Goldwing in a Tacoma?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Number 18, Jan 19, 2012.
  1. Jan 19, 2012 at 9:54 AM
    Number 18
    Number 18 [OP] Member
    Rick
    Savannah, GA
    2010 Access Cab PreRunner
    Has anyone loaded a Goldwing in the back of their Tacoma? I have a 2010 Access Cab and would like to be able haul the Goldwing in the back. I've read horror stories about tailgates failing. The Goldwing weighs ~800lbs.
  2. Jan 19, 2012 at 10:03 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I'd seriously consider a trailer for a bike that big. That thing would be a beast to get into and out of the truck bed. If you do haul it in the bed, I'd definitely look into either internal steel reinforcing for wood to go under the tire and spread the weight across the tailgate (plywood that runs from the front of the bed to the rear of the tailgate works or relentless fab makes a steel cover that adds rigidity). Make sure you have secure tie down points, I'd put d-rings on the frame bolts, that's a heavy bike!
  3. Jan 19, 2012 at 10:06 AM
    Zac808
    Zac808 Custom User Title
    Zac
    Viva Las Vegas
    08 TRD DC SB 4x4
    In my sig
    ^^What he said.
  4. Jan 19, 2012 at 1:02 PM
    speedydave
    speedydave Well-Known Member
    Dave
    Hickory, Nc
    Mustang GT
    I have hauled my Ducati with no issues, but it weighs less than half of your Goldwing.
  5. Jan 19, 2012 at 1:11 PM
    Boerseun
    Boerseun Well-Known Member
    Ferdie
    Sarasota, Florida
    2018 Tundra TRD Sport 4x4
    Upgraded 2002 Tacoma to 2018 Tundra
    I would rather use a trailer. (That Goldwing can probably pull the Tacoma on a trailer)
  6. Jan 19, 2012 at 1:12 PM
    Warhorseforever
    Warhorseforever Will The Thrill
    Will
    Sand Lapper
    2001 Toyota Tacoma Pre-Runner SR5
    Kenwood KDC-348U HU Kicker DS65 Front Doors Only 2 Polk Audio MM840 Kenwood KAC 8105D for subs SuperCrewSound.com behind rear seat sub box
    Trailer it defiantly I wouldn't trust that much weight on the tailgate even with the re-enforcements.
  7. Jan 23, 2012 at 9:14 AM
    Number 18
    Rick
    Savannah, GA
    Guys, I understand and appreciate the advice. I have a trailer and use it occasionally. I'm just trying to find out if anybody more brave than I am has put a Goldwing in the bed of their Tacoma.
  8. Jan 23, 2012 at 9:19 AM
    Warhorseforever
    Will
    Sand Lapper
    Well imo it's a bitch to get a 500 pound dirt bike in the back of a truck with any kind of height to it much less a 1000+ pound gold wing. I'm sure it can be done without any problems and be put in the bed without any problems but I wouldn't do it myself.
  9. Jan 23, 2012 at 9:22 AM
    Sunner
    Sunner Well-Known Member
    Your DB weighs 500lbs!? :eek:. I thought they were supposed to be light. My sportbikes weigh less than 400.
  10. Jan 23, 2012 at 9:25 AM
    Syncros
    Syncros Well-Known Member
    I think it would be fine, just put a sheet of plywood under the rear tire to spread the load. The trac system holds my KX250 up o.k. (230lbs) but I added D rings up front to be safe.
  11. Jan 23, 2012 at 9:30 AM
    Warhorseforever
    Will
    Sand Lapper
    Yea may have exaggerated that number a little bit. :eek: My old KX80 wasn't but 200 and my CRF probably 250-300. The last bike I've ridden/loaded was a KLR650 and that's every bit of 400. You have to forgive me I've been out of the ridding world for about 2 years since I wrecked my bike and dislocated my hip. I'm done with dirt for a while because there aren't any good places around here to really ride without spending a small fortune to get there.
  12. Jan 23, 2012 at 9:31 AM
    Pugga
    Massachusetts
    x2, that's a heavy bike for the dirt! My 750 doesn't weigh that much.
    If you already have a trailer, I wouldn't even attempt putting the Goldwing in the bed. Nothing to do with brave, it's just not a good idea if it can be avoided in my opinion.
  13. Jan 23, 2012 at 9:32 AM
    PAlittlematty
    PAlittlematty "the soulless ginger"
    Beech Creek, PA
    I miss my taco
    OME Lift, 885 Coils, 13MM Top Spacer, Dakar Leafs, DSM UCAs, Homeroshi Flush Mount Grille, WeatherTech Digifit Mats, Bestop Super Top, Toyota Bed Extender, Clevice Receiver 1990 SR5 3.slow SAS 5” Leafs, high pinion diff, 37” PBRs, MC rear, AP front bumpers, 5.29s, locked
    Only dirtbike I've ever seen that weighed that much was "the dirtwing". Xr650 frame with an 1800cc goldwing motor in it. Raced a hare scramble or two with it. Od for sure trailer a wing. They're way too big to be hauled in the bed of a midsize pickup
  14. Jan 23, 2012 at 10:57 AM
    FirsTaco
    FirsTaco Well-Known Member
    Jeff
    Reading, MA
    '22 Ford Bronco Badlands
    You know how I know you should not own a GoldWing? You want to put it in a truck, do your self a favor and go to the nearest Hardley dealer and trade in that wonderful bike for one of there bikes they are much more suited for being hauled around.
    But on a more series not I would not put a Goldwing in the back of the taco or most other trucks use a trailer.
  15. Jan 23, 2012 at 11:44 AM
    Omar
    Omar Well-Known Member
    New Jersey
    TRD Sport Access Cab
    I once picked up a goldwing for a dealer swap at work and used my 97 Tacoma. No problems at all. But they did use a platform on a forklift to load it and we used the same to unload it here. I'de imagine using a ramp with that size of a bike would be tough!
  16. Jan 23, 2012 at 2:08 PM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    I have had dad's KLR650 in the back of mine, idk how much it weighs but its nowhere near that much! Also have drove the Grizzly 660 ATV we have back there without problems and it weighs over 600
  17. Jan 23, 2012 at 4:01 PM
    Omar
    New Jersey
    also I load 2 track bikes (zx-6r and gsxr750) in mine all the time with no problems driving 9+ hours straight
  18. Jan 23, 2012 at 4:25 PM
    fjrmurph
    fjrmurph Well-Known Member
    If you can find a way to load it, loading ramp maybe. Put some extra support on top of your tailgate and make sure its tied down well. I don't see why you wouldn't be able to haul the Goldwing. The rubber mat would be good to make sure it doesn't slide around !!
    MY 2 cents
  19. Jan 23, 2012 at 4:26 PM
    Tookie
    Tookie Well-Known Member
    Port Vincent, LA
    2009 DC TRD Sport
    This is mine, I wouldn't dream of loading it into ANY truck,
    without a lot of help... when it leans too far, it IS going
    to go over.. all you can do is get out of the way. :D
  20. Jan 23, 2012 at 4:28 PM
    NumNutz
    NumNutz One of the original 7928
    Virginia Beach, VA
    07 Tacoma 4x4 - Kings, TC, Dakars, broken stuff
    Lots.
    Any bike that comes with reverse should not be loaded in a pickup.
