Goo Gone vs. WD 40 - searched couldn't find an answer to my ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bgsmith, Oct 8, 2011.
  1. Oct 10, 2011 at 12:42 PM
    jjew18
    jjew18 the Nightman cometh!
    Alliance Airport
    05 PreRunner SR5
    Added extra awesomeness to its original awesomeness.
    I found the 3M Stripe Off Wheel at O'Reilly and NAPA, however at O'Reilly they did not have the drill bolt the wheel attached too, just the replacement wheel. If you can get one, this would be the way to go for sure.
  2. Oct 10, 2011 at 12:44 PM
    georgeandkanoa
    georgeandkanoa the point is simply this
    jeff
    calgary
    07 tacoma trd
    bilstein5100's front tinted windows access cover pioneer stereo weathertechs grillcraft grill kc's behind cbi sliders
    I think I've seen this movie, nail polish remover works
  3. May 26, 2013 at 10:50 PM
    Jetlander
    Jetlander Just trying to measure up...
    Jonathan (aka MOAB)
    Depends on the day.
    2010 Tacoma DCSB 4x4 SR5
    TKO Wheel w/ 35" BFG KM2, Volant CAI, Safari Snorkel, 3" lift, All-Pro Full Skid Underarmor, Chopped/Re-Routed FlowMaster Exhaust, CBI Moab 2.0 Front Bumper, DerpWerx High Clearance Rear Bumper, Rear Tire Swing Out, BAMF Sliders w/Kickouts, King Resi w/700# Coilovers on front, Total Chaos UCA's, King Long Travel with Resi's, Shock Hoops and King 2.5 Bump Stops, OME Dakar Leaf Springs mounted on All-Pro Shackle Flip w/ U-Bolt Flip, extended SS Brake Lines, DerpWerx Bedrack, 10# C02 Tank, Black Badges, Dual Optima Red Top's, Blue Sea 12 Fuse Block on custom Block mount, SuperWinch 9.5iSR Talon w/synthetic line, Prolink Thimble, 20" Rigid Dual Row LED Light Bar, Rigid Dually Floods, OTRATTW Switches, Cab Mount Chop, Cobra CB w/ 4' Firestik, Center Counsel Glock 23 mount (with plenty o' ammo!), Weathertechs, and plenty more mods to come!
    Here's a question. I'm going to debadge my rig so that I can paint the badges. Where do I get the adhesive to reapply the badges when I'm done?
  4. May 26, 2013 at 11:10 PM
    DirtyDTaco
    DirtyDTaco Talk slow, shoot fast.
    Matthew
    Mississippi
    '00 XtraCab 4x4 3.4L V6 5-Speed, 240K miles
    Polk 6.5" Coaxial Door Speakers, Pioneer DEH-X6500BT Head Unit, Black Bed-Lined Badges, 15% Tint, JL Audio 10" BassWedge, Alpine 500w Mono Amp
    Use 3m molding tape from Walmart, just cut it and apply it. Pull the backing off when you're ready to stick it to the truck. I think it's called super strength molding tape. In the automotive section with the spray paint and bedliner. Part number 03609.
  5. May 26, 2013 at 11:16 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Yup... Gray tape, red backing.
    Started showing up at WM about 5-6 years ago.
    Before that, you had to get it from auto paint & body supply houses.
  6. May 27, 2013 at 8:12 AM
    Jetlander
    Jonathan (aka MOAB)
    Depends on the day.
    Thanks guys, I appreciate the info!
  7. May 27, 2013 at 7:30 PM
    Jetlander
    Jonathan (aka MOAB)
    Depends on the day.
    Adhesive removed (pain in the @ss), badges sanded and primed. Just put the first coat of Matte black paint on and will hit it again in the morning, with a third coat tomorrow night. I did get the 3M tape and stuck it to the back of the badges prior to painting. Should have it all back on the Taco on Wednesday...
  8. May 27, 2013 at 7:34 PM
    SOSHeloPilot
    SOSHeloPilot My 1st Muscle Car
    S.E USA & S.E. Asia too
    2024 4Runner SR5
    Missing My Last Tacoma --- Had 11 Toyota trucks in the past and many other Toyota cars too.
    Hot sun (heat gun will help warm up the adhesive too) and Gorilla Duct Tape (sticky side) and blot it off.
  9. May 27, 2013 at 7:45 PM
    BamaToy1997
    Bill
    Navarre, FL
    Be VERY careful when using heat. Too much will actually begin to soften and melt the clear coat.
    Also, WD-40 is a lubricant, not a decal/sticker/adhesive remover. It is not designed to do so. Goo-gone IS designed as an adhesive remover. Just FYI.
