Goo gone not working
Discussion in '2nd Gen. Tacomas (2005-2015)' started by drewskie, Jul 28, 2011.
  1. Jul 29, 2011 at 7:58 AM
    hookedontronics
    hookedontronics Well-Known Member
    Jake
    Glenville, NY
    2010 DC Off Road 4x4
    Icon extended travel 3.5" front coilovers, DSM UCAs, TSB leaf pack w/ wheelers AAL, All Pro U-bolt flip kit, Walker Evans 2.0 rear shocks, 18" XD Monster rims, Nitto trail grappler 285/65R18 Tires, Color matched grill, Grillcraft, Kragen HIDs, Carling switches, my bed light mod, diff drop, Alpine IVA-W505, JL Audio C5 componets and coaxials, JL 300/4 and 250/1 amps and JL stealthbox, wheathertechs, avs vent visors, toyota bed x-tender, alcantara center console cover and door pocket covers, console vault, color matched mirrors, heated mirrors, etc etc etc
    little bit of gas on a rag and it'll wipe off with ease. I use gas on a rag to remove everything adhesive, it works amazing.
  2. Jul 29, 2011 at 7:59 AM
    KevMc
    KevMc Well-Known Member
    Kevin
    West Columbia, SC
    06 TRD Sport DC LB
    Satoshi with Hella 500FF's Readylift N-Fab Rear Runner w/ Westin lights TRD Seat Covers
    Spray Plastidip on it, then peel it off when it dries, should take the glue with it.:notsure:
  3. Jul 29, 2011 at 8:14 AM
    moe1967
    moe1967 Well-Known Member
    2010 TRD DC Off-Road PreRunner
    ^This^
    Just make sure you wash the area about 3 times when you are finished. (With fresh soap each time)
  4. Jul 29, 2011 at 10:00 AM
    drewskie
    drewskie [OP] Well-Known Member
    Drew
    Burbank, CA.
    08 Prerunner 4 banger
    Thanks for all the responses gents, I think this here is my issue. The more I look, the more it seems like all the glue is gone, but the outline is just set in the clearcoat. I will give the wd-40 a try, and afterwards I will probably have to polish the whole truck. Doesn't help that its Black either.
  5. Jul 29, 2011 at 10:16 AM
    sloppyjoe
    sloppyjoe They are more like guide lines.
    All Over
    Silver and simple
    Non
    I would go with 91% alcohol, it sill not harm the paint, and it eats glue and the like pretty darn good. Thats what I used to debadge vehicles.
  6. Jul 29, 2011 at 10:21 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    When I took mine off , I could see a ghost of the decal in the clearcoat , a couple days in the sunshine and it was gone or blended with the rest of the panel enough that I couldn't see it anymore
  7. Jul 29, 2011 at 10:29 AM
    09taco4x4
    09taco4x4 Well-Known Member
    Louisiana
    09 DCLB TRD Sport 4x4
    Valant cold air intake kit Borla catback exhaust 6" Pro Comp Stage 1 Walker Evans 2.5's w/ TSB spring and add-a-leaf Light racing upper a-arms 285/70/R17 Dynapro ATM tires 17x9 XD wheels
    My truck is black also and the outlines did show up better on my truck as compared to my buddies silver truck. Word of advice, if you have never clay bar your truck before, go to AutoGeek.net and watch the video on how to clay bar a vehicle. Tought me a few things I didn't know.
  8. Jul 29, 2011 at 11:04 AM
    TiMe
    TiMe Well-Known Member
    CA
    05 Dbl Cab 4x4
    6" Fabtech with coilovers 33" nitto mud grapplers
    Rubber eraser wheel from the autobody paint supply store on a cordless drill and some rubbing compund and polish after you are done.
    This is the BEST way to do you. You can debadge an entire truck in less than 20 mintues if you know what your doin.
  9. Jul 29, 2011 at 12:52 PM
    JRader1790
    JRader1790 Well-Known Member
    Josh
    Pascagoula
    '11 TRD Sport 4x4
    I was curious as to why more people don't recommend the 3M Eraser Wheel, that thing does wonders!
  10. Jul 29, 2011 at 1:38 PM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    Because it works if used in moderation. Last time I mentioned that I got flamed by a bunch of pussies who weren't willing to try it because they heard on the internet that it would damage their paint. I wish people would try things for themselves every once in a while rather than believing everything they read on the internet.
