Good/bad A/C compressor brands?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Aerose91, Dec 9, 2024.
  1. Dec 9, 2024 at 10:07 AM
    Aerose91
    Aerose91 [OP] Well-Known Member
    Connecticut
    07 TRD Sport 4x4
    My compressor locked up, so I am replacing the compressor and expansion valve. Any brands that are suitable replacements for OEM and isn't crap? I'd rather pay a little more to not have to do this again.
  2. Dec 9, 2024 at 10:16 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    I believe Delphi is currently the closest thing you can get to OEM since Denso discontinued them but do note that the Lock Sensors on replacement compressors have been quite problematic lately so save the one off your old compressor in case the new one doesn't work.
    Also if there is metal contamination the condenser must be replaced and all lines & evaporator need to be flushed thoroughly.
  3. Dec 9, 2024 at 12:50 PM
    Williston
    Williston Well-Known Member
    New England
    2014 Tacoma 040 SR5 4x4 DC SB V6 AT5 Tow Pkg Entune+ Mostly stock with a few OEM mods.
    Stock (99.999%) OEM Bed Floor Mat, Front Bed Rail Cargo Net and hooks, Auto-Dim mirror w/Compass and outside Temperature display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. (winter) OEM All-Weather floor mats (summer).
    It's a shame that the OEM Denso compressor is NLA but given the expense of doing it over again if you have an early failure, (and the way things are going possible NLA in the near furture) I would go with the OEM expansion valve and any other pieces you need.
    It might be worth it to search around for an OEM Denso compressor too: I would think it's a good possibility out there that a big dealer might still have a few stashed away on the shelf. If you need a condenser too, Denso makes them and I understand they are far less expensive than the Toyota OEM part. (which Denso also makes)
  4. Dec 9, 2024 at 12:51 PM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    2021 Tacoma TRD Off-Road 4x4
    Denso always if you can get it.
    Stay as far away as you can from Four Seasons.
  5. Dec 10, 2024 at 11:13 AM
    Aerose91
    Connecticut
    07 TRD Sport 4x4
    These are helpful, thanks. Is Denso the OEM brand? So a Denso expansion valve is my best bet?
  6. Dec 10, 2024 at 2:36 PM
    Williston
    New England
    Historically those OEM Toyota parts have been supplied by Denso, but You may want to confirm that this is still the case.
  7. Dec 10, 2024 at 2:40 PM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    Denso is generally OEM Toyota for most of their parts. This is a good site to check part numbers at and to see if they still make parts for your application: https://www.densoproducts.com/application/search. It also lists if they were the OEM supplier for that part which is nice.
    Williston likes this.
