Gonna bite the bullet and ask a stupid question.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BrokenCoastie, Feb 3, 2020.
Does mudding destroy pullys?
  1. Yes, dont do that, you are dumb if you do.
    40 vote(s)
    42.1%
  2. No, dont be a wuss.
    55 vote(s)
    57.9%
  1. Feb 3, 2020 at 12:04 PM
    BrokenCoastie
    BrokenCoastie [OP] Nonsolis Radios Sediouis Fulmina Mitto
    James
    East Bay area
    ‘17 TRD OFF ROAD
    I recently had a whine in my engine bay. Turned out to be every single pully and the alternate clutch. All replaced under warranty. Does a little bit of mud and water typically do such damage? Ive see people literally go up to the hood in water. Are they just asking for it like apparently I was? Am I to stay out of the mud? Or was I just unlucky or did I do something stupid? Better asked as did my stupid cause this?
    Thatbassguy likes this.
  2. Feb 3, 2020 at 12:09 PM
    chaotic_taco
    chaotic_taco Well-Known Member
    ATX
    2017 DCSB TRD OR MT
    How many miles? How deep do you go? How well do you clean up after?
    Cementoffroad and Mully like this.
  3. Feb 3, 2020 at 12:11 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    Im sure if you off road in muddy conditions constantly and it gets on belts and pulleys, eventually it will wear them out quicker than usual. The sand is abrasive so im sure its not the best thing for the engine bay.
    Just my .02c. Good luck!
  4. Feb 3, 2020 at 12:11 PM
    slick7108514
    slick7108514 Well-Known Member
    Arizona
    2018 White Tacoma TRD Offroad DCSB
    I had a horrible squeal after a recent muddy off roading trip. Dealer replaced belt under warranty. I also found it odd that mud could cause such a problem.
  5. Feb 3, 2020 at 12:14 PM
    BrokenCoastie
    James
    East Bay area
    ‘17 TRD OFF ROAD
    27k, deep enough to get mud splatter on the underside of the hood. And, I rinse careful of the alt.
  6. Feb 3, 2020 at 12:14 PM
    MR E30
    MR E30 Well-Known Member
    Michael
    Wherever it's parked
    2021 Silver TRD OR DCLB w/ AluCab and All the Mods
    I've never been incredibly muddy, but I have done some engine bay dunking with no long-term ill effects.
    [​IMG]Day 1 - AWC - 22 by Michael Rickerd, on Flickr
    After this plunge I had a slight squeal for an hour or so but it went away completely before I finished the trial.
  7. Feb 3, 2020 at 12:14 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    If they get wet at all, they whine and shortly after will blow out
    slander, Mully and Junkhead like this.
  8. Feb 3, 2020 at 12:18 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Sounds like you wheel at an industrial hazardous waste site. On the beach and mud is fine.
    Mully likes this.
  9. Feb 3, 2020 at 12:21 PM
    crashdb
    crashdb I break chainsaws
    Dave
    Manassas, VA
    2008 Toyota Matrix
    Rollin' hydrocarbons!
    Last time I got dirty I had a lovely squeal after a few water crossings. It lasted a little longer that I thought it would; even after a two ride at highways speeds. It finally went away and has been fine since. If it keeps being a problem I'll try a good brand of belt and go from there.
  10. Feb 3, 2020 at 12:24 PM
    BrokenCoastie
    James
    East Bay area
    ‘17 TRD OFF ROAD
    Was mostly in NJ...
  11. Feb 3, 2020 at 1:35 PM
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    These could all be misinterpreted very easily
  12. Feb 3, 2020 at 1:37 PM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    Are we still talking about his truck?
  13. Feb 3, 2020 at 1:41 PM
    dr4g1116
    dr4g1116 Well-Known Member
    2019 Silver Sky Metallic TRD OR SB M/T
    Not sure why anyone is saying no.
    The dirt and dust of the Pines (I'm assuming that's where you went) can absolutely get into your pulleys and help wear down bearings and lubrication. Been wheeling there with my Jeep for years and absolutely saw pulleys wear faster than normal. That said it was mostly idler/tensioner pulleys. My AC and PS were original.
    Edit: you're not dumb if you do. You're dumb if you go off roading and DON'T expect to replace things a little earlier than usual. It's just the name of the game. Never go off road if you can't afford to fix or tow your vehicle.
    Joe23, pa blaster, SR-71A and 3 others like this.
  14. Feb 3, 2020 at 6:18 PM
    Aquatic Tacoma
    Aquatic Tacoma Well-Known Member
    Odessa, Fl.
    2019 Tacoma TRD Sport 4x4 Dbcb , 2004 Tacoma S-Runner
    Both are Stock - built correct from the start.
    Back in the day I ran a shop where we ran our company Tacos off road in the sometimes swampy areas of Florida. We'd get belt squeal form deep water. Carrying a little can of spray belt dressing in our tool boxes cured it. I think it was Permatex, but Im sure there are other brands out there. If the alternator, tensionor, etc., bearings take a water hit, not so simple.
  15. Feb 3, 2020 at 6:28 PM
    Kevin Jones
    Kevin Jones Well-Known Member
    Kevin
    Va
    1996 Tacoma - 2018 Tacoma
    Yes, definitely but probably not as bad as tightening your belts too tight.
  16. Feb 3, 2020 at 6:47 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Mudding destroys all. Just Battle scars, enjoy!
    Joe23 and Chew like this.
  17. Feb 3, 2020 at 7:00 PM
    Cudgel
    Cudgel “Tonka”
    Live in: An Ocean of Plastic Trash
    2017 OR DCLB
    ICON8 Lift -285s. upTOPoverland rack.
    Certain algae and fungi/lichen will impact belts, seals and idlers. This is especially true in mid Atlantic states or equatorial marshlands. Annealing is rare from biological sources but can occur from mineral deposits in output waste steams from manufacturing or illegal waste disposal. Burnished and reversal of heat treating may result in harmonic distortion, especially when combined with misalignments or torque...your most likely root cause.
    TartanEagle likes this.
  18. Feb 3, 2020 at 8:30 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    THIS!
    Nothing is safe from mud. I use my truck (gun range, hauling, camping, offroad) but diving in to a shitty old mud pit to make a bunch of drunks holler? Nah, that's what POS trailer rigs are for.
    Joe23 and Tocamo[QUOTED] like this.
  19. Feb 3, 2020 at 8:35 PM
    NYCTaco52
    NYCTaco52 Half man, half goat
    Somehow known as Stewart, but named Ben
    Ft Lauderdale, FL
    2022 Subaru Ascent
    Pine barons? That mud is horrible. It's full of sand and salt. That salt is what's eating away at your belt
  20. Feb 3, 2020 at 8:45 PM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    I used to go quite regularly out to Stave Lake, it is a dam reservoir that it quite low and a regular mud hole to 4x4 in, in this area. This mud is thick and sticky. I would regularly come out of there unable to identify my truck or it's colour, aside from mine was the muddy one. Mud got everywhere. Including the pulleys and belt. I never had an issue, ever, with mud destroying a set of pulleys. The pulleys spin at high speed even at idle and will throw any debris off them quite quickly. You would be more likely to throw a belt off before you did any sort of damage. Go and get muddy! You will be fine.
