Good 3 or 4 inch lifts?
Discussion in 'Suspension' started by rallsp12, Nov 30, 2009.
  1. Dec 2, 2009 at 7:38 AM
    #41
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    No...
  2. Dec 2, 2009 at 7:47 AM
    #42
    gorilla33
    gorilla33 Stock Radiant Red
    East Tennessee
    05 trd sport
    OME3-05-AL
    TAC3-05
    Or 5100's in the front with a possible AAL. What direction would you go?
  3. Dec 2, 2009 at 12:56 PM
    #43
    jdkeller
    jdkeller How many words can be fit in this s
    Jonathan
    Inland Empire, Ca
    2008 Tacoma Prerunner TRD Offroad
    Dome light LED, 6000k HID Headlights and fogs, Grillcraft black mesh, rear 5100's, Total Chaos UCA's, 285/75/16 BFG KM2's, Spidertrax spacers, Blacked out emblems, cb,kenwood tm270 ham radio, All Pro 3" leaf pack, Fox 2.0 coilovers, Revenge Fab Sliders, u bolt flip kit, Pioneer avh4200, bed bar with light and antenna, Wet Okoles, Weathertech Mats, Wet Okole Armrests, Rear KR Fab bumper, bed mat, N-Fab spare tire carrier with full size spare on 16" TRD rim, Bedlinered flares and grille. Camburg Spindles, All Pro front fenders.
    Not the bottom one. Spacer lifts are bad.
    You are not spending a whole bunch on rear 5100s. Its best to just get them. Easy to install too. The top lift is great but You need 5100s or OME front shocks to go with it I believe.
    If you dont want to spend a lot go 5100s up front and thats all.
  4. Dec 2, 2009 at 1:58 PM
    #44
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    What He said ^^^^^
  5. Dec 2, 2009 at 6:03 PM
    #45
    gorilla33
    East Tennessee
    05 trd sport
    I guess thats the way i was leaning. 5100's at 2.5 would level me, is that correct? In addition AAL would give me basically my stock lean back, but raised 2.5 inches???
  6. Dec 2, 2009 at 6:19 PM
    #46
    jdkeller
    Jonathan
    Inland Empire, Ca
    Correct. 2.5 with no aal may leave the front a tad high. If I was going your route I would do 2.5 and a 1" aal. 1.5" tops. Just my 2 cents.
  7. Dec 2, 2009 at 7:05 PM
    #47
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    What he said ^^^ (again), but would go with the 1.5" AAL
  8. Dec 23, 2009 at 7:18 AM
    #48
    Rucas
    Rucas 1st gen
    Lucas
    1st gen. 4x4
    Custom Aluminum Camper
    On the toyotec site
    "1 1/2 lift rear add-a-leaf for tacoma with rear TSB springs"
    Does this mean that i need the rear TSB done to get about the 1 1/2 rear lift to level out the truck with 5100's at 2.5?
  9. Dec 23, 2009 at 9:11 AM
    #49
    jdkeller
    Jonathan
    Inland Empire, Ca
    No. That just means it's normally used with the tsb lags since those give you a slight lift. Only difference in the aal's is the lift they give. Run whichever you want.
  10. Dec 23, 2009 at 9:14 AM
    #50
    Rucas
    Rucas 1st gen
    Lucas
    1st gen. 4x4
    ohh so if i do get that "1 1/2 lift rear add-a-leaf for tacoma with rear TSB springs", it probablly wont lift the rear as much as with the TSB?
  11. Dec 23, 2009 at 9:35 AM
    #51
    jdkeller
    Jonathan
    Inland Empire, Ca
    You will get about whatever lift the aal says. The reason they have different lift sizes is because after you get the front lift done then you need an aal to lift the back up. If you have the non tsb springs they say get this one and if you have the tsb ones they say get this one. Thats because the tsb leafs sit a little higher due to having 4 leafs instead of 3.
    All this aside. Figure out how much lift you want and get the aal that gives it. :)
  12. Dec 23, 2009 at 9:42 AM
    #52
    Rucas
    Rucas 1st gen
    Lucas
    1st gen. 4x4
    okay thank you very very much!
  13. Dec 23, 2009 at 9:49 AM
    #53
    jdkeller
    Jonathan
    Inland Empire, Ca
  14. Dec 23, 2009 at 3:55 PM
    #54
    Toytec Lifts
    Toytec Lifts Toyota Suspension specialist
    Rocky Mountains
    Toyota's are awesome
    Thanks for your help jdkeller.
    Your right on it.
  15. Dec 23, 2009 at 6:17 PM
    #55
    jdkeller
    Jonathan
    Inland Empire, Ca
    Thanks for supplying aal's :cool:
  16. Dec 27, 2009 at 9:55 PM
    #56
    elliott.estes
    elliott.estes Well-Known Member
    sacramento
    07 Black DC TRD Sport
    In Dash Avic-D3 / Blacked out headlights / Satoshi Grille / OME 90000 Front Shocks/ OME n182 Rear Shocks / OME 885 Coils / AAL with TSB's / 10MM lift Enhancer Kit / Light Racing UCA's / BFG AT KO's (285x70x17's) / Procomp 7089 Rims
    If I add this 3" toytec lift is there a disadvantage of keeping my stock shocks? After all my reading I know I need to purchase a LR UCA to level out the lift, but would this combo be enough for 285/75/17s?
  17. Dec 28, 2009 at 7:22 AM
    #57
    Toytec Lifts
    Rocky Mountains
    There is no advantage to using the stock shocks except for money reasons. Otherwise, the stock shock should work.
  18. Dec 28, 2009 at 2:32 PM
    #58
    elliott.estes
    sacramento
    Thanks, what do you think about the tires fitting?
  19. Dec 29, 2009 at 8:23 AM
    #59
    Toytec Lifts
    Rocky Mountains
    The tires will fit regardless of your shocks. The shocks don't lift, just the AAL does.
