Gonna do brake pads and rotars, any advice?
Discussion in '1st Gen. Tacomas (1995-2004)' started by MikeNickolas, Dec 28, 2021.
  1. Jan 3, 2022 at 7:59 AM
    #41
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    There are some small rubber plugs in the backing plates which allow you to see in and measure the material left on the shoes.
    If you're going to go through the process to get the drum off, just replace the shoes and have the drums turned. If the drums haven't been removed before, you likely will need to use the star adjusters to "suck the shoes in" so that the drum will let the shoes go- a small lip can develop, and you can damage things if you just try to force the drum off with bolts.
  2. Jan 4, 2022 at 4:55 AM
    #42
    CrippledOldMan
    CrippledOldMan Well-Known Member
    David
    Salisbury North Carolina
    2003 TRD Crew Cab
    None
    True, but for me it will easier to have my brother just remove the wheel. Click on my avitar and you'll see why I'm not so flexible anymore these days. Crawling under the Truck for anything is a chore.
  3. Jan 4, 2022 at 7:39 AM
    #43
    foothill96tacoma
    foothill96tacoma Well-Known Member
    I recently did my front brakes (stock, not the Tundra upgrade). The only complication I encountered was loosening the caliper bolts, which required a *really* big breaker bar. I put anti-seize on these bolts when reinstalling so things will be easier the next time around.
  4. Jan 4, 2022 at 3:52 PM
    #44
    Nessal
    Nessal Well-Known Member
    Texas/Bay Area
    2003 V6 4X4 TRD DCAB
    Did you just do the pads? You shouldn't have to remove the calipers for that.
  5. Jan 4, 2022 at 3:59 PM
    #45
    Andy01DblCabTacoma
    Andy
    San Diego, CA
    But you do have to remove the caliper to remove the rotor.. which should be turned or replaced when you do the pads.
    Nessal[QUOTED] likes this.
  6. Jan 4, 2022 at 6:26 PM
    #46
    foothill96tacoma
    I replaced the pads, rotors, and calipers. I had a complicated wobble I needed to fix. But yeah, you should turn or replace the rotors when you replace the pads and this requires removing the calipers.
