Good Deal?
Discussion in '1st Gen. Tacomas (1995-2004)' started by lonzorizo, Sep 13, 2010.
  1. Sep 13, 2010 at 11:13 PM
    lonzorizo
    lonzorizo [OP] Well-Known Member
    Lonnie
    Hoopa, Ca
    2003 TRD OR, 2016 TRD OR Tacoma
    Is this truck a pretty good deal http://humboldt.craigslist.org/cto/1952892423.html? I'm lookin to get a truck asap and this is one of my options. Isn't 6 inches too much of a lift? I thought after 3" of lift problems start to develop over time, any truth to this? What you guys think?
  2. Sep 14, 2010 at 6:24 AM
    Taco76087
    Taco76087 Well-Known Member
    Robert
    Weatherford,Texas
    04 Tacoma prerunner TRD SR5
    Rockford Fosgate p2 10'', Q-Logic Enclosure, JVC KD-PDR30 Ipod Connection, Rockford p200.2 Amp, Clear Corners, KING Coilovers, Rancho Rear shocks FJ TRD Trail Teams Wheels with 285/75/16 Duratracs
    run a history report, and see how many miles are on it. Look for signs of bodywork as well.
  3. Sep 14, 2010 at 8:44 AM
    lonzorizo
    Lonnie
    Hoopa, Ca
    Copy that....anybody have any comments about the lift?
  4. Sep 14, 2010 at 8:54 AM
    Matic
    Matic The "OFG" Baby!!!
    Tricky Dick
    Easley, SC
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate. 2019 Jeep JLUR.
    rrrraaaaaked.
    $9k for a dc 4x4 with what looks to be some money spent in it. No way. I wouldn't sell my 4x2 for that little.
  5. Sep 14, 2010 at 9:00 AM
    JLee
    JLee The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    I don't see a problem with 6" lift it it's done right It doesn't say what brand of lift or who installed it that would be my first question about the lift.
  6. Sep 14, 2010 at 9:02 AM
    Matic
    Tricky Dick
    Easley, SC
    wtf? how much does text cost in an add. Do you want to sell a vehicle or have people callin you all day long or stoppin by because your to retarded to add some info to the truck.
  7. Sep 14, 2010 at 2:34 PM
    Manlaan
    Manlaan Well-Known Member
    Greg
    Riverton, Utah
    2002 XtraCab SR5 V6 4x4 Black
    See Signature
    As far as the lift goes, it looks like there's a bit of a body lift on it, so if I had to guess, I'd say 3" of body and 3" of suspension to get to the 6". Not necessarily a bad thing since the body lift does give you more fender clearance for larger tires with out any trimming, but still... Maybe its a bit more than 3" for the body lift. No clue.
    It really depends what the other part of the lift consists of, how many miles, and what other features are there if its worth the money or not. The body lift itself really isn't worth anything to add to the resell price.
  8. Sep 14, 2010 at 2:52 PM
    lonzorizo
    Lonnie
    Hoopa, Ca
    Ima call the guy up after work and get some more details on the lift and the mileage...
  9. Sep 14, 2010 at 3:19 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Sadly, the craigslist ads are free. Just a lazy seller.
  10. Sep 14, 2010 at 3:42 PM
    lonzorizo
    Lonnie
    Hoopa, Ca
    What u mean by "rrraaaaaked"?lol
  11. Sep 14, 2010 at 4:31 PM
    Manlaan
    Greg
    Riverton, Utah
    See Signature
    He's just mentioning the rake on it (back end higher than the front) I think, although I believe is pretty close to the factory angle for a 4x4. For some reason a lot of people dont like the rake.
  12. Sep 14, 2010 at 5:12 PM
    lonzorizo
    Lonnie
    Hoopa, Ca
    O alright got it...lol nevr wlda guessed
  13. Sep 14, 2010 at 6:36 PM
    lonzorizo
    Lonnie
    Hoopa, Ca
    4" suspension lift and 3" body lift....130,000 miles. Idk if I wna spend money on a truck with that many miles already.
