Gone mod-wild....
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dvst8r1K, Apr 8, 2017.
  1. Apr 8, 2017 at 4:13 PM
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 SUPERCHARGED DCLB TRD SPORT
    6' Salvadoreño here but close enough lol!
  2. Apr 8, 2017 at 4:20 PM
    Justinlhc
    Justinlhc Not looking for a relationship
    I'm white as snow and still short. :anonymous:
    I prefer the seat spacers in the rear mounts only. That way I don't feel like I'm leaning back.
    Texas_Christo likes this.
  3. Apr 8, 2017 at 4:23 PM
    themanbearpig012
    themanbearpig012 Well-Known Member
    Rudy
    Nipomo, Ca
    2015 DCSB TRD SPORT
    Fox 2.5 Factory Series Coil-Over Reservoir (Front) Fox 2.0 Performance Series IFP (Rear) Method "Mesh" 17x8.5|6x5.50|0/4.75" wheels
    yeah thats kinda how i feel when i'm sitting. not a bad idea to do that
  4. Apr 8, 2017 at 5:08 PM
    Dvst8r1K
    Dvst8r1K [OP] Night-Taco
    Greg
    2nd gen Black Tacoma SS 4.0l 4-dr 4x4
    1" Toytec body-lift, K&N filter, coolant by-pass, mesh cotton screen delete, TTBS, WeatherTech in channel visors, 2.5" Rancho full suspension kit, Oil Catch Can, Toyo 285/70 A/T-2's, 21.5" light bar in grill, blacked-out grill, de-badged entire truck; and again, more to come.....
    Yeah, my 6'4" buddy at 4wp drove my truck around and liked the seating arrangement/position, and I agree, tho I'm a bit shorter, some slight adjustingand I'm good. He said lots of people do it.... I see why...
  5. Apr 8, 2017 at 5:10 PM
    TheDuke0fHurl
    TheDuke0fHurl Well-Known Member
    Boston
    2013 DCLB SR5
    Where do you get the spacers?
  6. Apr 8, 2017 at 5:20 PM
    Dvst8r1K
    Greg
    Autozone has an 8-pack polyurethane shock bushings.... That's what those are... The seat isn't sitting on metal, and I like the ride. You wouldn't think it makes a difference, but try them and let me know what you think.. Maybe $20.00 spent on them, or less??
    If you like the difference polyurethane body mounts make, you'll like the way these will feel. You may ha e to take a larger diameter drill bit to make them work with the seat-bolts, but they will work..... In red or black as usual....
  7. Apr 8, 2017 at 5:23 PM
    TheDuke0fHurl
    Boston
    2013 DCLB SR5
    Did you do front and back or just front?
  8. Apr 8, 2017 at 5:27 PM
    mattgecko
    mattgecko The LED Lighting Guy. MattGeckoLEDs.com
    South San Jose, CA
    2011 DCSB O.R. 4wd TRD Super Charged
    The seat bushings are a neat idea, I'm 6'6" might give front only bushings a try.
    Have fun with the build!
  9. Apr 8, 2017 at 5:28 PM
    Dvst8r1K
    Greg
    Front and back... If you're tall, it just depends on the angle you want the seat to be at...
  10. Apr 8, 2017 at 5:36 PM
    Dvst8r1K
    Greg
    You can always unbolt all 4 seat bolts, position the bushings where you want the seat positioned and start work.... The work being if you install all 4 bushings, you'll have to drill an oval out of the factory seat holes so that the bolts can be re-installed/due to the new angle and height the bushings will leave the seat at, and after that, install bushings, start each seat screw at least 1/2 way in, then finish tightening, and you're done....
    Cruzordie and mattgecko like this.
  11. Apr 8, 2017 at 5:43 PM
    Clearwater Bill
    Billy
    Largo Florida
    Yeppers.
    Shwaa[QUOTED] likes this.
  12. Apr 8, 2017 at 6:03 PM
    Justinlhc
    Interesting. I'm not sure how I feel about the safety of that, but it's probably ok, right? :notsure:
    Did it really make a difference? :confused:
  13. Apr 8, 2017 at 6:11 PM
    Dvst8r1K
    Greg
    Now that you mention it, I think I purchased some longer grade 8 bolts because the factory bolts not being long enough with the spacer. The longer bolts will go in as much as the factory did having the extra length...... I just checked, and they are longer bolts. Sorry I didn't catch this earlier, but thanks for mentioning it...
    Safety wise. It can't be much different than a factory bolt.... I been wheeling, stopping abruptly, and zero movement from the seats....
  14. Apr 8, 2017 at 6:19 PM
    Dvst8r1K
    Greg
    I guess about the same difference polyurethane body-mounts would make. The thing is, metal on metal, rough. Polyurethane between metal, comforting..... Like all and any mods, you don't have to do them, and it's all about preference and differentiality, and up to you...
  15. Apr 8, 2017 at 6:42 PM
    #35
    Justinlhc
    I wasn't downing it, I was asking because I was interested and have never seen it done. :cheers:
  16. Apr 8, 2017 at 6:52 PM
    #36
    Dvst8r1K
    Greg
    It's all good, no offense taken. Longer grade 8 bolts to make up the difference in the bushings, and it's just like factory, which only go in about an 1"1/2... Plusit gives you room to mount a amp underneath or something...
  17. Apr 8, 2017 at 7:06 PM
    #37
    Dvst8r1K
    Greg
    Plus, of you like forwarding water, there's an extra inch for you before your but gets wet.... Lol!!!
  18. Apr 8, 2017 at 8:09 PM
    #38
    Sub_Par
    Sub_Par Well-Known Member
    Buffalo NY
    2011 TRD Off Road
    Forwarding? Like you get ahead of the water?
    3pooches likes this.
  19. Apr 8, 2017 at 9:07 PM
    #39
    Dvst8r1K
    Greg
    Watersports, if you like watersports.......
  20. Apr 12, 2017 at 5:20 AM
    #40
    Blais03
    Blais03 Guess I'll bring a spare wheel bearing...
    Nick
    Easthampton MA
    '08 Reg. Cab 4WD + '06 Reg. Cab 2WD
    did you make or buy these splash guards? What are they and where did you get them? I also have a 1 inch body lift and need to replace mine.
