Going up a size/TPMS
Discussion in 'Wheels & Tires' started by buggravy, Jan 27, 2019.
  1. Jan 27, 2019 at 1:06 PM
    buggravy
    buggravy [OP] Well-Known Member
    Calabasas, CA
    '19 TRD Offroad
    I feel like this info has to be here somewhere, but I couldn't find it. Thinking of going from stock size 265/70/16 tire to a 265/70/17. Would probably sell the current setup lock stock and barrel so that the buy has mounted, balanced wheels with fully functioning TPMS. I assume I just need to purchase new sensors and have them programmed, but is there any issue with going up a size as it pertains to TPMS? Will I retain all the functionality, i.e. warning light and current pressure read out in the dash info?
    AugustusJack likes this.
  2. Jan 27, 2019 at 1:09 PM
    Shikokaon
    Shikokaon Slacker Extraordinaire
    Portland, OR
    2017 Tacoma D-Cab Off Road (MT)
    As far as i know (and from when i switched to 285s), no issues with tpms.
    I kept stock ones, but from others i havent heard of any issues if replaced, and new ones programmed into system.
  3. Jan 27, 2019 at 1:10 PM
    AugustusJack
    AugustusJack Well-Known Member
    A.J.
    NW WA
    '19 DCLB OR, '00 XC 3.4L 4wd MT
    No idea myself. Seems straightforward, but bumping all the same
  4. Jan 27, 2019 at 1:56 PM
    4WD FTW
    4WD FTW Well-Known Member
    '08 DC LB 4x4
    Icon Suspension Kit Pelfrey Bumper and Skid 4.56 Gears Detroit TruTrac Rear Archive Hammer Hangers Deaver U402 Stage 1
    Tpms will function perfectly normal regardless of tire/wheel size. The only complication is with stock toyota sensors - they are specific to steel/alloy wheel types. But, that won't affect you. Almost all aftermarket sensors work on all wheel types.
  5. Jan 27, 2019 at 2:01 PM
    LSUfan1975
    LSUfan1975 Well-Known Member
    Eric
    Washington NC
    2019 SR5 Dbcb MGM
    Mine work fine. Again on stock rims though. Just bigger tires.
