at 3:01 PM
    scocar
    scocar It's not rocket surgery
    Dick
    In close proximity to an undisclosed location
    2015 DCLB 4x4 SR5
    Mostly pallet racks loaded with very impressive boxes, and a smashed head unit
    Check the suspension and ride clsoely. The TRD OEM Bilstein shocks and the coils and leafs are pretty notorious for, uh, sucking. Take it on a freeway with some bumps and curves going fast and see how well it tracks and handles. If it feels like it needs your full attention to keep it in the lane, and the rear end feels like it keeps want to drift out/roll, they are done and need replacement. You can also look at the leaf springs. Even new, they tend to be fairly flat, but they should not be "frowning." They should have a little upturn at the ends, at least. Aslo look for signs of oil leaks/grease coming down the shocks. It ain't real cheap to replace this stuff correctly (better than OEM). I just went through this on my truck with 101k miles (when I bought it). Aftermarket shocks and springs are a vast improvement.
    Another consideratation: if it is 4wd, and Xtra cab, and it has a cap, that is quite a bit of weight and the 4 cyl and automatic is likely not a great power combination. I don't know this from experience with this particular truck, but I would recommend trying to find a 6 cylinder, especially if you drive in hills/mountains much. Without a V6, $12k may be a bit much, in my opinion.
    Also check if the little back window latches are broken, they always break. Also check the door weatherstrip (where you would rest your arm while driving if you ahvd the windo open). These tend to get brittle and not wipe the glass, and the rubber coating over the metal trim dries up and chips off. It is very easy to fix, but still something to nitpick about.
  7. Jul 18, 2010 at 5:47 PM
    gobias
    gobias as in Gobias some coffee
    02 Dbl TRD
    I'd have them take the shell off and let you check the tops of the bed rails for damage. Make sure the shocks, locks, and windows all work on the shell. Check the frame for rust. Make sure they change every fluid before you buy it. Check everything rubber for deterioration. Especially belts, hoses, and cv boots. +1 on the suspension. $12k seems a bit high for a 4-banger but it is a Toyota dealership, after all.
  8. Jul 18, 2010 at 10:43 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor 15x8 D Window Steelies 33" BFG KM2s Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Make sure it actually is a TRD model. Can't always go by it having a sticker. An '03 TRD will always have a button actuated rear differential locker. There will be an obvious button for this on the dash, to the left of the steering column.
  9. Jul 19, 2010 at 5:03 AM
    STLharry
    STLharry Lube: It's the key to penetration.
    Harry
    VT
    Yeti Rescue Package with 270k miles
    '95-'97 camouflaged, ARB bull bar, RAT Products skid plate kit, sliders, Green Mountain Customs rear tube bumper and overland bed rack, King coilovers with Icon neoprene covers, defenestrated sway bar, OME Rear Suspension: CS046R leafs + AAL/5125 shocks/NWOR greasable hardware/U-bolt flip kit; S13WL Tundra calipers/pads/rotors, IPF H4 lenses and bulbs, IPF 968 DCG 100W lights, clapped out CB radio, Aussie-spec FJ60 inclinometer, ARB CKMA12 compressor, Superwinch S9000 with 12V Guy clock switch, 4' Hi-Lift, deckplate mod/grey wire mod/dif breather extensions, Duratrac tires, Sockmonkey bedside decals, boat cupholder, Dakine bike pad
    Not if it is a 4cly auto. 4cyl manuals had the locker as a option but 4cyl autos did not. So he will not have a locker reghardless of if it is a real TRD or not.
  10. Jul 19, 2010 at 10:30 AM
    Digiratus
    Roaming the PNW
    The RedHead
    I don't see how it could be a TRD model if it doesn't have the locker in it. The stickers alone, or even if it has Bilstein HD shocks, don't make it a TRD. Not in the '03 model year.
  11. Jul 19, 2010 at 7:12 PM
    98fourbangertaco
    98fourbangertaco Well-Known Member
    Taylorsville, NC
    98 toyota tacoma, 4wd, SR5, 2.7L, 5-speed
    daystar 2.5in suspension lift kit, detroit truetrac in rear, custom transfer case skidplate, deckplate mod, green high-performance drop in filter, Huskyliner floor mats, 31x10.50 wild country radial mtx tires, yakima roof rack, load warrior basket, stubbs welding rock sliders, arb front bumper with warn 9,000lb winch and procomp black series 100w offroad lights, trail-gear rear bumper, borla exhaust, blacked out factory wheels, shovel mounted on roof rack, de-mudflaped
    I agree with digiratus, i have never heard of a trd model without a locker but theres always a first for everything
  12. Jul 19, 2010 at 7:20 PM
    2000yota
    2000yota Toyota FTW
    Garrett
    Hernando, MS
    2006 TRD Sport
    ive got a 4 banger auto trd without a locker. its a 2000 tho idk if that makes a difference
  13. Jul 19, 2010 at 8:01 PM
    98fourbangertaco
    Taylorsville, NC
    well maybe trd 4cyl auto didnt have a locker, i would have never thought that
  14. Jul 19, 2010 at 8:42 PM
    pittim
    pittim mittip backwards
    Pink slider.
    This.
