Gone: Fox 2.0" Coilover (Single) | 05-22 Tacoma × 2
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by daveeasa, Oct 13, 2022.
  1. Oct 13, 2022 at 3:52 PM
    daveeasa
    daveeasa [OP] FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    Gone, no longer available.
    Purchased new from HotShot OffRoad in June of this year. All road miles, maybe 2-3k worth including one 1k drive as I moved in August. Too stiff for my '05 RC and just got swapped out today.
    FOX part number: 985-02-002
    These are 2.0's, no remote reservoir, no DSC.
    JFanaselle likes this.
  2. Oct 13, 2022 at 3:53 PM
    daveeasa
    David
    PNW
  3. Oct 16, 2022 at 5:42 PM
    daveeasa
    David
    PNW
    Bump and also willing to deliver in November anywhere between San Diego and Portland along the I5 corridor and maybe even closer to 101. Also might be open to a trade for something cool. Let's find these a home, yeah? They aren't bad at all, just need a heavier front end than my '05 RC at 3400 lbs.
  4. Oct 16, 2022 at 7:40 PM
    MGMDesertTaco
    Bumpity bump. Without a part number I'm going to assume these fox 2.0's don't require uca's?
    I was tempted, but I'm somewhere in between ordering 2.5 fox elites/n98 deavers from accutune and trading for a ford raptor if I can find one for msrp. Might have to wait for the 2023's. :annoyed:
    GLWS! :hattip:
    daveeasa[OP] likes this.
  5. Oct 16, 2022 at 7:42 PM
    daveeasa
    David
    PNW
    Oh yeah lemme go hunt for a number on these things.
    I had them on with stock UCA and stock wheels and tires, no problems other than too stiff for my wimpy truck.
    MGMDesertTaco likes this.
  6. Oct 16, 2022 at 7:49 PM
    daveeasa
    David
    PNW
  7. Oct 16, 2022 at 9:28 PM
    stan23
    stan23 Well-Known Member
    stan
    Santa Clara, CA
    2025 DCSB TRD Sport 4x4
    I have these same coilovers on my truck and the ride is really good. From fox if the preload was never adjusted, you get a nice 1" lift on a 3rd gen. You can adjust up to a 2" lift. This is a great price!
  8. Oct 17, 2022 at 5:07 AM
    daveeasa
    David
    PNW
    Thanks for the bump. Note that Jason (aka speed freak) did adjust the preload for me, mostly to attempt to soften the ride quality for the truck. So, at present time, it is likely going to be close to stock height or maybe a very small lift. There are some small scratches on the collar from that adjustment and some scrapes on the springs from a very small rub with the anti sway bar which was addressed after the alignment shop pointed it out. I did not treat these like delicate heirloom fine china, but I didn’t beat on them either. They don’t look ugly but they aren’t new anymore.
    I suspect they would be a solid upgrade for any DCSB? Just needs more weight than my wimpy I4 2wd RC could provide.
  9. Nov 11, 2022 at 1:19 PM
    daveeasa
    David
    PNW
    Who wants a reasonably priced upgrade up front. These are adjustable height, 0-2” I think?
  10. Nov 11, 2022 at 1:24 PM
    Brian422
    Brian422 I fell into the pit that is TW
    Brian
    Birmingham, AL
    2012 DBCSB F/R Locked, 35's ,Long travel, 23 Tundra 4x4 limited
    Not Stock
    Just wondering why you didn't change spring rate if they were just too stiff?
  11. Nov 11, 2022 at 1:36 PM
    daveeasa
    David
    PNW
    1. Because I’m an idiot?
    2. Because Accutune advised me to get a shock that can be tuned
    3. Because I really wanted someone else to own the proper solution.
    4. because I moved and wanted a “bolt on and done” solution
    I did discuss that with Accutune. They wanted TC UCA’s too and their shock tuning. I went with exactly what they suggested and 550’s. The first shop bungled the install and my collars wound up cross threaded. 2nd shop destroyed the collars trying to eliminate 2” squat. Ordered new collars from Accutune. Now I have 1” squat with no threads showing. So I’m in process on ordering 500’s.
    Quite the drama. I might just take the truck out to the middle of nowhere and set fire to it.
