Going up in tire size,limits
Discussion in '2nd Gen. Tacomas (2005-2015)' started by .Randy Bullard, Apr 14, 2015.
  1. Apr 14, 2015 at 9:36 PM
    .Randy Bullard
    .Randy Bullard [OP] Member
    Randy
    North Florida
    in market
    I have a base 2wd 4cyl and want to go up one size to a 225-75-15,or a comparable size in a 16" rim..I've been looking at possibly a factory 16",and notice they are 1" wider..Is this a concern? Also,in a 16" what tire what would be closest equal to a 225-75-15? Another point,I'm only interested in filling up the wheel well a little,and don't want to compromise mileage and want a quiet smooth riding tire with the minimal "legal" load rating..thanks for the input! Randy
  2. May 12, 2015 at 6:12 PM
    10taco2wda
    10taco2wda Member
    Dan
    South dakota
    2010 Tacoma 2wd
    Non yet
    Randy I'm in the same spot. Want bigger rims and tires but don't wanna sacrifice anything either. Did you end up finding the perfect size?
  3. May 12, 2015 at 8:33 PM
    NMTrailRider
    NMTrailRider Well-Known Member
    New Mexico
    sounds like 265-75-16 is the largest you can go on a 16" rim without rubbing. in theory you'll lose a little in mileage/acceleration, which some have reported, but not drastic. I got that info here on the forum. I imagine that would be amplified with a 4cyl. you could also do a LT235-85 (taller/skinnier) but that tire only comes in an E rating (stiffer rubber, rougher ride from what I've been told).
  4. May 12, 2015 at 8:37 PM
    NMTrailRider
    New Mexico
    FYI I have michelin ms2's in a 245-75-16 and they're awesome. super smooth ride and the quietest tire I've ever had on a truck. not big, but a nice size for this truck as far as a compromise between looks/function.
  5. May 12, 2015 at 8:46 PM
    NMTrailRider
    New Mexico
    if you're moving up from 15's, and want a little bigger without a big sacrifice elsewhere, I think you'd like the 245's. Hope this helps. I don't think I'd go bigger than the 245's on an 4cyl auto, but maybe someone else has some insight for you. in a first gen, yes. but not in a 2nd gen.
  6. May 12, 2015 at 8:48 PM
    medic2230
    Murph
    Bama! Roll Tide
    I believe he is talking about the regular 2WD not the prerunner 2WD.
  7. May 12, 2015 at 9:11 PM
    NMTrailRider
    New Mexico
    ah, gotcha. my mistake.
  8. May 13, 2015 at 8:23 AM
    10taco2wda
    10taco2wda Member
    Dan
    South dakota
    2010 Tacoma 2wd
    Non yet
    Yes I have a 2010 base 2wd. But this is the info I wanted. So thanks guys. Looking into Vision Warrior wheel with 235 70 16 tires. Thanks for the help guys.
  9. Jan 30, 2016 at 7:31 PM
    .Randy Bullard
    Randy
    North Florida
    in market
    As yet still on stockers,but I briefly drove a Frontier xcab sv model with much larger tires and wheels(but it looks like ANY truck comes w bigger than these 215-70-14's on mine) and was amazed how much better it handled road imperfections.Wasn't sure if it was mostly attributed to the bigger wheels/tires or not..I just know those tires look goofy as hell in those big wheel wells on mine,and this is one rough riding truck. Also,are all 5 bolt Toyota wheels interchangeable,bolt pattern,offset,rubbing etc..I don't want to jack the suspension up,or lose much power/mileage.help.! Lol,Thanks!
