Gonna install the V6 block heater today. Any advice, tips?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacomaPrime, Dec 11, 2011.
  1. Dec 11, 2011 at 8:49 AM
    TacomaPrime
    TacomaPrime [OP] Cybertronian Tacoma
    Greg
    Illinois
    05 Prerunner SR5 TRD off road
  2. Dec 11, 2011 at 9:15 AM
    JKD
    JKD Well-Known Member
  3. Dec 11, 2011 at 9:23 AM
    beastlytaco
    beastlytaco Well-Known Member
    Ian
    08 Access Cab SR5
    i thought those were only needed on diesel applications?
  4. Dec 11, 2011 at 9:44 AM
    OffroadToy
    OffroadToy This ain't Dodge City, and you ain't Bill Hickok
    4X4 Offroad
    snugtop, piaa, weathertech, westin, oem bed mat, trd seat covers, avs inchannel vent visors, 2" suspension lift, front diff drop, rear differential breather extension, oil filter drain hose, a/c drain hose extention & reroute, front window tint, cat theft protection plate, tailgate clamp mod, xpel headlight/foglight protecters, oem block heater, bfg 265/75R/16 a/t k/o's, cabin air rodent protection screen, rcbs illuminated 4X4 switch mod
    There's plenty of wire to do a clean route. Run it straight up and zip tie to the wire harness running along the top of the firewall. Go over the brake fluid reservoir then along the fender, inback of the fuse box and battery, then out the front. I used a loose zip tie to help secure the plug to the grill.
  5. Dec 11, 2011 at 9:49 AM
    TacoIII
    TacoIII Mr. Boombastic
    Andrew
    Boone, NC
    10 Taco 4x4 off road package
    3" OME 886 coils, ARB bumper warn M8000, Lightforce 240's and 255/85 16 KM2, Redline hood struts,arb twin air compressor, 4.88's, Tepui kukenam, Pelfreybilt bed rack and rear high clearance with swing out, and custom offroad bodywork
    Dont do it with a hot engine or when its is really cold outside. makes it a challenge lol
  6. Dec 11, 2011 at 10:32 AM
    TacomaPrime
    Greg
    Illinois
    plugging it into the right hole on the block helps too.
    I made a video of the process I will post a link when im done.
  7. Dec 11, 2011 at 10:33 AM
    TacomaPrime
    Greg
    Illinois
    yep. That's how I plan on routing mine
  8. Dec 11, 2011 at 12:09 PM
    TacomaPrime
    Greg
    Illinois
    Video is formatting to a .wmv now, will upload to youtube afterwards.
  9. Dec 11, 2011 at 12:13 PM
    Pugga
    Massachusetts
    '18 Ford F-250 SCREW
    F-250 Land Yacht Mod
    More common on diesels in the states but there is an advantage to using them on gas engines also. I believe they're standard equipment on a lot of Canadian Tacomas.
  10. Dec 11, 2011 at 1:43 PM
    TacomaPrime
    Greg
    Illinois
  11. Dec 12, 2011 at 6:08 AM
    TacomaPrime
    Greg
    Illinois
    So what can I expect from the block heater??
    I plugged it in last night and had it come on at 430am this morning. I started the truck, but the engine temp gauge was still at C. It did seem to get warmer faster. Is that what it's supposed to do? I've never had one, so I don't know. Just want to make sure it's working.
  12. Dec 12, 2011 at 6:42 AM
    Pugga
    Massachusetts
    How long after 4:30 did you start the truck? It's only a 400W element, it won't warm the engine in 30 minutes. In bitter cold situations, it just helps keep a little bit of heat in the engine overnight. If it's only 10 or 20 F outside, that little heater probably won't make that much of a difference.
  13. Dec 12, 2011 at 7:22 AM
    TacomaPrime
    Greg
    Illinois
    started the truck around 730 when I went to work.
  14. Dec 12, 2011 at 7:45 AM
    Pugga
    Massachusetts
    How cold was it? I know a lot of the ones on diesels are around 1,500 watts vs the 400 watts from the Tacoma one. This is exactly why I've been hesitant to get one for mine. They'll keep some heat in the engine if you live in areas where it gets -30 F or below but I can't see them being a big help otherwise. :notsure:
  15. Dec 12, 2011 at 7:46 AM
    TacomaPrime
    Greg
    Illinois
    the outside temp was 26 degrees when I left this morning.
  16. Dec 12, 2011 at 7:47 AM
    TacomaPrime
    Greg
    Illinois
    Figure it's gotta be more help then hurt.
    My dealer said they didn't want to install it because they "damage" the engine. :rolleyes:
    Really? REALLY?!?
  17. Dec 12, 2011 at 7:48 AM
    Pugga
    Massachusetts
    At that temp, I wouldn't even bother plugging it in. It should help it some because it is putting heat into the engine but I can't see it being a big difference until the temps get much lower. You're right, it will still help, I just don't know as if you'd see the difference. When the truck spends the night out in -40 degree weather, there's a good chance it absolutely will not start the next morning where the addition of the block heater could mean the difference between starting and not. At 26 degrees, that is not really a concern.
  18. Dec 12, 2011 at 8:00 AM
    TacomaPrime
    Greg
    Illinois
    yeah. I pretty much just plugged it in to see if it worked. Mostly it will be used when the temps get really low here, which isn't too often, or when we go up to international falls, MN to visit my in laws. somedays there the high temp is -20, -30.
  19. Dec 12, 2011 at 8:03 AM
    Pugga
    Massachusetts
    I'd try it then, in the really cold conditions and I'll bet you'll notice it starts easier and warms up quicker than it normally does in those temps.
  20. Jan 19, 2012 at 10:40 AM
    TacomaPrime
    Greg
    Illinois
    this thing has been working great the last couple days. It's been getting into the low single digits to below zero temps and windchills way below zero the last couple nights.. Have a timer plugged in and set to turn on at 430am, till 730am, which is right about when I leave for work. The truck has started RIGHT up, no slow start. And I can drive it normal and it has great pickup right away rather then feeling sluggish because of the cold. Great investment if you ask me.
