Good 3 or 4 inch lifts?
Discussion in 'Suspension' started by rallsp12, Nov 30, 2009.
  1. Nov 30, 2009 at 6:36 PM
    rallsp12
    rallsp12 [OP] Well-Known Member
    Ralls
    Gadsden AL
    08 Black Double Cab 4WD
    2 pioneer 10'' subs with 1000 watt ma audio amp behind back seats, pioneer in dash avhp4100 dvd. westin bull bar painted with line-x black, 15 % tint on front windows and 5 % strip on windshield. rear window tinted 5 %. 3 inch toytec spacer in the front and 1 1/2 inch block in the rear
    here is my deal. i have a 08 4wd DC tacoma and am wanting to lift it up. i cant go any higher than 4 inches. i am not wanting to spend too much. i am wanting to find a 4 inch since its as high as i can go but cant seem to find one. does anyone know of a 4 inch suspension lift? and also i have found a 2.5 inch rough country lift for $250 and is that the same as the 3 inch because it also levels it out too.? and it looks like a lot of tacomas have the rough countrys or tuff countrys. and last since i cant find a 4 inch i will probably settle with the 3 inch so how big of tires will i be able to run? i have 265 bfg all terrains. i am thinking 33's is all ill be able to fit.
    so?
  2. Nov 30, 2009 at 6:36 PM
    dunkhi
    dunkhi CSULB socal
    Craig Sirois
    Southern California. Fountain Valley
    09 Ivan Stewart
    Toytec Coilover kit. Bilstein's 5100. Alcoa Wheels. General Tires. Magnaflow Cat-back. BLHM. Yellow fogs. 13TW5 jl sub. Stewart Decals.
    i am running toytec coilovers laying on some 5100's at 3.5 the ride isnt bad. and i fit 285/70/17 no rubbing at all.
  3. Nov 30, 2009 at 6:45 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    watch out anything above 3 inch without a differential drop bracket lift will cause your cvs to die, so i think your only option is the 4.5 inch from rcd or the longtravel kit from total chaos
  4. Nov 30, 2009 at 6:48 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Even with a diff drop, your endangering the CV's. X2 on the 4.5 RCD.
  5. Nov 30, 2009 at 7:39 PM
    rallsp12
    Ralls
    Gadsden AL
    does the 4.5 rcd level it out too?
  6. Nov 30, 2009 at 7:54 PM
    rallsp12
    Ralls
    Gadsden AL
    and whats the difference in the rough country 3 inch and the 4.5 rcd? the rcd is 2000 bucks and the rough country is only 250? why is this?
  7. Nov 30, 2009 at 8:06 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The Rough Country is a top plate spacer lift. It can wear out your ball joints, and damage your shocks.
  8. Nov 30, 2009 at 8:10 PM
    ktmrider
    Junk
    yea and with the Rcd lift it provides new shocks, 5100s which will much improve your ride, and if you go with the spacers its going to be a bad ride, and the blocks in the rear will ride badly and eventually wear out your leafs
  9. Nov 30, 2009 at 8:11 PM
    rallsp12
    Ralls
    Gadsden AL
    is it a good enough lift if im just wanting it for looks and for bigger tires and not really off roading as much as most people
  10. Nov 30, 2009 at 8:19 PM
    rallsp12
    Ralls
    Gadsden AL
    and really i only have about 1000 to spend on it and can only get up to 4 and thats just the best option ive really found
  11. Nov 30, 2009 at 9:21 PM
    ktmrider
    Junk
    like you can and it will be fine until you get the funds, but alot of the people on tw that ran them regret it.
  12. Nov 30, 2009 at 9:25 PM
    nighthawk87
    nighthawk87 Well-Known Member
    with 1000 you can get yourself the toytec coilovers on toytec.com
  13. Nov 30, 2009 at 9:27 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    for 1000 bucks id say go for something better than the toytecs, like icons of for a few extra bucks fox's
  14. Nov 30, 2009 at 9:32 PM
    freedomriding
    freedomriding FREEDOMEDIA
    Nate
    Oahu, Hawaii
    '20 TRDOR w/KDSS
    Eibach 2.0, STT PROs, Summit Dakars, JBA
    If your gonna drop the money on RCD, u might as well go Fabtech basic 6" so you can completely clear 33's
  15. Dec 1, 2009 at 8:42 AM
    Toytec Lifts
    Toytec Lifts Toyota Suspension specialist
    Rocky Mountains
    Toyota's are awesome
    Plus you get a forum discount..
  16. Dec 1, 2009 at 11:47 AM
    rallsp12
    Ralls
    Gadsden AL
    which toytec coil over lift kit is it?
  17. Dec 1, 2009 at 1:10 PM
    Toytec Lifts
    Rocky Mountains
    that's the Ultimate Kit...
    little over your budget, but well worth the life time warranty everything in the kit comes with.
    a true life time investment to your suspension, meaning, once you put this on, the only thing down the road you will need to deal with, is your rear leaf pack.
  18. Dec 1, 2009 at 1:52 PM
    rallsp12
    Ralls
    Gadsden AL
    so that lift actually levels it and lifts everything up 3 inches? and would i only be able to run 33's or bigger?
  19. Dec 1, 2009 at 1:56 PM
    jdkeller
    jdkeller How many words can be fit in this s
    Jonathan
    Inland Empire, Ca
    2008 Tacoma Prerunner TRD Offroad
    Dome light LED, 6000k HID Headlights and fogs, Grillcraft black mesh, rear 5100's, Total Chaos UCA's, 285/75/16 BFG KM2's, Spidertrax spacers, Blacked out emblems, cb,kenwood tm270 ham radio, All Pro 3" leaf pack, Fox 2.0 coilovers, Revenge Fab Sliders, u bolt flip kit, Pioneer avh4200, bed bar with light and antenna, Wet Okoles, Weathertech Mats, Wet Okole Armrests, Rear KR Fab bumper, bed mat, N-Fab spare tire carrier with full size spare on 16" TRD rim, Bedlinered flares and grille. Camburg Spindles, All Pro front fenders.
    That has the leafs as well so you are not just leveling it. Lifting front and rear. You can fit 33"s with minor fender trimming.
  20. Dec 1, 2009 at 2:01 PM
    rallsp12
    Ralls
    Gadsden AL
    ok i see now. thanks. and what exactly do u have under ur tacoma?
