Going to synthetic!
Discussion in '4 Cylinder' started by joeyhunter, Mar 24, 2014.
  1. Mar 24, 2014 at 4:35 PM
    joeyhunter
    joeyhunter [OP] Member
    Lebanon,Pa.
    02 Tacoma
    My 02 school just hit 120,000 miles. Any negatives about switching to synthetic oil?
  2. Mar 24, 2014 at 4:36 PM
    Silence9
    Silence9 Solve et Coagula
    Alberta, Canada
    Not that I know of. Some people have claimed they have leaking issues on older vehicles that are worked in because synthetic is generally thinner.
  3. Mar 24, 2014 at 10:26 PM
    Reckless44
    Reckless44 RecklessGrl
    Susie
    Chino, CA
    Tacoma
    Front Suspension: Camburg 4" lift spindles, DR (Icon) Race Coilovers. OEM upper control arms, SS brake lines Rear Suspension: Old Man Emu 3" lift Dakar leaf springs, matching Old Man Emu rear shocks, extended rear SS brake line
    I purchased 0W-30 Mobile 1 Synthetic Oil for my 05 Tacoma. I think I screwed up on the correct viscosity and wanted to know if it's ok to use this or should I return it and get 5W-30??? :confused:
  4. Mar 24, 2014 at 10:29 PM
    kyleTRDtaco12
    kyleTRDtaco12 Well-Known Member
    Kyle
    New Jersey
    2012 Toyota Tacoma Base DCSB 4x4 V6 6MT (202)
    TRD Cat-Back Exhaust TRD Sport Package Springs & Shocks (Front Linear Coil Springs, Rear TSB Leafs) Front & Rear Toyota/Bilstein 40mm Shocks) Silver Toyota 16" SR5 Wheels with 265/70/16 BFGoodrich Rugged Trail T/A Tires w/ Locks OEM Black-Chrome Housed Headlights (SR package) OEM TRDpro Grille Insert RokBlokz Rally MudFlaps w/ Stamped Logo OEM 'TRD Sport' Bedside Graphics TRD QuickShifter w/ TRD Shift Knob Hawk HPS Front Brake Pads w/ Brembo Blank Rotors OEM Front Aluminum Skid-Plate eBay TRD seat covers Rear Diff. Breather Mod A/C Drain Extension Mod OEM Fog Light Kit OEM Intermittent Wiper Switch OEM Bed D-Rings OEM Bed Mat OEM Door Sill Protectors Blacked-Out Badges (from Xrunner 205 Black Sand Pearl) Pop & Lock Tailgate Handle TruXedo TruXsport Roll-Up Tonneau Cover AVS BugFlector II Front Bug Guard AVS In-Channel Window Vent Visors TRD High Pressure Radiator Cap Stubby Radio Antenna Ultra-Gauge EM v1.2 w/ Windshield Mount BullaCulla 7-Pin Relocation Bracket Misc. Stickers
    Oh god, deff go back to 5w-30 asap, cant use 0w anything in any tacoma lol, unless its a 4 cylinder, I think newer 4 cylinders use 0w-20
  5. Mar 24, 2014 at 10:34 PM
    kyleTRDtaco12
    Kyle
    New Jersey
    Lol yeah I made the edit when I remembered, I had a brain fart for a couple seconds lol, I used 0w-20 in my 2010 corolla xrs 2.4L when I still had it lol.... but yeah if her truck isnt a 2.7 then deff shouldn't be using 0w anything lol
  6. Mar 24, 2014 at 10:36 PM
    kyleTRDtaco12
    Kyle
    New Jersey
    But getting back to the subject at hand, personally I wouldn't switch to synthetic, especially on that high of milage, conventional is just fine, just use a good filter, like toyotas OEM filters.
  7. Mar 25, 2014 at 1:40 AM
    Reckless44
    Susie
    Chino, CA
    Tacoma
  8. Mar 25, 2014 at 1:55 AM
    Coast2Coast
    Coast2Coast Well-Known Member
    Northern Alberta
    2009 TRDOR
    Black Sand Pearl factory paint - flattened "au natural" by tree branches.
    My 99 is on synthetic at 200,000miles, no worries.