    I have used acetone many many times to remove decal adhesive and paint overspray and I have NEVER damaged the clear coat doing so. Automotive clear coat is pretty chemical resistant once it's fully cured. If you use a small amount on a rag and don't leave a lot on the paint it won't hurt it and works a lot quicker than goo gone ever will. I used acetone to remove the TRD beside decals on my truck and did zero damage to the paint or clear coat.
    3M Eraser wheels work well too but they are kind of expensive and hard to find not every auto parts store carries them.
  11. Jul 29, 2011 at 4:39 PM
    Sniper#830
    Sniper#830 Active Member
    Paso Robles, CA
    2017 Toyota Tacoma / 4x4 / Off Road
    Rubbing alcohol or 3M adhesive remover..... both dont hurt the paint.
  12. Jul 29, 2011 at 5:40 PM
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    Then maybe there was something wrong with your paint. Were you using 100% alcohol or methanol? Some Detailers use alcohol to strip wax all the time and it has never hurt any of my vehicles.
  13. Jul 29, 2011 at 5:58 PM
    LUSETACO
    LUSETACO Here for the Taco Pron
    Dennis
    South Central Pee A
    2005 PIMP MOBILE
    Yes
    Just rubbing alcohol. I've used it before to strip adhesive and never had a problem. That time though I tried one small spot and stripped the clear right off.
  14. Jul 29, 2011 at 5:59 PM
    JDMcQ
    Interesting. I have never had an issue. I have seen that happen with acetone though. You try to buff it out?
  15. Jul 29, 2011 at 8:34 PM
    #35
    LUSETACO
    Dennis
    South Central Pee A
    2005 PIMP MOBILE
    Yes
    I used some polishing compound and waxed it a couple times and it got better but the damage is done.
  16. Jul 29, 2011 at 10:26 PM
    #36
    drewskie
    Drew
    Burbank, CA.
    Acetone like Nail polish remover? I used that on a few work trucks a while ago, and there's still the spot from where I rubbed. I did use a lot and I dont think I washed it off at all though
  17. Jul 29, 2011 at 11:03 PM
    #37
    09taco4x4
    Louisiana
    I luckily found one in stock near the house. Oh and it only cost $40.00....to me that is worth not having to sit there and rub that shit off all day. Plus I barely made a dent in the thickness of the wheel from doing 5 trucks. Def worth the money!!:cool:
  18. Jul 30, 2011 at 1:57 PM
    #38
    Btnewman
    Btnewman Benjamin Newman
    Benjamin
    Grand Junction co
    Uh. It's beat to he//. But it's only 1 owner.
    Custom body work/damage ARB rear locker Bumpers Shocks Other parts Tires and Rims Air tank fully plumbed into truck "Golf ball mod"
    I agree with wd-40, took off dealership badge residue with no sweat
  19. Jul 30, 2011 at 2:05 PM
    #39
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    Jesus christ people.... the fuckin glue is gone. Stop suggestion he uses shit that is going to kill his paint... he just has an outline from where it hasn't been waxed, cleaned, or subjected to UV. Its normal and no amount of solvent is going to take it off!
    Go get some Meguiars Ultimate Compound from the local auto store in the detailing section. Any other cleaning compound will work, this is just my OTC preference. Get yourself a terry cloth, and use the compound in small circles around the area by hand. After about 5 minutes of rubbing, you should be good as new. I will warn though, you might end up with one spot on your truck that is good as new and you'll want to do the rest.
    Remember you will need a fresh coat of wax after youre done though.
    Op, do not listen to any one of these tards above you. Every damn one of them is giving conflicting information and you, not knowing any better, is going to pull the wrong information from them. I'm about to flag every damn one of em for suggesting products that are not approved for this usage. Wake the fuck up clowns.
    :locked:
  20. Jul 30, 2011 at 2:09 PM
    #40
    phatdrew
    phatdrew Well-Known Member
    drew
    dover, de
    2" lift, 17" pro comp wheels, 285x70x17 micky t's, billet grill
    i have sinced rebadged my truck but when i first removed them, there was an imprint of the badges on the truck from the wax. i used a clay bar and it removed the imprint from the badges on the clear coat. good luck!
