Gonna try my own trans flush today....
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 93civEJ1, Apr 15, 2013.
  1. Apr 15, 2013 at 12:24 PM
    93civEJ1
    93civEJ1 [OP] Well-Known Member
    09 DC TRD OR
    Procomp 6" Stage 1, Bilstein 5100's in front, flowmaster 40 series
    U mad? Hopefully it will be cakewalk.
  2. Apr 15, 2013 at 12:25 PM
    medusa1066
    medusa1066 Well-Known Member
    Jonathan
    Morgantown, WV
    2007 4x4 TRD Sport
    Loosen fill plug first :] Good Luck!
  3. Apr 15, 2013 at 12:28 PM
    93civEJ1
    09 DC TRD OR
    haha....yes, thats the smart way in case you strip everything else out...
  4. Apr 15, 2013 at 12:57 PM
    93civEJ1
    09 DC TRD OR
    Im also gonna try the Valvoline Maxlife that is compatible for WS fluid vehicles.
    At 9.33 a quart for almost 14QT's for Toyota WS from the dealer,
    I think ill maybe try out the Maxlife for much less. Im not scared to take risks and tear apart vehicles.
  5. Apr 15, 2013 at 12:59 PM
    neonlazer
    neonlazer Mechanically Goofy
    Jeffrey
    Lafayette, LA
    '12 DCSB 4x4 SR5
    Just don't accidentally put engine oil or tranny oil in the coolant or any other input that it doesn't belong in. :anonymous:
  6. Apr 15, 2013 at 1:14 PM
    93civEJ1
    09 DC TRD OR
    Haha....I know the difference between a tranny pan and engine pan..haha, im not new to working on cars.
    Completely built my 94 Supra...so im sorta familiar with toyotas. Fully built the motor, singled it, and changed from auto to manual. Its not my first rodeo. ;):p
  7. Apr 15, 2013 at 1:19 PM
    neonlazer
    Jeffrey
    Lafayette, LA
    '12 DCSB 4x4 SR5
    Nice! You might get some enjoyment/laughter reading this..as to why i posted what I posted. :D
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/33318-halp.html
  8. Apr 15, 2013 at 3:25 PM
    Danno 1948
    Danno 1948 Well-Known Member
    Dan
    Ocala,Fl.
    02 SR5 Prerunner
    Added front spacers to bring front end up to match rear
    I used Maxlife fluid and haven't had no problem. Has better reviews than most trans. fluid. Good luck just take your time.
  9. Apr 15, 2013 at 7:15 PM
    93civEJ1
    09 DC TRD OR
    Thanks. One thing I find odd is I was able to get the fluid fully looking good. Did the trans temp fluid check fine bit with my truck idling I never could really get anything to come out of the fluid level check plug. I used more than enough fluid. Even went through 16 qts to be completely sure I'm not low. Only a trickle would come out at idle. Barely enough to even be noticed. If I cut the truck off the fluid would come running out that hole like crazy. I did this chane to try to resolve the trans shudder at part throttle with the 3 to 4 gear that some people get while in OD around 35 to 40mph. It didnt resolve mine. Not sure where to go next.
  10. Apr 17, 2013 at 2:19 PM
    93civEJ1
    09 DC TRD OR
    I was able to finally get it sorted...I needed a little more and then got it to flow out of the check plug. Things seem good for now.
  11. Apr 17, 2013 at 8:34 PM
    93civEJ1
    09 DC TRD OR
    It was less noticeable but I haven't had enough time to test out at that certain speed gear and rpm combo yet to make a final answer or decision.
  12. May 3, 2013 at 6:04 AM
    93civEJ1
    09 DC TRD OR
    Update...The shudder I was having seems to be pretty much gone now.