    For the other question 0w20 is recommended in the 05-09 v6 tundra, which has the same engine as the 05+ v6 tacoma. So if it's easier I'd just use it since you have it, then switch to 5w30 on the next oil change. I saw a pole on here that said most people use mobil 1, which is what I've always used.
  9. Mar 25, 2014 at 2:05 AM
    Reckless44
    Susie
    Chino, CA
    Tacoma
    Thank you!!!! :)
  10. Mar 25, 2014 at 8:01 AM
    txusa03
    txusa03 Well-Known Member
    Is Mobil1 0w40 synthetic ok to use for a 2009 2.7l tacoma?
  11. Mar 25, 2014 at 5:00 PM
    Silence9
    Alberta, Canada
    I thought this at first too, then several people argued that it doesn't matter when you switch to synthetic.
  12. Mar 25, 2014 at 5:32 PM
    kyleTRDtaco12
    Kyle
    New Jersey
    personally, idk why there should any thought put into buying oil/filters when you could just go down to the toyota dealer, pay approx $35 for a case (12 quarts) of oil specially formulated for toyota engines and filters from the dealer cost, what $6 a piece?? it just makes sense to use dealer oil/filters.
  13. Mar 25, 2014 at 5:37 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    May be less of an issue if you keep the same grade, i.e. use 5W30 synthetic instead of 0W30.
  14. Mar 25, 2014 at 5:40 PM
    KenLyns
    Belly of the Beast
    Not sure if sarcastic.
    0W30 is OK because it's the same viscosity as 5W30 at operating temperature. 0W20 is iffy because the oil is thinner when at operating temperature, so testing is needed to make sure it's OK. Toyota did testing on the 2.7L and found it ecked out an extra 1 mpg to make the EPA ratings look better on paper, so now 0W20 is required on the 2.7L.
  15. Mar 25, 2014 at 5:42 PM
    jeremy_283
    jeremy_283 Super Member
    08 TRD Offroad Access Cab 4x4 Auto 4.0L
    Hella Rallye 4000 Cornering Lights PIAA 510 Fog Lights All Pro Front Bumper All Pro Rear Bumper All Pro Transfer Case Skid All Pro IFS Skid All Pro Rock Sliders All Pro High Clearance Hitch OME Dakar Leaf Springs OME Rear Shocks OME Front Shocks OME 885 Front Coils Wet Okole Seat Covers WeatherTech Floor Liners Sony Head Unit JL XD600/1 Amp 2 JL Audio 10” Subwoofers Custom Subwoofer Enclosure Kenwood Front Speakers Sony Rear Speakers Sound Deadening Mats LED Interior Lighting Pop N’ Lock Tailgate Lock Viper Alarm System Extra D-Rings In Truck Bed Maglite Seat Mount Disable Seatbelt Chime Rear Differential Breather Relocation Hi-Lift Bed Mount Flexible Front Mud Flaps 110v Inverter Always At 400w ABS Kill Switch Locking Center Console Removed Sway Bar
    Honestly, if i had just obtained a truck that 120,000 miles ran on standard oil I probably wouldn't change it.
    No need to mess with what the engine's internals have become accustomed to.
    I run synthetic but I started synthetic with my first oil change.
    I don't really know what I'd consider a cutoff point to make the switch.
  16. Mar 25, 2014 at 5:53 PM
    kyleTRDtaco12
    Kyle
    New Jersey
    its not sarcastic, but i seriously wouldnt use 0w anything in a V6 tacoma... i didnt know if renegade had a 4 or 6 cylinder, then i later saw she has a v6... just use whats suggested in the owners manual, the manual was written for a reason is all im trying to get at.
  17. Mar 25, 2014 at 6:34 PM
    Silence9
    Alberta, Canada
    60% of the time, reading the oil cap works 100% of the time. :)
  18. Mar 25, 2014 at 10:07 PM
    Reckless44
    Susie
    Chino, CA
    Tacoma
  19. Mar 25, 2014 at 10:15 PM
    Reckless44
    Susie
    Chino, CA
    Tacoma
  20. Mar 26, 2014 at 8:18 AM
    txusa03
    Reckless, thanks for the awesome link and the bad news (for me) is 0w40 is not on the list for use with a 2.7 l NA tacoma engine. But 0w20 is on the list for that engine.
    It is bad news b/c I have 14 quarts of mobil 1 0w40 now I need to figure out what to do with the oil.
