Gonna bite the bullet and ask a stupid question.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BrokenCoastie, Feb 3, 2020.
Does mudding destroy pullys?
  1. Yes, dont do that, you are dumb if you do.
    40 vote(s)
    42.1%
  2. No, dont be a wuss.
    55 vote(s)
    57.9%
  1. Feb 3, 2020 at 8:59 PM
    BrokenCoastie
    BrokenCoastie [OP] Nonsolis Radios Sediouis Fulmina Mitto
    James
    East Bay area
    ‘17 TRD OFF ROAD
    I appreciate all the feed back. I dont know, I guess I was just wondering if 3rd gens are just weaker quality. Like, FFS, my second gen was a decade old and had literally been in the ocean up to the mirrors (not even a long story) with nothing, no problems. Just worried GM is rubbing off on Toyota I guess.
  2. Feb 3, 2020 at 9:01 PM
    eon_blue
    Azusa, CA
    Yes. Mud destroys pulley bearings lickety split. Just had to replace my AC idler pulley because of a nice front end dunk in some muddy water.
    Fuck mud
    cruiserguy likes this.
  3. Feb 3, 2020 at 9:09 PM
    Jessrin
    Jessrin Oh, okay...
    Jesse
    Upper Michigan
    24 Tacoma Double Cab TRD Off Road 4X4
    Stock
    Mine never did.
  4. Feb 4, 2020 at 1:43 AM
    Big tall dave
    Big tall dave Well-Known Member
    Elora, Ontario, Canada
    2018 Tacoma TRD OR DCLB
    Same here except i’d use a finger-full of silicone lube (SuperLube) on both sides of the serp belt (with the engine off) Worked like magic....
  5. Feb 4, 2020 at 3:42 AM
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    Define long term? 10k miles?
    Chew likes this.
  6. Feb 5, 2020 at 8:27 PM
    Link master
    Link master Well-Known Member
    2016 Tacoma inferno trd off road dcsb
    Arb summit bumper. Morimoto led headlights and new grill. Grill and lights have sequential turn signals.
    No, they wont.
    Belts get wet by spray when you drive in rain but spin at such a high speed they throw the water off quick.
    I have had numerous engine wash of big rigs and the belts are not made any different, just longer.
    Moisture gets everywhere.
    Everything outside the passenger compartment is designed to handle various environments.
  7. Feb 6, 2020 at 8:31 AM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    @JKO1998
    Oh yeah? you think your pulleys do well with water in them I’ve got an idea for you. Pull them off and submerge them in water for a day. Put them back on. See what happens
    Edit- just noticed you’re a 3rd gen guy.
    i apologize.
    have your wife remove off those pulleys for you
    slander, OscarMyers and eon_blue like this.
  8. Feb 6, 2020 at 9:08 AM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    Is that common with older Tacoma's, they breakdown while forging water and mud. Good to know! Thanks for the information, I guess my 3rd gen pulleys will be just fine then. :boink::D
    As for my wife, she might just be able to change pulleys! And there is certainly nothing wrong with that. :D
    Link master and TartanEagle like this.
  9. Feb 6, 2020 at 9:32 AM
    Spoonman
    Jamie
    Alberta
    The stupidity is off the charts with you. My god.
  10. Feb 6, 2020 at 10:03 AM
    Speedfreak
    Dave
    Canada Eh!
    Manual Mall Crawler
    Thanks! You really get me. We must be like 2 peas in a pod.
  11. Feb 6, 2020 at 10:12 AM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    There's a reason the best Land Cruiser site on the internets is named 'ih8mud.com':D
    Water doesn't worry me as much as mud does. Mud sucks ballz unless you're wheeling a 1977 Ford 250 Hi Boy with a 351 that's on 44" super swampers and you don't care about it:cool: and that's not opinion, that is based on scientific facts /sarcasm/, might be alternative facts, but facts none the less :rofl:
  12. Feb 6, 2020 at 12:22 PM
    nomnomtaco
    nomnomtaco Well-Known Member
    2019 Black Tacoma Limited
    Hot Stock
    Heyyyyyyy
  13. Feb 6, 2020 at 12:46 PM
    rpowell25
    rpowell25 Well-Known Member
    Robert
    Walnut Creek, Ca
    2019 Tacoma DCSB TRD Off Road 4wd
    The list is long but distinguished
    Serpentine belts are notorious for squealing when they get any kind of residue on them. Clean water generally won't cause a squeal. Coolant and other stuff that can leave behind a residue that will have the belt squealing for a while and sometimes it won't go away which necessitates a belt change. I've not seen a situation where the pulleys were also at cause other than physical damage. That said, if the pulleys have some residue on them and a new belt is installed the squeal can return.
    I personally had a serpentine belt on a GM car that I spilled new coolant on. It squeaked like mad. Sprayed WD40 on it while the engine was on and the squeak went away for about 3 minutes or so. The only way to get it quiet was to replace the belt.
  14. Feb 6, 2020 at 4:07 PM
    NEIPA27
    NEIPA27 Well-Known Member
    Florida
    2020 OR
    I had a 2008 Tacoma that I drove into the swamp to try and rescue my friend's F-150 that was stuck. This is Florida, and the numerous water holes I had to drive through were full of muddy, sandy water. The hard packed sand on the bottom meant there wasn't much chance of being stuck, but being inexperienced, I charged through all of them way too fast, trying to get inertia.
    The result was blasting a lot of that water into my engine compartment. Driving back home I noticed squealing, which went away. But then soon after I noticed the pulleys sounded really noisey. Soon after that, the pulley for the engine fan sized, and caused the AC compressor to over heat and seize. That was an expensive trip to the swamp.
    It's too bad that the pulleys aren't a part that you can pull off, take apart and service & lube after off-roading. now, if I have that kind of muddy water intrusion I've been spraying them off with the hose the best I can while the engine is running. I don't know how much it actually helps. maybe somebody who's more familiar with the mechanics of how the pulleys work can chime in.
    Just my experience.
  15. Feb 7, 2020 at 1:07 AM
    #35
    Big tall dave
    FYI- This may seem sketchy, but i’ve cured some squeaky belts by touching them for a few seconds with a small wire brush while the engine is running. I usually tape the wire brush to a long stick and then do both sides of the belt. Works the same on grooved or flat pulleys too, you’ve just gotta be real careful. It deglazes them and cleans the crud out of the grooves....
    rpowell25[QUOTED] likes this.
  16. Feb 7, 2020 at 1:20 AM
    #36
    deadpocketss
    deadpocketss Dingus
    Ian
    Colorado Springs, Colorado
    '24 Subaru Crosstrek Premium
    Yeah, it'll mess up pulleys and stuff but they're not hard to replace.
    Just have fun with it.
  17. Feb 7, 2020 at 10:05 PM
    #37
    Link master
    Have your boyfriend help pull your head from your backside, if you are submerging them for a day then your far more stupid and should not have a vehicle.
    It's not a submarine.
    Come back when you have driven several million miles in multiple vehicles and environments.
    Derp
  18. Feb 7, 2020 at 10:58 PM
    #38
    Spoonman
    Jamie
    Alberta
    I know more than you about trucks.
    slander likes this.
  19. Feb 8, 2020 at 9:07 AM
    #39
    Link master
    Your response shows you do not, princess.
    Keep digging your hole deeper.
  20. Feb 8, 2020 at 4:43 PM
    #40
    Spoonman
    Jamie
    Alberta
    What hole?
    Get your pulleys wet. See what happens. Do you not understand that water isn’t a good bearing lubricator?