  14. Sep 14, 2010 at 6:40 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Donahoe CO, Donahoe Rear Resi, Deaver J59, 16" Pro Comp, 33" BFG AT, Hayden Trans Oil Cooler, Oil Filter Relocator, FM 40, ES Bushings, Beefed CB Drop, Deckplate, K&N Drop-In, DO Bed Bar, Cobra 75 WXST, Firestik Firefly, Philips D1R, Clarion Remote Start, Husky Liners
    What happened to the flares?
  15. Sep 14, 2010 at 8:03 PM
    Manlaan
    Greg
    Riverton, Utah
    See Signature
    That many miles isn't necessarily a problem. It just depends how well it was taken care of. Personally, I'd be a bit on the careful side with that much lift, as others have said, its not a problem if its done correctly, but I'd be cautious about any other upgrades that might have been done as well, but again, not a problem if done right.
    With that large of tires, it probably should be regeared to 4.56 or 4.88, so probably feels a bit sluggish now. If you're ok with it how it is, thats fine and it wont hurt anything, but regearing front and rear (assuming 4x4) is pretty pricey but will give you a bit more to the wheels, at the expense of higher rpms at highway speeds.
    It really just comes down to what you want. I'm not a fan of the body lift, but if you wanted 6" with out replacing the cross member, that is the way to do it.
    Any idea about the engine in it? If it has the 3.4, make sure the Timing belt has been done very recently, as thats recommended every 60k. If it hasn't been done, expect to spend another $500-1000. Aside from that, just the normal maintenance stuff with any other vehicle. Make sure the 4x4 and locker works as well.
    Just remember that when selling things like cars, people post a price expecting to be talked down a bit, so keep that in mind.
  16. Sep 14, 2010 at 8:38 PM
    lonzorizo
    Lonnie
    Hoopa, Ca
    Wow thanks alot for all the info that's exactly the kind of reply I was hoping for. He said its a rancho suspension lift and the rest is stock except the stereo. And I assume its the 3.4 did they come with n e thing besides that for the dc? Dnt think so n e ways. I can just remove the body lift too right n run 32's or smthin...but jw how much would re-gearing cost about? And thanks again man really appreciate everybodys help I got screwed over for my last truck, 01 frontier that's just a yard ornament now...
  17. Sep 14, 2010 at 8:42 PM
    Blue
    Blue You're my boy blue
    Dylan
    Sierras
    ex 99 current 04 TRD
    yeah you can remove the body lift
  18. Sep 14, 2010 at 10:00 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Some d-cabs came with a 2.7l 4 cyl. If that one has the 4, it better be re-geared or it will be really gutless with those 33s.
    I would question the validity of the TRD claim. If it has the v6 it has to have the TRD e-locker or its not a TRD.
    In my opinion, a Tacoma is not a TRD without the e-locker but there are a few trucks on this forum (d-cabs with 4-bangers) that are actual TRDs, though they are all equipped with auto trannies.
  19. Sep 14, 2010 at 10:09 PM
    Manlaan
    Greg
    Riverton, Utah
    See Signature
    Really not sure about the engines available in a Double Cab. Pretty sure the majority of DC are Auto Trans, but then again, I haven't really looked it up either. I'm with Digiratus though. If it doesn't have the rear locker, it may be called a TRD (even from the factory with the 4cyl), but it just isn't one.
    Regearing isn't cheap. If you're thinking of lowering the truck and putting on smaller tires anyway, it really isn't a concern, and even if you were to keep the same tires on, its really just a judgment call if you want to regear or not. If you did, you'd get better mpg and power at lower speeds, but less mpg at highway speeds. So, I'd say it more depends on the type of driving you're going to be doing more than anything else, and if you need the low speed power or not.
  20. Sep 15, 2010 at 10:39 AM
    Taco76087
    Robert
    Weatherford,Texas
    X2
