Good and bad Performance mod help please
Discussion in 'Performance and Tuning' started by Pnicholas1019, Oct 8, 2013.
  1. Oct 10, 2013 at 4:21 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    URD did recently have a dyno delivered. :D. They are ceramic coated too.
    Notice bung locations. They have them in the middle primaries, as well as the collectors. So if you purchase the harness extensions, you can have your AFR sensors read all of the cylinders, versus just the center.
  2. Oct 10, 2013 at 7:00 AM
    tooter
    tooter play every day
    Greg
    Los Angeles
    2012, std cab, 5 lug, 2.7, 5 speed
    Built for maximum low end torque, tooter II.VII intake manifold spacer, LCE long tube header, Injen long tube intake, 2,900 rpm torque peak.
    This has all the marks of a very well thought out product. :thumbsup:
    Greg
  3. Oct 10, 2013 at 7:09 AM
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
  4. Oct 10, 2013 at 6:27 PM
    Kelvin
    Kelvin Wheeeeee
    16’ GX460 with some junk bolted on
    Looks like the product page is up for it. Says they are 304 SS.
    URD Spec-U Headers
    Now I want to get rid of my LT's and shorties that were supposed to go on by now for these...course that means I'd have to get creative come smog time.
  5. Oct 10, 2013 at 6:37 PM
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    Damn air injection, RAGE!!! I want that URD reeeeal bad :drool:
  6. Oct 10, 2013 at 9:16 PM
    novanut21
    novanut21 Well-Known Member
    Brent
    North Central,WV
    2009 TRD SPORT
    AFE CAI, Magnaflow cat-back, TRD S/C, TRD Quickshifter, URD Fuel Pump Kit, Wet Okoles Front&Rear, WeatherTech Mats, Sockmonkey Decals, Satoshi grille, JBA "shorty" headers, URD Y-Pipe, TTC Oil Catch Can, Lotek Dual Apillar gauge pod w/ Autometer Phantom II AFR & Vac/Boost, URD Pulley, HID Retrofit.
    Nice! I'm definately down to get a set to replace my JBA shorties.
  7. Oct 11, 2013 at 12:33 PM
    RacecarGuy
    RacecarGuy Well-Known Member
    Houston, Texas
    '12 DCSB OR
    Pelfreybilt front and rear HC bumper w/swingout, BAMF LCA Skids, BAMF Diff skid, Pelfreybilt IFS and Trans skid, RCI gas tank skid, Bronze SCS F-5's, Icon RR's ext travel, Dakar leafs, Archive Garage shackle flip
    Any idea if they are going to make an air injection compatible set?
  8. Oct 11, 2013 at 6:46 PM
    PMK
    PMK Well-Known Member
    Florida
    10 DCLB TRD Sport
    White, debadged, Mudflaps removed, ICON 2.5 in front, 2.0 in rear, all 4 corners have reservoirs, Spidertrax wheel spacers all around, BAMF bolt on sliders, Avid lightbar, oem transmission cooler converted to power steering cooler, aftermarket transmission cooler eliminating all oem transmission cooler stuff, remote mounted spin on transmission fluid filter TrueTrac rear differential, rear diff housing vented and filtered into left side bed box, URD MAF calibrator, Volant intake scoop into oem airbox, second filter removed, airbox internals smoothed, blended and polished throttle body, NST intake manifold spacer, Wet Okolee set covers, WeatherTech Digital Fit mats, inexpensive JVC single DIN, Scangage, AVS Stepshield door sill protectors, Doug Thorley Long Tube Headers, URD Y pipe with O2 sims.
    Agree, I have brand new DTST in the box and a set of used cats that I just never find the time to install...this look BA and with no emissions checks, this is true plug and play.
    PK
  9. Oct 11, 2013 at 9:20 PM
    Pnicholas1019
    Pnicholas1019 [OP] Well-Known Member
    Parker
    surprise
    '92 toyota tacoma
    6" lift, front bumper, Oil cooler, HID lights, toyo m/t 33's.
    i like these urd better headers peobably step right into those but as far as an exhaust i like the low sound of the magnaflows. or should i stay stock?
  10. Oct 11, 2013 at 9:24 PM
    Pnicholas1019
    Parker
    surprise
    '92 toyota tacoma
    come time for emmisions i will head north to the dmv that doesnt do smog checks!
  11. Oct 11, 2013 at 9:26 PM
    Pnicholas1019
    Parker
    surprise
    '92 toyota tacoma
    also the urd with the magna flow catback offroad system seems like a good matchup.
