Good East Bay mechanic?
Discussion in 'Northern California' started by GVE, Aug 11, 2010.
  1. Aug 11, 2010 at 3:04 PM
    GVE
    GVE [OP] Member
    Greg
    Walnut Creek, CA
    05 PreRunner TRD Sport Double Cab Longbed
    Hey everybody, this is my first post on TW, but not my first time on. I've been scouring the site for the last couple of weeks and have found some really good info. I have a black '05 Tacoma TRD Sport DC LB, and am looking at getting a slight lift, new wheels, and bigger tires. I think I've decided on XD Series Hoss wheels if 16's will fit, or 17" XD Addict's (black and 4.5" backspacing for both). Initially wanted Nitto Terra Grapplers, but now I'm back to looking around. I just ordered a full set of 5100's and am still trying to figure out if I want AAL's (Toytec) or a mini set like the 3 Leaf Progressive Set from Wheelers. With the 5100's set to 2.5" up front, I've read that I can clear 285/70/17 (or 285/75/16) tires with minimal inner fender trimming. So I guess several questions:
    1: Suggestions for rugged looking, not too noisy, long lasting tires; burly looking AT or a "street friendly" MT keeping in mind 90% or more on road
    2: Which rear lift; a mini set, or AAL, and will I need 1.5" or 2" lift (I have a camper shell) to make it level
    3: The big question; which mechanic should I go to to do this work? I live in the East Bay, so hopefully some shop in the vicinity. I don't have any tools, might be able to borrow some, but have never done any of this before and want it to be done right. I know I'll have to go in for an alignment regardless.
    Any thoughts or inputs? Thanks for all your posts and getting me started!
  2. Aug 11, 2010 at 8:38 PM
    PreRunnerSeth
    PreRunnerSeth Well-Known Member
    Apex, NC
    16 Super White Limited 4x4
    I would suggest 2.5 Lift on the billies with a 1.5" aal to be level
    As for tires Im not sure. I have only had one set.
    For install you can come to Mod day in september and we can install them here. I/we have installed a lot of lifts here at my house and I have all the necessary tools including a professional spring compressor.
  3. Aug 12, 2010 at 8:08 AM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    i live in concord..for your basic mech needs..toyota pro in concord is pretty kick ass.
    for your lift..1.5 hours at seth's mod day..and it would get installed quick. i did the 1.5" aals..for my NON- tsb rears..and i ride level (maybe even i smidge low?). i think i would do the 2", to make it a tad higher..
    i installed my lift at seth's..funner and cheaper than any shop. he orders pizza (we all chip $) from a pretty good place too :D
  4. Aug 12, 2010 at 9:56 AM
    GVE
    GVE [OP] Member
    Greg
    Walnut Creek, CA
    Wow guys, that sounds perfect! Thank you Seth for hosting and the invite! I've got a friend who works at Pyramid, maybe I'll see if I can get a pony keg or something... I'd love to get some experience and see what everybody else is running.
    Aficianado, you say that 1.5" AAL and the Billies set at 2.5" up front might make it a little nose high (reverse rake)? But if I set the front at 2", would I be able to fit 285's on there? I'm fine with trimming the inner fender, but I'm trying to avoid the purchace of UCA's and wheel spacers...unless that's a good idea anyway.
    The other question I still have is if I can fit 16" (4.5" backspace) wheels on my TRD Sport set-up. I've heard that sometimes the calipers stick out too much. I'm going to get new wheels regardless, and I'd rather have more tire than wheel. People also keep talking about hubcentric or not. I still don't really know the difference and which I should go with.
    Thanks for your words of wisdom guys!
  5. Aug 12, 2010 at 10:49 AM
    GVE
    GVE [OP] Member
    Greg
    Walnut Creek, CA
    Sorry, I misunderstood. I'll look for 2" AAL's. Here's another thought, what about putting on 885's around the 5100's up front? Is that possible, and if so, would the ride be better?
  6. Aug 12, 2010 at 4:18 PM
    PreRunnerSeth
    Apex, NC
    With 885's the spring provides all the lift so you would have to set the billies at 0. Not sure which would ride better, But most are satisfied with the lift obtained with just the 5100's.
  7. Aug 13, 2010 at 10:10 AM
    GVE
    GVE [OP] Member
    Greg
    Walnut Creek, CA
    Thanks Seth. Right after that post I did more searching on TW and found that same answer. I think I'll stick with the 5100's all around and either 1.5" or 2" AAL's. I'll have to get longer U-bolts for the AAL's, but besides that, is there anything else I'll need for the lift? If it's still OK, I'd love to work on it at your Mod Day. Can't wait to get it put together!
  8. Aug 13, 2010 at 10:27 AM
    PreRunnerSeth
    Apex, NC
    you will probably need shims or a carrier bearing drop kit to help with rear drive line angles.
    You need to get yourself in the mod day thread and sign up and put yourself down for suspension mods. I limit the suspension mods to 2-3 since the first couple times I didn't and we ended up being there WAY late.
  9. Aug 13, 2010 at 10:29 AM
    Rucas
    Rucas 1st gen
    Lucas
    1st gen. 4x4
    Custom Aluminum Camper
    WHAT! your in concord??
  10. Aug 13, 2010 at 10:44 AM
    aficianado
    back to bone stock.
    yup..concord. near downtown..you?
  11. Aug 13, 2010 at 10:48 AM
    Rucas
    Rucas 1st gen
    Lucas
    1st gen. 4x4
  12. Aug 13, 2010 at 11:54 AM
    GVE
    GVE [OP] Member
    Greg
    Walnut Creek, CA
    I'm thread jacking my own thread here, but aficianado and sharkie, maybe we should roll up together. I'm bringing my set of 5100's, U-bolts, shims, and AAL's...plus a bit of beer.
    Lucas, I see that we have the same truck, but you've been very busy. I got mine used a few months ago, and it's still straight stock. My tail lights are cracked and I was thinking of getting tinted ones. Where did you get yours?
  13. Aug 13, 2010 at 12:11 PM
    Rucas
    Rucas 1st gen
    Lucas
    1st gen. 4x4
  14. Aug 13, 2010 at 3:16 PM
    GVE
    GVE [OP] Member
    Greg
    Walnut Creek, CA
    Man, that's a good write up, but I have to get new lights all together...they're cracked. That's pretty ironic that your set up is exactly what I was looking at. I've got the bilsteins and AAL's in the mail, and am just about to pull the trigger on a wheel/tire package with Terra Grapplers. I think I'm going to go with the 285/70/17's though. Hope they're good tires...
  15. Aug 13, 2010 at 9:54 PM
    Rucas
    Rucas 1st gen
    Lucas
    1st gen. 4x4
    haha nice. I got the front 5100's from another another member on here. but i dont think down south motorsports has anymore rear 5100's so im just sticking with shock extenders and an aal.
    I have heard good things about the nittos, so hopefully they arent a waste.
  16. Aug 26, 2010 at 12:13 PM
    lmnt
    lmnt Active Member
    Any of you guys get the TSB leaf spring done locally? I still need to do it.
  17. Aug 27, 2010 at 9:29 AM
    GVE
    GVE [OP] Member
    Greg
    Walnut Creek, CA
    Man, I wish I could have gotten it, I got mine used with too many miles. Lots of Toyota dealerships around though, so I'd just start calling if I were you. Hope you get it, it's a sweat deal.
  18. Sep 28, 2010 at 10:40 PM
    lmnt
    lmnt Active Member
    Toyota Concord is doing it with no hassle - took 2 weeks for them to get the parts though oO.
    Now I just need to get my front lift in before I head in for the free alignment :)
