Good bumpstops?
Discussion in 'Suspension' started by mh.meier, Mar 9, 2012.
  1. Mar 9, 2012 at 9:46 AM
    mh.meier
    mh.meier [OP] PB MIKE Vendor
    MAD MIKE
    Flagstaff AZ
    Truck Norris Silver Unicornimus Prime
    2008 Tacoma DCLB 4X4 SR5 -Pelfreybilt Steel front single-hoop bumper(, color matched -Heretic Studios 20" single row light bar -Rigid Dually D2 Flood pods -KM FABRICATION custom 1/4" steel bumper mounts -Warn ZEON Platinum 12,000lb Winch -Pelfreybilt Rear HI-Clearance bumper with swingout -NATO can carrier -Folding Aluminum table -RIGID SRQ reverse lights -Full Pelfreybilt skids -ARB air compressor under the hood -Custom CO2 Setup -KMFAB Custom ext brake line brackets -KMFAB Bedrack -Camping Lab MANSION RTT -ARB Touring 6' Awning -Litra Torch camping light -CTC Bed Cap, color matched -Toyota OEM bedmat -KMFAB bed reinforcement -AVID Offroad weld on slider -BAMF Bed corner tie down brackets -Custom chopped front fenders -Front custom satoshi gille, color matched -OTTRAW switches -King Ext Travel front CO's -King 700# coils -Total Chaos Uni-ball UCA's -Dirt King stock length lowers (soon to be installed) -Sway-A-Way 2.0 rear ext travel shocks -All-pro Expo LEaf packs w/ custom bumps -35" Goodyear Wrangler MTR's w/ Kevlar -16" SCS SR8's in Black -Custom Retrofits -Smoked Tails -Airflow Snorkel -Cobra 29LX CB with PA and the fixins' -KMFAB CB antenna mounts -Pioneer in dash DVD with Nav -Weathertech mats
    I am putting a 3in lift on my Tacoma and I purchased the Billy 5100 RCD rear shocks but one of the problems they said I might have is that the shock will bottom out before the bumpstops hit. Is there anyway I can refit my bumpstops to hit sooner or is there another set i can purchase? I have been looking at Air bumps but I am not sure which one will work best with my shocks. Any help?
  2. Mar 9, 2012 at 9:53 AM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    Who said Allpro? I thought that shock would work! You'll prob have to measure the collapsed length and go from there! They have the timbrens that will stop your up travel otherwise you could put a spacer under the flip kit they have...that thing is thick as hell!
  3. Mar 9, 2012 at 9:54 AM
    mh.meier
    MAD MIKE
    Flagstaff AZ
    I have the flipkit on order as well with my new leafs, should I just get the Timbrens with the flipkit?
  4. Mar 9, 2012 at 10:03 AM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    If you want to overpay 1,000% for some rubber then by all means get Timbrens....I just can't justify the price difference from what other vendors offer. IMO they are a rip off.
    just about any bump stop will work if you invert it. You can then tack weld plates on top of the flip kit until you reach the desired travel or put spacer plates between the bump and frame. Just be sure it's strong.
    mine with wheelers bumps
  5. Mar 9, 2012 at 10:10 AM
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    The timbrens tend to be pretty tough on the rebound if the rear end hits hard! I didn't like them and got some superbumps from wheelers. They are 1.5" taller than stock but still compress to the same size which is 3". If you mount a bump stop to that flip plate I think it sits up 1/4-1/5" higher (thickness of the plate). Depending on how much room the shock has untill it bottoms out you might be ok.
    You'll prob have to get everything on and see.....! Or see who's running the AP pack you'll have and get a collapsed measurement!
  6. Mar 9, 2012 at 10:14 AM
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    XXXX, what are you running? AP's with 5100's?
  7. Mar 9, 2012 at 10:24 AM
    mh.meier
    MAD MIKE
    Flagstaff AZ
    Yeah, I didnt like the price of the timbrens since they were close to the same as the airbumps. I didnt know about the wheelers bumps which is weird since I but everything throught them and DSM. But yeah I bought the AP standard leafs and the 5100 RCD's.
  8. Mar 9, 2012 at 10:27 AM
    mh.meier
    MAD MIKE
    Flagstaff AZ
    Wow, I didnt realize I could gt both front and rear bumps from wheelers for less than the Timbren rears.
  9. Mar 9, 2012 at 10:38 AM
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    Ya, the superbumps in the front make a noticeable difference! I could feel them there the first time I took the truck out....kind of like a secondary shock adding some resistance on compression but not too much!
    I'll prob drill 2 holes in my superbumps and mount them to that flip plate when I do mine!
  10. Mar 9, 2012 at 10:43 AM
    XXXX
    sKiP
    05 Prius
    TSB pack with overload removed and wheelers 3 leaf progressive aal. Going strong for over 30k of abuse so far.
    yep...and Wheelers bumps are expensive. Do not buy the rears with the "tower" as it's a waste and will be 1/2 the posted price without it. There are many other sources for bumps out there. Look around and you could do the rears for probably $40.
  11. Mar 9, 2012 at 10:43 AM
    mh.meier
    MAD MIKE
    Flagstaff AZ
    Its that easy to mount em to the flip plates? I think Ill do that too then. Thanks for all the help amigo. i am ordering the Wheelers bumps right now.
  12. Mar 9, 2012 at 11:05 AM
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    He needs the height the towers offer. Your shocks can take the compression, his wont! I like how you did yours though!
    Ya, the pre-drilled flip plate (have to ask for those) from AP is used for the timbrens. Drill the same hole in the superbumps plate and they're on.....or you could weld them on if you have access.
  13. Mar 9, 2012 at 11:09 AM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Camburgs, Methods, Vision X, BFG
    or do it upside down!
  14. Mar 9, 2012 at 11:22 AM
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    Did you do brake lines with that Pat? Not sure I'm confident in bleeding them when I get a new pack?
  15. Mar 9, 2012 at 11:23 AM
    XXXX
    sKiP
    05 Prius
    Take the $60 difference, save up some more $$$ and buy shocks that can :D
    Those towers severely curtail travel.
    X2.....
  16. Mar 9, 2012 at 11:29 AM
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    Hard to find a shock that compresses to 14-15" and extends to 27" while staying in the stock location! Do you have 265's? My 285's would never stuff that much!
    Pat's bumps are good...cheaper too!
  17. Mar 9, 2012 at 11:31 AM
    PLC721
    Patrick
    Chandler, Az
    Shock hoop for the win :cool:
  18. Mar 9, 2012 at 11:35 AM
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    For sure!
  19. Mar 9, 2012 at 11:35 AM
    XXXX
    sKiP
    05 Prius
    Yes, 265/70/17. I'm going to 255/85/16 so my rear will be getting re-tuned very shortly.
    Also gonna throw some new leafs into the mix.
  20. Mar 9, 2012 at 11:37 AM
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    That's smart, wider tires (although they look good) do not stuff well! You got good mileage out of that leaf pack!
