good alternate to $1200 toyota oem cat converter
Discussion in '1st Gen. Tacomas (1995-2004)' started by prerunnerSD, Jun 12, 2012.
  1. Jun 12, 2012 at 9:13 AM
    prerunnerSD
    prerunnerSD [OP] Well-Known Member
    USA
    01 Tacoma Limited 6 cylinder 4X4
    Grill guard Front and rear Bilstein 5100's Front Coilovers Rear AAL "I Brake for Tailgaters" Firestone Destination A/T (P265/75/R16)
    I have the p0420 bank 1 code. Changed the 02 sensor code still triggers. Was told to replace bank 1 cat.. With Toyota part # 17410-07040
    This item is $1200 and I know I can get it cheaper but what is a good alternative that will live up still the original oem specks.. It does need to pass california emmisions.. Also could a faulty bank 1 cat be the reason I am using so much more gas?
  2. Jun 12, 2012 at 9:22 AM
    98tacoma27
    Ben
    Not Beech Creek
    I have "heard" that the Walker CAT's work well when compared to OEM. I think you will have a power loss if it is clogged, which may make it use more gas.
  3. Jun 12, 2012 at 9:31 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    What kind of sensor did you put back in?
  4. Jun 12, 2012 at 9:42 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
  5. Jun 12, 2012 at 9:49 AM
    prerunnerSD
    USA
    I put an oem denso 02 upstream bank 1 sensor that I bought off ebay brand new in hoping that would do the trick but the code came back.
  6. Jun 12, 2012 at 9:52 AM
    capetaco12
    capetaco12 .<>./
    Cleveland Ledge, MA
    Sold: 33's,armor,crawler,dents, ect. 2020 Gladiator
    OME lift CBI sliders, front bumper homemade rear bumper 33x12.50 m/t Gears Aussie locker inchworm crawlbox Homemade flat belly
  7. Jun 12, 2012 at 9:53 AM
    98tacoma27
    Ben
    Not Beech Creek
  8. Jun 12, 2012 at 9:55 AM
    prerunnerSD
    USA
  9. Jun 12, 2012 at 9:57 AM
    98tacoma27
    Ben
    Not Beech Creek
    Look at Rockauto.com They sell the name brand CAT's. They also offer 5% discount for members.
  10. Jun 12, 2012 at 10:10 AM
    koco
    koco Well-Known Member
    Bay Area Ca.
    '01 Taco
    Around $26,000 worth of unleaded in the fuel tank.
    Why do you say it won't pass?
    JGO likes this.
  11. Jun 12, 2012 at 10:11 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Try the link in the original post again, edited for your year model..........
  12. Jun 12, 2012 at 10:14 AM
    prerunnerSD
    USA
  13. Jun 12, 2012 at 10:19 AM
    prerunnerSD
    USA
    That looks like the downstream cat. The upstram has a slight curve on it bending up to the engine.
  14. Jun 12, 2012 at 10:21 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
  15. Jun 12, 2012 at 11:33 AM
    98tacoma27
    Ben
    Not Beech Creek
    I should specify, if your vehicle requires getting sniffed (exhaust gasses tested) it won't pass. All the sim does is send the proper wave form to the ECM to trick it into thinking the CAT is functioning properly.
  16. Jun 12, 2012 at 11:40 AM
    prerunnerSD
    USA
    Does this cat need to be welded in place? Or can I just use the bolts in place? Was it welded factory?
  17. Jun 12, 2012 at 11:54 AM
    cgs2k2
    cgs2k2 old man
    I think you can clamp it as long as you make sure there are no leaks.
  18. Jun 12, 2012 at 4:58 PM
    capetaco12
    capetaco12 .<>./
    Cleveland Ledge, MA
    From what i hear any aftermarket cat will work for maybe 1-2 years. my local exhaust shop refuses to install anything other than toyota cats in these trucks. If you get a walker/magnaflow whatever cat. It should pass smog no problem but it may set off the computer. buy the aftermarket cat and the sim for less than the yota cat. you wont be killing any extra seagulls.
  19. Jun 12, 2012 at 5:50 PM
    prerunnerSD
    USA
    thanks for all your help.. im going with a cat 'the truck shop' in san diego has.. it exceeds cal emissions standards and i believe is citytech brand.. they recommend that so i am going with that.. <$300
  20. Jun 12, 2012 at 5:52 PM
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    It is also illegal.
