Good accurate, clean bass?
Discussion in 'Audio & Video' started by I Liquid I, Sep 27, 2011.
  1. Sep 30, 2011 at 6:05 PM
    #41
    06SR5canada
    06SR5canada Well-Known Member
    Saskatchewan
    06 dblcab SR5
    2ndary air filter removed, flowmaster 40
    screw music, all i need is bass :p
  2. Sep 30, 2011 at 7:00 PM
    #42
    I Liquid I
    I Liquid I [OP] Well-Known Member
    Puerto Rico
    06 BSP DCLB, 17 Inferno TRD Offroad DCSB, 06 SW ACLB
    Too many mods to list
    Heh. This thread has derailed into a build.
    Anyhow... Slight question/problem.
    Bought the amp wiring and such.
    I have 4 Gauge going into the amps. The cable came with an inline 100 A Fuse. The fuse is not waterproof.
    Im I right in thinking about changing this to an inline fuse that is waterproof? Or perhaps a circuit breaker for piece of mind?
    Also, it came with a 100 Amp fuse. My 1000 W Amp has four 25 Amp fuses and my 300 W Amp has two 25 Amp fuses. Is the supplied 100 Amp fuse that came with the cable enough or too much? I'd like to put the exact fuse I need. I've searched, but have found no definitive answer. If any of you know, i'd be very thankful.
    Not sure if I'm supposed to add all the 25 Amp fuses, which would mean a 150 Amp fuse, or to go with the gauge and stay with recommended 100 Amp fuse.
    BTW, as for deadening, I decided to go with FatMat. Its really inexpensive, and this is a work truck, so I should not go overboard on it, since I will still have tools rattling and such.
  3. Oct 1, 2011 at 12:41 AM
    #43
    I Liquid I
    Puerto Rico
    Update.
    Nvm. Kept searching and saw in many places that in fact I needed to add the fuses in the amps and that would give me the fuse for battery. Seems I need a 150 Amp fuse.
    Everything is now on the way.
  4. Oct 1, 2011 at 12:50 AM
    #44
    mizicko705
    mizicko705 Im that one guy!!! Who did that one thing...
    Kevin
    Socal
    05 Prerunner TRD V6
    (2) 12" rocksford Fosgate P3SD412 1000 watts RMS Sony explode deck Tinted Windows Blacked out Emblems Black hood scoop, valince bar and sleeved fog lights. FlowMaster 40 series BHLM Head lights Led lit door locks
    drop 2 12's in, best thing of your life, very crisp, very clean, very powerfull!!! :bowdown:
  5. Oct 1, 2011 at 4:58 AM
    #45
    lbridges
    lbridges Well-Known Member
    Lee
    Jonesville, FL
    2022 SR Access Cab
    None yet
    Perhaps I am missed some other post on the subject, but are you running a single wire from battery to a distribution block, then splitting to the amps?
    As a general rule fuses to protect the power wire from fire hazard should be placed within 18" of the battery, and a 4 AWG wire should carry a fuse no larger than 125 Amps. BCAE.com has garnered a lot of respect on car audio, and their page on fusing might help.
  6. Oct 1, 2011 at 7:07 AM
    #46
    I Liquid I
    Puerto Rico
    Thank you very much. That's the kind of page/info I was looking for. I just bought the 125 fuse. Thanks.
  7. Oct 1, 2011 at 8:06 AM
    #47
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    You should be fine. If you're pulling 125 amps you're killing your battery more than likely. That and you're listening waaaaay too loud.
  8. Oct 1, 2011 at 5:57 PM
    #48
    pinktaco808
    pinktaco808 Hot Steppa
